Sining in to hotmail mensager
Hallo i am trayng to sin in to my mensager and its say that an herro has acord.and its says that i am not conect to the net mensager how can i resol this problem?
and i have windows xp and the mensanger dos not let me up dat to the new mensager.many thanks
  • Anonymous May 02, 2009
    i can sine in on hotmail
  • 2,427 Answers
In the messenger options / tools there is an option to diagnoise and solve problems, you can use that of you can diasble any firewall you have or open a port on the firewall for messenger
the first solution is recomended
Posted on Jan 09, 2008
How do I fix the sin on my calculator?
It depends on the unit of measurement. The sine of one radian is about 0.84. The sine of one degree is about 0.017. The sine of one grad is about 0.015. From your numbers it looks like your calculator is set to grads when you want it to be in radians (and are you sure you want a negative number for the sine of one?).
Press the DRG key to cycle through the angular modes. One of the annunciators at the top of the display will light to indicate the current mode.
Jan 31, 2014 | Sharp el-531x scientific calculator
My TI-30XB WONT CALCULATE INVERSE COS OR INVERSE SIN
Does it refuse to do so or does it give an error message?
Three common errors:
  1. Not having the correct angle unit. Wrong result, No error message
  2. Confusing reciprocal of sine (1/sin(x) with arc sine (x) ,sin^-1(x). Confusing the reciprocal of cosine, 1/cos(x) with arc cosine (cos^-1(x)). Wrong result, No error message
  3. Taking the argument of the inverse sine and/or inverse cosine functions outside the interval [-1,1]. This gives a domain error.
Oct 28, 2013 | Texas Instruments TI-81 Calculator
I get err:domain on my TI-84 plus when i do Sin -1 (60) why?
While the domain of the sine function is the whole of the real line, it range spans the interval [-1,1]. In other words the sine of an arbitrary angle is imperatively somewhere in the closed interval [-1,1].
So when you want to find the arc sine corresponding to a given value of a sine function, you cannot give as argument to the arc sine [sin^-1] a value that lies outside the interval [-1,1].
For your case, the argument is 60 and it is outside the permitted domain [-1,1]. That is why the calculator protests by signaling a domain error.
Oct 28, 2010 | Texas Instruments TI-84 Plus Calculator
Why limit of sin x is 1, when x tends to 0 ?
Sin 0 = 0
Sin 90 = 1
Sin 180 = 0
Sin 270 = -1
Sin 360 = Sin 0 = 0
Is there an angle greater than 360???
Is there any greater value of Sine than 1 ???
Aug 11, 2010 | Pyramid Calculus WIZ 2.0 (cp11395) for PC,...
Find csc(-330°) to the nearest hundredth
The cosecant function does not have a specific key on any calculator because it can be easily calculated as the reciprocal of sine.
Thus csc(-330°)=1/sin(-330°)=2
sin(-330°)=sin(360°-330°)=sin(30°)=0.5
csc(-330°)=1/0.5=2
If you do not want to be bothered with these facts, just calculate the sine of -330° and take the reciprocal of the result using the [x^-1] key. For the minus sign before 330, use the change sign key (-). Close the right parenthesis.
[SIN] [(-)] 330 [)] [x^-1]
Jan 21, 2010 | Texas Instruments TI-30 XIIS Calculator
How to use the SIN botton EX: 25 x SIN(65)
Before starting to enter the angle measure to calculate the value of a trigonometric function (sine, cosine, tangent) you must make sure that the current angle unit (degree, radian, grad) the calculator is configured to be using is the same that your problem requires. For instance, if you are solving a problem in which the angles are given in degrees you must verify that the calculator is configured to work in degrees.
When calculator is turned on, the angle unit is reset to degrees, but just to make sure it still is, look at the display: It should show the indicator DEG. If the display indicator is not DEG press the key [DRG] once or twice until you see the DEG on the screen.
The angle unit being taken care of, we turn to the actual calculation
Usually, to calculate the sine of an angle, you enter the angle value, press the [SIN] key and hit [=]. As you can see the sine function eats the number stored in its current register and calculates its sine.
To make sure that the calculator is taking the sine of 65 and not of 25*65, I would enter the calculation as follows
[65 [SIN] [*] 25 [=] : the result should be 22.65769468
or
25[*][ ( ] 65 [SIN] [ ) ] [=]
In the last key sequence, the use of parentheses forces the calculator to pause all previous calculations and wait for the closing right parenthesis. When the right parenthesis is entered, the calculator takes care of the contents of the parentheses first, then resumes the operations entered before the parentheses.
Importance of checking the angle unit before a calculation
Let us perform the calculation with angle unit
  1. in degrees : 25* sin(65) = 22.65769468
  2. in radians : 25 *sin(65) = 20.67071699
As you can see, the two values are not very far apart and since you are expecting a value that does not exceed 25 you might want to check your result.
Hope it helps.
Thank you for rating this solution
Dec 12, 2009 | Texas Instruments TI-30XA Calculator
When I'm adding component vectors, how do I get the number for 20SIN170(degrees)?
If the default angle unit is not degree, you must set it to degree by pressing the [DRG] key. Once this is done you type
170 [SIN] [ * ]20 [ENTER]
If it feels awkward to enter the command this way you must insert parentheses to make sure calculator is evaluating the sine of 170 , not the sine of 20*170
20 [*] [( ] 170 [SIN] [)] [ENTER]
Notice that the parentheses enclose 170 [SIN]. The sine of 170 will be computed first, then the result is multiplied by 20.
Hope it helps.
Thank you for rating this solution.
Dec 11, 2009 | Texas Instruments TI-30XA Calculator
Im not sure how to put the formula 4 sin squared x 60 into my casio fx-83wa calculator it keeps saying syn error please help
You should know that you cannot enter something like sin^2(x) as you would by hand. So you must use parentheses: ( sin(x) )^2. If you do that there is no ambiguity. The calculator evaluates the sine because parentheses are evaluated first, then it takes the square.
So 4[x][(] [SIN][(] 60 [)] [)] [Xto the 2] [=] result is 3/
Since you do not say what model you use, what I entered may not be appropriate: the parentheses inside the sine function may not be needed. In the new Casio the first parenthesis inside the sine is supplied by calculator, but the closing one must be entered by the user.
Hope it helps
Sep 17, 2009 | Casio Office Equipment & Supplies
Trigonometric functions
Put the calculator in radian mode. Find the sine of the angle (sin(angle)), invert the result (1/x or x^(-1)). csc = 1 / sin
Jan 27, 2007 | Texas Instruments TI-86 Calculator
Computers & Internet Logo
6,106 people viewed this question
David Payne
David Payne
