Question about Emagic EMI 6|2m External Sound System
Cant get emagic to work/ show on Audio midi set up on new mac 10.6 please help. Have downloaded and installed drivers
In snow lepard open the file manually from within the startup folder inthe library
Posted on Nov 15, 2009
Trying to find a Win XP driver for emagic emi 6|2 external soundcard?
http://www.filetransit.com/download.php?id=104065
EMI 2'6 Driver contains EASI, ASIO and the SoundManager Driver.The EMI 2'6 now supports the professional 24 Bit/96 kHz standard for optimal audio quality under Mac OS 9.1. In addition, with buffer sizes down to 4 ms, extremely short latency can be reached under EASI, ASIO and Soundmanager with...
http://www.rocketdownload.com/download.php?p_id=82681
http://www.filetransit.com/download.php?id=16210
it seems as though the only drivers are for mac operating system
Jun 03, 2011 | Emagic EMI 6/2 USB audio External Sound...
My oxygen 49 3rd generation (m-audio) midi keyboard just stopped working for me. Ive tried changing the usb lead, and I've tried it on a different computer, and it still doesn't work. I have a macbook pro,...
If the keyboard is lighting up, there is a 90% chance the problem is in the software in your MAC.
Hint: Software "breaks" easier than the hardware !!!
Re-install your software as a first step.
Sep 12, 2010 | M-Audio Oxygen 49 USB Midi Controller
Just purchased behringer u-control uca222. When first plugged in the power led came on. Downloaded the midi driver at the behringer site and attempted to install. Power led went out then the midi drivers...
The UCA222 is a USB AUDIO Interface, not MIDI.
You want to download the ASIO driver(s) and install those again. You then have to go to whatever audio software app you are using, and 'set up' the ASIO drivers within your audio software itself (read the manual or look at some of the headings under Preferences or Settings in the software window itself).
Also go to the Audio Settings panel and configure your Audio Ins / Outs, make sure they are selected and 'enabled'. You should see Behringer USB listed when you click on the audio out tab. Just click on it with the mouse button and release.
You also may have to go to the ASIO Control Panel (again from within whatever audio app you are using) and tweak whatever settings are there. Make sure the ASIO driver is selected (not the MS Win or Realtek or whatever), and check that the audio outputs are likewise enabled there.
(Some apps won't output any sound while you are adjusting the Control Panel settings etc, so you may have to adjust the settings, then close the panel, before you'll be able to test for audio output, then if it doesn't work, go back into the panel and adjust some more and try again.)
If you are trying to control a VST plugin or VST Instrument via MIDI, you just need to go into your audio app's Midi Settings panel and likewise make sure your Midi controller kbd (or other Midi source) is selected and enabled, and that the appropriate Midi channel is enabled (or you can just select Omni Mode and it will listen to all Midi channels).
Of course you must have some sort of MIDI interface to connect your keyboard to your computer. Many new kbds have USB in which case it will send/receive midi via USB (tho you may have to install the proper drivers for your specific keyboard first. - they will be on your install CD that came with the keyboard or available on the internet).
Good luck! Hope some of this helps.
Mar 19, 2010 | Behringer U-CONTROL UCA202 USB-Audio...
What exactly IS this A 6 2m?
Its a audio midi interface drive for an emagic audio midi.
Aug 02, 2009 | Emagic EMI 6|2m External Sound System
Hi i need new drivers and soft ware for emagic a 62 m sound card
Well, I can help you with the driver and manuals. I am not sure if you can get the software to interface with the unit here though. It may be bundled with the driver download.
http://download.info.apple.com/Apple_Support_Area/emagic/
You didn't say whether you have a Mac or PC, but this page has links to both.
Jun 18, 2009 | Emagic EMI 6|2m External Sound System
Sound module & mic (connected to a Tascam US-224) not working
I may be able to help.  I am a longtime Mac and Tascam control surface user.  I am currently running a MacBook Core 2 Duo 2.0GHz running OS 10.5.6 with a Tascam FW-1884 audio interface/mixer/control surface connected.
Setup is fairly easy in the Mac OS.  Here are the steps I'd follow:
NOTE: Before beginning the following process make sure that ALL of your MIDI gear is connected.
- Tascam connected to USB port of computer
- MIDI Keyboard "OUT" connected to Tascam "IN"
- Roland "IN" connected to Tascam "OUT"
1) Open your "Applications" folder.
2) Open the "Utilities" folder.
3) Double-click on "Audio MIDI Setup."
4) At the top of the window select "MIDI Devices"
5) In the pull-down menu on the left select "New Configuration."
6) Title your configuration and press "OK"
7) If your gear has been detected automatically their names and icons should appear in the main window.  If so, skip down to step 12
8) Click on the "Add Device" button
9) Double-click on the "new external device" button that has now been created.
10) Select your device's manufacturer and model (i.e. Roland, JV-1010).
11) Adjust any other settings appropriate to your setup.
[In the main window there should be a Tascam US-224 button.  On it there should be one pair of arrows that indicate the MIDI In and MIDI Out ports of the device.]
12) Click (and hold) on the MIDI Out arrow of the US-224 button.
13) Drag the "cord" and attach it to the MIDI In of the Roland JV-1010 button.
13) Click (and hold) on the MIDI In arrow of the US-224 button.
14) Drag the "cord" and attach it to the MIDI Out of the "keyboard" button.
This should get you setup from a Mac OS/Device routing perspective.  For the appropriate US-224 Control Panel settings refer to the User Manual.
Feb 07, 2009 | Tascam US-224 DIGITAL AUDIO WORK STATION...
Motu micro lite
Log into Motu.com with  UN - fixyajames PW - fixya
Hope the download fixes the problem.
James Mac
Sep 09, 2008 | Motu Mark of the Unicorn Micro Lite USB...
No driver
Aug 14, 2008 | Emagic EMI 6|2m External Sound System
Can get soundcard to work with my new studio speakers
i have a tascam us 122 and a mac leopard OS I cant find the drivers on tascam.com help me please
Nov 02, 2007 | Tascam US-122 USB Audio/MIDI Interface...
Emagic EMI 6|2m External Sound System Logo
204 people viewed this question
Top Emagic Computers & Internet Experts
David Payne
David Payne
Are you an Emagic Computer and Internet Expert? Answer questions, earn points and help others
