Question about Motorola Mobility i425 iDEN Cellular Phone
Dowload pictures to my pc to motorola i425 - Motorola Mobility i425 iDEN Cellular Phone
How do I delete a picture off of the motorola i425 phone
look for an "options" tab. in there it should allow you to delete the picture
Aug 16, 2011 | Motorola Mobility i425 iDEN Cellular Phone
My i425 wont power up at all and when i put it on the charger it says device attatched but keeps saying battery low?? why?
First of all, lmauala1986, you say it's a i425, but the picture is of a i415. Anyway, it sounds like you may have a bad battery, if that's the case you should try a new (NOT USED) Motorola™ Battery (NOT a generic equivalent). Or, maybe the battery contacts (both on the battery, itself and inside the phone) could be dirty and maybe they could just use a good cleaning with a cloth moistened with rubbing alcohol. Hope this helps.
Aug 14, 2009 | Motorola Mobility Boost i415 Cellular...
Change service provider from boost to at&t on i425
att and iden are two different networks, even if you unlock the phone the sim card wont work
Jul 07, 2009 | Motorola Mobility i425 iDEN Cellular Phone
My computer doesn't recognize my phone!?
Hi Friend,
Initially check wither u have installed the PC Suite properly.If it is not installed properly then unistall the previous and u can install the motorola pc suite from below mentioned link
http://www.brothersoft.com/motorola-mobile-phonetools-61039.html
After installing try to connect the mobile to the pc with the help of the PC Suite.
Once connected u can access files,datas,internet
Regards,
Ayyasam
May 30, 2009 | Motorola Mobility i425e Pay-As-You-Go Cell...
How to turn off predictive texting on Motorola i425
go into a text message and push the button right above the green send button and choose alpha....problem solved
Mar 19, 2009 | Motorola Mobility i425 iDEN Cellular Phone
Deleting messages on Motorola i425
Hello, newa...
In order to delete a message, you select it and press the menu key (second key on the left side, between the first one and the Send key).
You choose the function "delete" message and press OK (the central key).
Does it solve it?
Mar 13, 2009 | Motorola Mobility i425 iDEN Cellular Phone
Motorola Mobility i425 iDEN Cellular Phone Logo
120 people viewed this question
Top Motorola Mobility Cell Phones Experts
Rami Obeid
Level 1 Expert
D. E. Hev
Lawrence Oravetz
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
