Question about GE GSS22JEPCC / GSS22JEPWW / GSS22JEPBB Side by Side Refrigerator
My refrigerator is noy staying cold enough.
My refrigerator is noy staying cold enough. Both the fan and compressor are running, door has not been left open, it is clean behind the fridge
  • 464 Answers
You may have a defrost problem, and will need to replace the main control board assembly which is item #801 in the attaced breakdown. The part # is WR55X10174. My refrigerator is noy staying  cold enough. - 250
Posted on Nov 14, 2009
I have no cold air in my refrigerator or Freezer. It defrosted everything.
Condenser Coils are Dirty
If the refrigerator is not cold enough the condenser coils may be dirty. The condenser is like a radiator and must stay clean in order to dissipate the heat which was removed from the inside of the refrigerator. As the coils get dirtier the refrigerator becomes less efficient, which makes it work harder to cool down. If the coils are dirty enough, the unit will never be cold enough and will not be able to cool the inside of the refrigerator to the proper temperature.
Evaporator Fan Motor
If the refrigerator is not cold enough, the evaporator fan motor might have failed. Every refrigerator has a set of coils called an evaporator. The refrigerator may have one or more evaporator fan motor(s) depending on the model and evaporator locations. The evaporator fan motor circulates the cold air from the coils thru the compartment. If there is only one evaporator it is in the freezer side. If the fan is not working, no cold air will get to the refrigerator compartment. The freezer may still get cold.
Condenser Fan Motor
If the refrigerator is not cold enough there might be something caught in the condenser fan motor blade, or the condenser fan motor might be defective. The condenser fan motor draws air over the condenser coils to cool them. The condenser fan motor is located underneath the refrigerator near the back. Pull the refrigerator out from the wall and remove the access panel to access it.
Start Relay
If the refrigerator is not cold enough, the start relay may be defective. The start relay is a small device mounted to the side of the compressor. It provides power to the run winding along with the start winding for a split second at start-up to help get the compressor started. If the start relay is defective the compressor may run intermittently or not at all and the refrigerator will not get cold enough. The start relay should be replaced if defective.
Temperature Control Thermostat
If the refrigerator does not get cold enough the temperature control thermostat might be defective. The thermostat allows power to flow through to the compressor, evaporator fan and condenser fan. If the cooling system fans and compressor are running, but the refrigerator or freezer is not cooling correctly check for an airflow or defrost system problem.
Start Capacitor
If the refrigerator isn't cold enough the compressor might be having difficulty starting. The start capacitor serves as a battery to give the compressor a little boost during start-up. If the start capacitor is burned out the compressor might not be able to start and run as often as it should. Test the start capacitor first with a capacitance meter, they don't fail often. If it's defective, replace it.
Thermistor
If the refrigerator is not cold enough the thermistor might be defective. The thermistor is a sensor which monitors the air temperature. It is connected to the control board. If the thermistor is defective the refrigerator does not cool or may cool continuously.
Temperature Control Board
If the refrigerator is not cold enough the temperature control board might be defective. The temperature control board provides the voltage to the fan motors and compressor. These boards are often misdiagnosed. Check all other components to be certain this is the cause of the problem.
Compressor
If the refrigerator is not cold enough, the compressor might be defective. The compressor is a motor which compresses the refrigerant and circulates the refrigerant through the evaporator and condenser coils. There are several other components which are more likely to be defective if the compressor doesn't work. If the compressor itself is defective a licensed professional will need to replace it.
Main Control Board
If the refrigerator is not cold enough the main control board might be defective. This is not common. Check the defrost system, cooling fans, and cooling controls first.
Jun 28, 2017 | Refrigerators
Subzero 532 refrig fan(& compressor) doesn't shut off
the higher the number on a fridge the warmer it is so setting it to 1 is close to 0C
when working on a fridge or freezer always turn it off at the wall
if the fridge is keep cold but not cold enough set it back to say 3
if the compressor is running and the back fins / wall is hot then the fridge is working
use a piece of paper between the door seal and the fridge edge to ensure that it is sticking to the fridge and sealing off properly
Jul 16, 2017 | APW Wyott SubZero Refrigerator Freezer...
Both fridge and freezer aren't getting cold enough in my Maytag Fridge
if they are both cold, but not cold enough, one of two likely scenarios, one minor, one major. the major one, you haev a sealed system leak of refrigerant, several hundred dollars to repair.
the minor, your condenser fan motor is not running, its job is to cool the compressor, if its not cooling the compressor, when the compressor gets too hot, it will shut itself down, while the fridge continues to run. when this happens, the unit seems fine first thing in the morning, but by evening it seems less fine...while everyone sleeping, doors have been closed, allowing unit to "catch up". replace fan motor.
Feb 27, 2010 | Refrigerators
Fridge/freezer not working but light is on,located in garage,which iss v cold
Normal 0 MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} . Cut everything off for a few minutes then turn it back on and listen for a click from the compressor relay as the compressor tries to start.
Is the compressor motor running.If no check starter/overload relay.
Check to see if the condenser fan at the back underneath near the compressor is running. If no check fan.
Are the condenser coils near there warm or room temp. should be warm
How to check stuff>
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Is the evaporator fan in the freezer running. It blows cold air into the fridge side through a damper in the wall between the freezer and fridge. Make sure the damper is open.
Below the evaporator fan is the evaporator coils. Remove the back cover in the freezer to observe the frost pattern. Light frost everywhere(NORMAL) or a partial pattern of ice(LOW ON FREON) or nothing(LOW FREON OR COMPRESSOR PROBLEM).
