Question about Dyson DC14 All floors Bagless Upright Cyclonic Vacuum
My vacuum is really hard to push on carpet. Is this normal?
  • 1,056 Answers
You can adjust the hieght to make it easier to push.
Posted on Nov 14, 2009
5 Suggested Answers
galati2k
  • 281 Answers
SOURCE: my vacuum has good suction but i can hardly push it across my carpet. any answers????
is your brush roller turning,that would cause it to be hard to push .the brush roller helps it walk across the floor.if your brush roller isn't turning then your belt is broke or the brush itself siezed up.unplug the vacuum and try to turn the brush roller .if it turns real free then your belt is broke.before you replace the belt always clean the motor shaft ,the old rubber from the old belt melts onto the motor shaft .if you don't clean it your new belt won't last very long.please leave feedback
Posted on May 04, 2009
  • 97 Answers
SOURCE: dyson - can't push the vacuum
try to see if the carpet setting is to carpet. i know this machine says that its a life time belt,but i would check this just in case. best way to tell if it's working is to lay the machine on its belly with the brushes pointing up and turn on the machine to see if the brushes are turning. (be careful not to put your face directly in front, just in case something is lodged in the brush and flies out )
Posted on Jul 29, 2009
galati2k
  • 281 Answers
SOURCE: dirt devile featherlite vacuum pushes extremely hard on high pile carpeting
the dirt devil featherlight has a automatic height adjustment for carpet and bare floors.check the wheels and see if there is something wrapped up around the wheels
Posted on Apr 29, 2009
WonderTech
  • 268 Answers
SOURCE: While vacuuming it's unusually hard to push.
I see your post is from May. I just joined Fixya this month so, id you're still looking for a solution, I would saythe belt broken or is so stretched the roller isn't spinning. Here is an link to an online guide with illustrations for changing belt. Also check the roller brushes for wear and change if necessary. Hope this helps.
http://www.info-vacuum-cleaner.com/oreck-vac-belt.php
Posted on Aug 20, 2009
Why is it such hard work to hoover the carpet with the dyson dc 33.it is really hard just pushing it across a new carpet.
Are your belts working and is your power head set too low? Try raising it up one or two clicks. A broken belt will not let your brushes spin and a spinning brush will help it go on carpets.
Aug 20, 2016 | Dyson Vacuums
Why does my Dyson DC17 now push really ******* carpet?
Have you correctly replaced the glider that covers the brush? You need to make sure that the clips are fully seated .
Aug 16, 2014 | Dyson DC17 Animal Upright Vacuum...
Vax hoover suddenly hard to push on carpet
Make sure you have it set to carpet, other wise not sure
Mar 27, 2014 | Vax U89-P9-P Power 9 Pet Bagless Upright...
Adjust height for plush carpet
The best solution is to change your method of trying to push the vacuum. The more upright the handle is on an Oreck, the harder it will be to push. The lower the angle (the closer the handle is to the carpet) the easier it will be to push. There will be a huge difference. Use a straight stiff arm that is pointed directly down towards the carpet. Use your shoulder and have a near locked elbow. The vacuum will now push easily.
Jan 12, 2014 | Oreck XL Ultra Bagged Upright Vacuum
After changing the bag on my riccar it is very hard to push'
after putting a clean bag into the vacuum cleaner, more air can get through it, so it generates more vacuum, sp it is obvious, that it will be harder to push for some time. if it wont get better, it only means you didnt gt it with a clean airbag
Apr 22, 2013 | Riccar 8955 Upright Vacuum
Dyson 33 wont push on plush carpet
I'm sorry to hear you're having difficulty using your DC33 on this particular carpet. If you haven't already contacted our Helpline, I'd encourage you to do so, as we'll be able to discuss other options which may be more suitable for your needs.
You can reach us on 0800 298 0298 (UK), or 1-866-693-9766 (US). We'll look forward to hearing from you.
Best wishes,
Jack
Dyson Online Customer Support
http://www.dyson.com
Mar 27, 2012 | Dyson DC33 Bagged Upright Vacuum
Dirt devile featherlite vacuum pushes extremely hard on high pile carpeting
Apr 28, 2009 | Vacuums
When i am vaccuming it is really hard to push how do u change that setting
Raise your height adjust, and replace your belt. This will fix 99% of the problems with vacuums being hard to push.
Your height should only be as low as it takes to get your brushes to just make contact with your carpet. Peoples' natural inclination is to slam the vacuum as low as possible to deep clean the carpet, but in reality it's restricting your airflow and is cleaning less effectively, as well as making it harder to push.
A properly designed vacuum should be easy to push any time there's a new belt on. If these two solutions don't make it any easier, make sure your wheels are spinning free on the bottom.
-R
Aug 09, 2008 | Dirt Devil Vacuums
Dyson suddenly hard to push on carpet
I know this sounds silly, but it works. Turn it over and wipe all the black residue off the bottom of it (off the plastic on the bottom that rubs on the carpet as you push and pull it). I thought my husband was out of his mind when he told me that was the solution, but it really works.
Jun 02, 2008 | Dyson DC14 Animal Bagless Upright Cyclonic...
Dyson DC14 All floors Bagless Upright Cyclonic Vacuum Logo
2,030 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
