Question about Dream Maker Spas Dream Maker Ez Spa Hot Tub
The temp. lower button does not work. Can only raise the temperature.Dream Maker b6xh controls.
  • 366 Answers
Sounds like your topside controller needs to be replaced.
Posted on Nov 14, 2009
Dream maker spaX400. has a green spa control panel keeps flashing SL. I tried setting it to F2can't get it to stay thereIt keeps going back to SL can change the temperature up down temp ofstays at 91
It is in sleep mode. Press your mode button until it says sp again then hit temp up button or whatever button you use to change the f1 f2 f4 messages.. it should change to SD or ST or SN for standard mode...
May 06, 2015 | Pool & Spa
My dream maker spa at temp outside 40 is heating water till only 80 dont know what to do.
This is common when your Heater element is bad.
The friction of the water moving through the pump typically will raise the water to around 80.
Jan 17, 2012 | Dream Maker Spas Dream Maker Ez Spa Hot...
I have a keurig b 60 brewer and i don't feel the water is hot enough. i just got it last night 12/23/10 can u suggest anything?
Sorry to read about your problem, I hope this helps you out.
ProgrammingBrewTemperature (187°-192oF)
The Brewer brews at a preset temperature of 192°. You can adjust this temperature down by 5 degrees if you prefer a cooler cup of coffee, tea or hot cocoa. Simply follow the instructions below.
1. Press the Menu Button on the LCD Control Center five times to program the Brew Temperature feature.
2. The LCD Control Center will now display the programming options with a small arrow next to "SET BREW TEMP" (fig. 15). Also, the temperature 192° (initial setting) will be displayed at the bottom of the LCD Control Center to indicate the current temperature setting.
3. A minus sign will appear over the Small Cup Button and/or a plus sign over the Large Mug Button. Use these buttons to raise or lower the temperature one degree at a time.
4. Once you have reached your desired brew temperature, press the Menu Button once to exit the programming mode. "BREW TEMP SET" will be displayed in the LCD Control Center if you have changed it from 192°.
5. To change the brew temperature again, repeat steps 1 through 3 to change the temperature up or down, remembering that the temperature can only be between 187° and 192°.
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 24, 2010 | Keurig B60 Coffee Maker
Tub is not heating to temperature and flashing a Ec message on the temperature screen.
the Ec message is reffering to the mode the tub is set for. Ec stands for Economy mode. In Economy mode the heater will only come on during the filter cycle you have programmed. It will take a while for the tub to actually heat up in this mode. Change the mode to St mode which stands for Standard mode. Your manual should explain how to do this. usually you hit the temp button then the light button to change from mode to mode. Once the St is in the read out window don't touch anything and it will except the programmmed entry automatically. In the Standard mode the tub will keep heating until the set temperature is reached. then it will come on every half hr or so to check that the temperature is maintained.
Oct 09, 2010 | Dream Maker Spas Dream Maker Ez Spa Hot...
Will not make ice, freezer temp is high, can not control the temp
Check to see whether the ice maker has been turned off. Here's how to check. Look for a wire along the right side of the ice maker that looks a bit like a coat hanger. If this wire is in the raised position, the ice maker is turned off. On some units you simply lower the wire to the down position to turn the ice maker on. On others, you lower a small red plastic lever to lower the wire. If the wire is in the proper position check the freezer temperature, it should be between 0-8 degrees Fahranheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice. Check your door seals and thermostat, repair/replace as necessary.
Mar 31, 2010 | Frigidaire PHS39EHSS Stainless Steel Side...
Is it more cost affective to leave the hot tub on all the time or turn it off and reheat it
it depends on how often you use it and if you have a good cover with thermal value. If you use the spa more than once a week, then it's probably more cost effective to leave it at temperature. If its more like once or twice a month, then probably better to lower the temp. My spa uses about $30 per month of power leaving it at 104 degrees.
Sep 24, 2009 | Dream Maker Spas Dream Maker Ez Spa Hot...
Temperature control
For the Kenmore, keep pushing the button and it should cycle back to the top of the temperature range.
Sep 04, 2007 | Kenmore 63822 / 63824 Bottom Freezer...
Dream Maker Spas Dream Maker Ez Spa Hot Tub Logo
368 people viewed this question
Top Dream Maker Spas Pool & Spa Experts
Ian Kime
Ian Kime
john h
The Cover Guy
The Cover Guy
Are you a Dream Maker Spas Pool and Spa Expert? Answer questions, earn points and help others
