Question about RCA HD52W59 HDTV Projection Television
Bad convergence replaced Fl231 and diode DL231
  • RCA Master
  • 8,617 Answers
Did you reflow the solder on the flyback? If not the FL231 will blow again and the convergence will still be off.
Posted on Nov 15, 2009
WERE CAN I BUY AND HOW MUCH IS A FL231 FUSE FOR RCA HD52W59
If you replace just the fl231 it will blow again. You will need to replace the FL231,DL231 and CP230. You can get the parts at the following link with free instructions with pictures total cost is about 26.00. Its listed under the RCA repair kits as the ITC222 & ITC222A convergence option missing repair kit. Its available at www.tvrepairworld.com
Dec 29, 2011 | RCA HD52W59 HDTV Projection Television
Convergency has gone out of sync, went to try to realign but the convergeny setting was not listed in the tools menu.
Thats usually caused by a blown FL231 Fuse and a blown DL231 diode that blow when the flyback transformer develops solder cracks around the pins. The repair is to first resolder the flyback then replace the FL231 fuse and DL231 diode. You can get the RCA / GE convergence option missing repair kit which has the parts and repair instructions from www.tvrepairworld.com
Jul 09, 2011 | RCA HD61W66 61" Projection HDTV
Hi I have a convergence issue. Is there a place in NYC where I can purchase these replacement items: (1) FL231 micro fuse (1) DL231 Diode (1) CL230 radial Capacitor I repaired the initial...
This DLP model RCA tv have convergence menu disappearing is very easy to fix just replaced the convergence fuse FL 231 near the FBT also must be resoldering FBT too.U can buy this FL231 covergence fuse at Ebay.com.No,but u must have to have a soldering iron,a desoring pump or desoldering braids and know how to basic soldering?To replaced this FL231 convergence fuse near the FBT and also must resodering the FBT too for protecting the new FL231 convergence fuse.
Mar 02, 2011 | RCA R52WM24 52" HDTV Projection Television
Wont turn on after replacing FL231 fuse on a RCA HD52W59
If you replaced the fuse alone without installing the other components that are rquired to repair that issue the new fuse can allow voltages to flow trough the diode in both directions which can prevent the set from firing up. You need to replace the FL231, DL231 and CL230 as a set then reflow the solder on the flyback and vertical IC.
Dec 04, 2009 | RCA HD52W59 HDTV Projection Television
My convergence keep going out, I replaced the convergence twice. I have a rca hd52w59 modle
When you say replaced the convergence twice, are you refering to the convergence boards or the FL231 fuse? If its the FL231 fuse unless you replaced the DL231 and CL230 plus reflowed the solder on the flyback it will continue to keep blowing untill the 3 parts are replaced together and the flyback gets resoldered. If you replaced the convergence boards then try resoldering the flyback.
Nov 27, 2009 | RCA HD52W59 HDTV Projection Television
R52wh74 already changed 231 fuse still not converging
Did you change DL231 and CL230 with the fl231? Also did you reflow the solder on the flyback and vertical IC? Bad solder is what blows the FL231, but without changin DL231 and CL230 and resoldering the flyback and vertical the fix wont be fully effective.
Jun 12, 2009 | RCA R52WH73 Projection Television
I have an RCA HD52w59 with a convergence problem. I've been told different things on this site. First I was told to change FL231, CL230, and DL231. I've also been told to replace both IC's (STK392-110)...
Your set doesnt have STK ICs. If the convergence adjustment option has disappeared from the on screen menu, then replace FL231, DL231 and CL230 If the adjustment option hasnt disappeared from the menu then you need to check the resistors on the convergence power supply board some of those will be open. The actual convergence Board will usually not develope problems just the Convergence power supply if the convergence adjustment option is still in the on screen menu.
Mar 15, 2009 | RCA HD52W59 HDTV Projection Television
56"rca hd tv blowing fl231 convergance fuses
replace DL231, CL230 , Fl231 then reflow the solder on the Flyback and vertical IC and that should solve the problem. You can get replacement parts at the following link .
http://servicemanuals.vstore.ca/
Nov 26, 2008 | Televison & Video
RCA HD52W59 HDTV Projection Television Logo
140 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
