Question about Miele S514 Solaris Electro Plus Vacuum
No suction Hello - any help with this would be much appreciated! I just changed the bag and filters. The machine runs, seems normal, but there is no suction. There is no blockage of the hose, as indicated by the fact that that little viewer window above where the hose connects to the unit is not showing the red portion that it shows when there is something blocking the hose (god, this is hard to describe!). If I disconnect the hose and put my hand over the hole, I feel some suction. But if I connect the hose, I feel very little suction, and there is no indication of hose blockage. what the heck is going on???
    Sniper:
  • 84 Answers
Well, it actually sounds like there is a blockage. Try removing your hose and dropping something through it, like a quqrter. If it comes through, no clog. If it is clogged, I believe that machine has a blower on the upper part of the cleaner (maybe in the bag compartment towards the top. You can take out the filter holder and plug the hose in there and run the unit . Does the blockage come out? If not, Try shaking the hose, or you can put a stiff wire in it to try to free it. Do not run water through it. If there is no blockage at all, then you will probably need to take it to a service center. But I am pretty confident that we are looking at a clog situation. Let me know if this fixesya! Thanks, Rene (vacuum Doctor)
Posted on Nov 15, 2009
My machine has poor suction
When was last time you changed filter or bag or whatever as YOU did not mention make model or anything else that would let one help you
Jan 02, 2017 | Vacuums
My dyson dc 33 doesn't have any suction at the bottom. I washed the filters and checked the hoses. But I suspect it is because I can't get the hand wand to turn off. It runs whenever I turn on the
Hi there, it's Jack at Dyson.
I'm sorry to hear you're having difficulty with your DC33. When the vacuum is switched on and standing upright, suction will always be diverted automatically to the wand and hose for above-floor cleaning. When you recline the machine into the normal vacuuming position, the suction should be transferred to the cleaner head. Make sure the brush control is set to 'Carpets', as the brush bar will not rotate when it's set to the 'Hard Floors' position.
If it doesn't seem to be picking up as well as it should be, we'd appreciate the opportunity to talk you through some simple troubleshooting checks when you have your machine to hand. We'll be able to ensure everything is working correctly - and if a replacement part or repair is needed, we can also confirm if this is covered under your Dyson warranty.
You can reach us by calling 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU). We'll look forward to speaking with you.
Feb 11, 2015 | Dyson DC33 Bagged Upright Vacuum
NO SUCTION
You haven't given enough details of what machine you are asking about. Take it to your local vac shop for help.
Aug 08, 2017 | Dirt Devil SwivelGlide Bagged Upright...
MOTOR RUNS WITH NO VACUUM PRESSURE
Sounds like the belt should be replaced. It maybe turning the brush, but if you smell burning rubber, its slipping and not turning the brush with as much force as it should. Changed the belt. Check the air suction path. If the suction is reduced, something is blocking it. Check the bag (if it has one) and all filters. If the machine picks up any liquid, it will reduce the air flow through the filters and bag. Change the bag and filters. If this is an upright, you may find caked on dirt under or in the area of the brush.
Nov 28, 2011 | Hoover Vacuums
Loss of suction o=with hose tool
Hose or tool is probably clogged. Is this an upright? Bagged or bagless? Have you changed the bag and filters? Cleaned out the brush and hose that goes from the brush area to the collection bag/cup? The only reason for a vacuum cleaner to lose suction but still work is a clog or dirty filter which blocks the air flow. Follow the air flow from the brushes to the bag/dirt cup. If the machine is bagged, change the bag. I use another vacuum cleaner to do this.While your at it, might as well change the belt.
Nov 15, 2011 | Hoover Vacuums
Bag was not on good, resulted in dust,dirt, dog hair everywhere...have cleaned pretty thoroughly but vacuum does not have any suction. After taking apart did find that the larger wide belt is broke but I...
Greetings from GoVacuum,
There are two things that you should check on this vacuum after running it without a bag inside. The first thing you should check is the filter that is underneath of the vacuum bag. This filter is underneath of a bracket, and the bracket can be removed by pulling straight up on the bracket. The bracket and filter are directly below the vacuum bag inside the vacuum bag housing. If the machine was run without a bag (or the bag fell off) then this filter is most likely going to be extremely clogged. You can simly remove the filter, and run it under hot water until clean. Make sure the filter is 100% completely dry before putting it back in the vacuum and using it. Running the vacuum with a wet filter will destroy your motor.