Not all refrigerators are insulated the same and not all condensers are in the same place. Your cold control is monitoring the temperature of the refrigerator section and is designed to turn off the compressor to keep things from freezing in that section. If it stays cold long enough outside in your garage the cold control thinks its cold enough and won't turn the compressor on. A makeshift closet to hold a little heat the unit generates will probably help.
Jan 10, 2010 | Refrigerators
I have a ge gss22kgpacc side by side, the freezer is working, lights, etc. all working, but the refrigeratoe side is not working, any insight? thanks, mike
on most units they have two controls refrigerator control is electric t-stat that runs compressor freezer control think of it as a door colder freezer door is barely open warmer freezer door all the way open all cooling coils are in the freezer and a fan moves the air to refrigerater side possible problem fan not running
door freezer control all the way closed
light switch broken light staying on door gasket not sealing tight find door switch press verify light shuts off and fan starts
look for torn or damaged door gasket can look from outside with light and see if gasket contacts case on all four sides
freezer is cold enough so compressor is ok hope this helps good luck ron
Dec 12, 2009 | GE Refrigerators
Model gss20iepcbb freezer side works fine ...fridge
freezer is cold enough so compressor is ok hopr this helps good luck ron
Dec 10, 2009 | Refrigerators
Freezer is not staying cold. The freezer is on but its not staying cold enough to keep the food frozen. The Ice maker switch is turned on but ice is still melting. Turned the control to coldest but still...
Sounds like the evap. fan motor is not turning. What is the freezer temp. have you measured it ? What about the fresh food section, (fridge compartment).
Anyway, try this. Hold the door switch in the closed position with the freezer door ajar and see/listen for the fan coming on. If you can't be sure, the best way to do this is to first turn the thermostat all the way to the "off" postion, and with the freezer door ajar and holding the door sw. closed (pushed in). turn the thermostat back on. (you may need to turn off then back on first if your arms aren't long enough) You should hear the fan motor start.
NOTE; you may hear the compressor overload "click" off if trying to start it right after shutting down, this is normal (under short cycles or manual restarts). You may also hear the condensor fan motor run (under the fridge by compressor) this too is normal. try to indentify the freezer fan (evaporater fan motor) running or not.
good luck.
Sep 24, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Kenmore elite 596 73503201 no cooling in top compartment
if the freezer is getting cold the problem is due to the cold air from the freezer not getting into the refrigerator. There are several things that can cause this problem. The coils in the freezer icing up and not defrosting properly is one of the things that can cause the refrigerator not to get cold enough. Another problem is the fan that blows the cold air from the freezer compartment into the refrigerator, not working. When the compressor is running open the refrigerator's door and push the switch that makes the light go out. You should hear the fan blowing the cold air from the freezer into the refrigerator, when this switch is pushed in. If the fan is working then you will need to find what is blocking the air flow. Iced up coils are a common problem. The icing problem can be due to a defective defrost timer or something defective in the defrost circuit. Click here for more information. Check for these problems and let me know what you have found.
REFRIGERATOR TROUBLESHOOTING
#1 Refrigerator side getting warm Freezer still cold
Evaporator fan motor not running.
Defective defrost timer. See Defrost Diagnosis Procedure
Defrost heater defective. See Defrost Diagnosis Procedure
Defrost thermostat defective. See Defrost Diagnosis Procedure
Airflow blocked from freezer compartment.
Freezer control turned to "coldest" setting blocking air flow to refrigerator side. On most refrigerator/freezers, the freezer control closes a baffle when turned to coldest setting, and this blocks off the air flow to the fresh food compartment.
Fan blade broken.
Defective door switch on older models.
Light staying on with door closed.
2 Refrigerator & freezer compartments both are getting warm
Make sure refrigerator is plugged in and has power.
Condenser fan motor on bottom under refrigerator not running.
Condenser coil clogged.
Defective defrost heater. See Defrost Diagnosis Procedure
Defective defrost thermostat. See Defrost Diagnosis Procedure
Cold control defective.
Compressor overload defective.
Compressor relay defective.
Compressor defective.
Low on refrigerant. #3 Freezer compartment getting hot.
Defrost timer stuck in defrost cycle.(replace)
Defrost thermostat stuck.(replace)
Ice maker stuck in harvest cycle
Light staying on with door closed. 4 Ice maker not making ice
Defective inlet water valve.
Freezer temperature not cold enough. (see problem # 2 & 3 above)
Defective thermostat in ice maker.
Defective drive motor.
Water inlet tube clogged with ice.
Defective module in newer style icemaker. 5 Refrigerator sweating around door edges
Door gaskets leaking air.
Defective case heaters.
Energy saver switch not set to reduce exterior moisture
also if require more help click the link http://www.applianceaid.com/refrigerator.html please do rate the solution .thanks in advance.thank you for using fixya.
Mar 27, 2009 | Refrigerators
Freezer not freezing, refrigerator side not cold enough
sounds like compressor might not be running. pull unit out and remove bottom panel to access compressor area. beware of electrical wiring!!!! touch compressor to see if it warm. make sure fan motor by compressor is running.
May 07, 2017 | GE Refrigerators
Fridge not cooling enough
Check compressor if it is working fine then check temperature thermostat. If they both are good then either your fridge has ran out of gas or the doors are not closing properly.
Nov 09, 2017 | Refrigerators
GE GSS22JEPCC / GSS22JEPWW / GSS22JEPBB Side by Side Refrigerator Logo
326 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Ilia Bichin
