Question about Sharp XVZ200 Multimedia Projector
My sharp xv z200 after 3 months of not using it, gives a slight strange noise and the picture is flickering, both with the video signal and with the own display. the led's are all green. Guest
  • 405 Answers
Sounds like the color wheel ceasing up.
Posted on Nov 15, 2009
  • bryan21858 Nov 28, 2010
    how do you fix this
Sharpvision XV-Z2000 No red color in picture.
Hi This is most commonly caused by a loose or broken video cord. Check to make sure it is not loose or broken.
Oct 19, 2012 | Sharp XV-Z2000 Multimedia Projector
Samsung LNT4669F Pixcels Flicker
As long as you only see these artifacts while watching certain broadcasts, the TV is fine.  If these lines are present no matter what you are watching, then you have a problem. What you are seeing is signal related and there isn't much you can do to fix that. Think of it like a scratched DVD; you will see strange things on the screen at times and many think it's the TV when it's only the signal from the device to the TV that is corrupt.
I have thought of one possible solution and this will depend on your TV's ability to slightly stretch the picture in vertical/horizontal directions.  If your TV will let you, you may be able to raise the top of the picture a cm or so to hide the flickering.  Check the TV's onscreen menu for anything to do with picture alignment.  This is nothing to do with aspect ratio though so ignore that.
Mar 24, 2009 | Samsung LNT4669 TV
Sharp projectors color all green
how is the vga cable?
is the green color coming in the sharp menu with any signal?
Jun 15, 2008 | Sharp (BQCPGC20X1) Projector Lamp for...
Sharp Lcd Projector XV-H30U
check to see if you got the covers for the filters in the back and the side? if you dont have the cover for either of these it will not power up it only turns on for about 2 seconds and then it dies. it has a switch that must be pressed in when the covers are on. without the covers it only powers only slightly. you can jimmy rig it if you dont have the covers. try puting in something that is nonmetallic to depress the switch if your missing either th back or the side cover.
Feb 20, 2008 | Sharp (RLMPF0014CEZZ) Projector Lamp for...
Sharp Projector XV-Z90 Flickering
the color wheel is dirty. It just need to be cleaned.
Feb 18, 2008 | Sharp Projector lamp Projector Lamp
Sharp CVP10MX started to make strange noise periodically
What type of noise. Fan noise or compressor noise?
Aug 25, 2007 | Sharp CV-P10MX Air Conditioner
Sharp XV-H30U Projector No Video
En la parte trasera del proyector tiene un grupo de conectores de video, conecte la señal de video a proyectar en "in 1" o en "in 2" y posteriormente levante la tapa de acceso a los controles ubicada encima al lado izquierdo y con el boton "video in select" seleccione video 1 o video 2 segun haya conectado la señal atras, luego con el enfoque manual del lente obtenga el enfoque adecuado. Espero haber servido.
Jan 19, 2007 | Sharp (RLMPF0014CEZZ) Projector Lamp for...
Picture - Flickers/Shimmers
I think the solution to your problem is adjustment, not of the brightness but either the `contrast' which is probably too high, or the `sharpening' if your set has this function. Too much sharpness will cause a shimmering effect, especially where you see an edge between colours.(due to ringing at a very high video frequency). Too much contrast can start to turn the video signal upside down, causing noise on the peak white in the picture. Another cause is if the RF signal into the aerial socket is too large, This can be corrected by an attenuator, costing about £2. 6dB or 10dB can be tried.
Oct 23, 2006 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Sharp XVZ200 Multimedia Projector Logo
131 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