Now in terms of the belts. Where as the belts don't directly control the suction of the vacuum cleaner, they certainly facilitate the pick up of dirt and debris on the floor. Many people assume that since the vacuum is not picking up from the floor, then the vacuum doesn't have suction. You can test this by pulling out the attachment hose and feeling for suction, is there suction at the end of the hose? If yes, then the reason the vacuum is not picking up on the floor is because of the belts. If you don't have suction at the end of the hose, then you have a clog, some where or a dirty filter.
The belts actually are what spin the brush, and the brush basically sweeps the carpet, and throws the dirt and debris into the suction port, and when the dirt and debris are near the suction port, the suction then takes over and takes it to the bag.
There are two belts on this model, it's best to replace both of these belts at the same time. If you replace just one, then the other belt will wear out quicker. It's always best to replace these two belts in conjunction.
The two belts that are used on this vacuum are:
Hoover Windtunnel V-Belt Part 38528034
Hoover Windtunnel Flat Belt, Hoover Part 38528035
Once you have the belts, and you're ready to replace them, here's a great video that we shot here at Govacuum.com that shows you exactly how to replace these belts, as well as some basic maintenance on your roller brush;
I really hope that my repair solution was helpful to you in fixing your vacuum cleaner. If you have any further questions about this repair, or any repair, feel free to contact me at chris.jones@govacuum.com, or request a clarification here on Fixya.
If you did find this repair solution helpful, please kindly rate this repair helpful by clicking the 4 Thumbs Up Icons in the top right hand corner of this solution.
Thank you very much,
Chris Jones
GoVacuum.com
Mar 19, 2010 | Hoover U6437-900 / U6439-900 Windtunnel...
My 4 yr old Nilfisk vacuum cleaner has been working fine up until now. But suddenly, it has hardly any suction power and also, hot air seems to be coming out thru the vents on top and also thru the space...
Hi there SmartAlec from Nelsonvacuums.com.au here.It sounds like a blockage of some kind. The best way to find it is to set the machine up for normal vacuuming and remove one component at a time until the suction returns. eg turn on and feel suction under floor head - not good? then remove the rod, then the hose.
Once at the machine on its own it gets a little triky as i don't know which model you have. However if you have a bagged model remove all the filters and the bag and retest. There will be at least 2 filters, one before the motor and one after (maybe under the vacuum or right at the back). If it is a bagless model even though the filter may look clean it is probably blocked with very fine dust. If suction returns when the filter is removed then you need to buy a new filter. I am a nilfisk vacuum cleaner agent so i can supply a filter for you.
If this still doesnt help you are welcome to call me if you live in australia my contact details are on my website www.nelsonvacuums.com.au.
Hope this helps !.
Happy vacuuming :)
Aug 23, 2009 | Vacuums
I have good suction at brush, but no suction in hose connection
i would change the bag and under the bag there is a filter, if dirty wash and make sure its completly dry before putting back into machine. once all done, have machine in upright position, turn on and see if there's sucktion at hose. hope this helps
Jul 25, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
No suction
1, Does the blower (discharge) side blow bunches of air??
Yes: Something is clogged from the bag to the hose end. Try blowing out the hose from the discharge side.
Or: The bag is not properly seated. Make sure that the plastic piece is properly inserted into the bag, and properly aligned and locked in place with the suction intake.
No: Something is wrong in the motor/fan assembly.
2: The hose has a plastic cover on the end farthest from the unit. Make sure that this cover is closed. If it is open, your suction will go way down.
Feb 23, 2008 | Kenmore 23313 Whispertone Bagged Canister...
Miele S514 Solaris Electro Plus Vacuum Logo
396 people viewed this question
Top Miele Vacuums Experts
Mack Baxter
Colin Stickland
Colin Stickland
Are you a Miele Vacuum Expert? Answer questions, earn points and help others
