Question about Nintendo Wii Console
My Wii console won't go on. I've checked all the connections. Can't turn it on via the paddles or directly by pushing (and holding) the button on the front.
  • copythat44 Nov 14, 2009
    I have tried resetting the brick by unplugging for a set period of time.
  • copythat44 Nov 18, 2009
    it worked. thanks!
  • 8,197 Answers
Have you tried to reset the brick on power cord.
To reset brick you need to unplug power cord from the wii and the wall for 5 mins. where it is not hooked up to anything.
Good Luck
Posted on Nov 14, 2009
Wii won't turn on.
Reset the AC adapter by following steps below.
1. Unplug the Wii AC adapter at both ends (from the back of the
Wii system and from the wall outlet or power strip).
2. After you've waited a full 2 minutes, plug the AC adapter back in on both ends and check to see if the power light comes on.
Jul 22, 2012 | Nintendo Wii Console
My wii won't turn on
Wii Console Won't Turn On, and Has No Power Light Situation:
  • The Wii console won't power on, and the Power LED is unlit
  • The console powers on, but shuts off after a few seconds/minutes
  • Attaching an accessory to the console turns the power off
Information:
This issue can be caused by an accessory or power surge tripping the circuit breaker on the AC Adapter.
What To Do:
  • Check any accessories attached directly to the console to make sure that it is licensed and undamaged. Unlicensed or damaged accessories shouldn't be used with the console.
  • Try using a different wall outlet, or plug a different device into the outlet to make sure the outlet is providing power.
  • Perform an AC Adapter Reset. (How To)
Dec 23, 2011 | Nintendo Wii Console
The mario kartwon't turn, it will go staight or backwards I pushed the red button and no change. what next?
Are you holding the controller in your hand sideways?Directional on one side and 1 and 2 buttons on the other?If you are,you just need to kind of turn the controller like a wheel with both hands.If you did that and it still doesn't work let me know.If you pushed the red button is that the one in the battery compartment?If you need to resync,you point the controller at the sensor bar with a game on and press and hold the red button inside the large door on the console.You may need to try it a couple times.
Jul 19, 2010 | Nintendo Mario Kart (Wii) for Wii
My console turns on via remote. I can push the left and right arrows but I am unable to select anything on the main menu. I have changed batteries, and tried different remotes. No change. Any suggestions?
Do you mean that no cursors appear on your screen? You most likely need a new sensor bar. The button presses are transmitted via wi-fi directly to the wii, but the wiimote's position relies on infrared transmission to the sensor bar.
Mar 29, 2010 | Nintendo Wii Console
My controller can`t connect to the wii. it tries, but it don`t work. i have tried to syncronize and move the wii away from other connection things like phones.
Open the SD Card slot cover on the front of the Wii console, just below the disc drive, and press and hold the red SYNC button for 15 seconds. This will clear all synced Wii Remotes from the console.Then try to sync it, press the red button on the console, then open the batteries cover on your
Wii Remote and push the red button there.
Nov 30, 2009 | Nintendo Wii Console
My Wii will turn on, but is not recognizing the remotes. I have tried to re-synchronize the remotes to the console, but they just keep flashing and don't connect.
First unplug your Wii from power cord and wait 30 min.Then plug it again and turn it on.Press and hold the red SYNC button for 15 seconds. This will clear all synced Wii Remotes from the console.Then try to sync it again.Push the red sync button on the console, then open the batteries cover on your Wii Remote and push the red button there.If this not help may be you have problem with bluethoot device on your Wii and this need service.
Nov 17, 2009 | Nintendo Wii Console
Wii fit balance board wont connect
Unplug the AC adapter from power cord then wait 10 min and plug it again.Open the SD Card slot cover on the front of the Wii console, just below the disc drive, and press and hold the red SYNC button for 15 seconds. This will clear all synced Wii Remotes from the console.Then push the red button again, then open the batteries cover on your
Wii Remote and push the red button there.After that push the red button on console one more time, then open the batteries cover on your Wii Fit and push red button there.If this not help may your wii fit need service.
Nov 02, 2009 | Nintendo Wii Fit for Wii
Can't sync wii remotes to console
When you sync the wii motes you have to do it in proper order!!!
There are 2 ways to sync one is minor out of sync stuff. You push red button on the wii briefly then quickly press the red button on the wiimote.
Second one is what you need to do. First remove any disk then hold in the power button until the light turns red. (not yellow or orange). Release it then unplug the Wii. Do not remove the batteries but if they are low replace them before you turn it back on. Wait at least 2 minutes.
Have the backs off the Wiimotes.
Plug the Wii in.
Turn the power on.
As the Health and Safety screen appears push in the red button on the Wii.
Hold it there a min. of 15 seconds. 25-30 is better.
When you release it right away push the red button on the first Wii mote. It flashes all the lights.
Immediately press then release the red button on the Wiimote while lights are flashing. When they stop flashing it will be synched.
a.Then press the button on the Wii again (this time only hold for 2-3 seconds) then press the red button on the second wiimote and while lights flash press the button on the Wii again.
Repeat a. for any other wiimotes.
Jan 01, 2009 | Nintendo Wii Console
Wii remote
Hey did you try holding the red button where you put the batteries and holding the red button where you put the SD card all unit have an button so it can read the sensor from unit to controller....
Jun 21, 2008 | Nintendo Wii Console
Remotes not synchronising
  1. Press the Power button on the Wii console to turn it on.
  2. Open the SD Card Slot cover on the front of the Wii console. Remove the battery cover on the back of the Wii Remote you wish to sync up.
  3. Press and release the SYNC button on the inside of the SD Card compartment on the console. Press and release the SYNC button just below the batteries on the Wii Remote.
  4. When the Player LED blinking stops, the syncing is complete. The LED that is illuminated indicates the player number (1 through 4).
Sep 15, 2007 | Nintendo Wii Console
Nintendo Wii Console Logo
16 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
phil
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
