Question about HP LaserJet 1020 Printer
My daughter ran a sticky piece of paper through the printer and now everytime we try to print something in color it looks blurry. What can I do to fix it?
  • Laxman Bisht
    Laxman Bisht May 11, 2010
    It is possible that there might be something(like glue) stuck on the drum which is not letting the print come out clearly on that particular part. You need to remove the printer cartridge. Remove the Drum and then clean the drum with a soft cloth. If should be working fine. Make sure you re-seat all the parts as they were before or else you might end up with a non-working printer. Your comments and ratings are highly appreciated. If you find this solution helpful please do not forget to rate it. Thankyou for choosing Fixya.
  • 38 Answers
You need to find out where the sticky deposited and let me know. could have went on the drum for the toner or the fuser most likely. Do not touch if hot.
Posted on Nov 16, 2009
MFC 240C print quality is excellent but prints crooked on page. Ran alignment multiple times, no help.
When the paper does not feed straight, dirty or sticky rollers can cause it to jamb or crinkle, also failure to remove all traces of paper from a previous paper jamb will cause further paper jambs.
Check for tiny pieces of at the edges of the rollers, and remove these pieces of paper. The rollers may be dirty or sticky and causes the paper to not feed straight.
Try cleaning the rollers with methylated spirits.
Mar 30, 2013 | Brother Multi-Function Center MFC-240C...
I have to click the go button everytime i print a smaller piece of paper
Paper size mismatch. Printer menu(printer front panel/paper size) select any size as well as in system printer properties select any size to over come from this issue..
May 30, 2012 | HP Color LaserJet 2600n Printer
My hp t65 will not print in color. I've changed
Make sure you removed the sticky piece of tape that covers the print nozzles on a new cartridge.
Sep 17, 2009 | HP OfficeJet t65 All-In-One InkJet Printer
Paper jam(Canon BJC 3000)
Try to open the printer cover and look for tiny paper shreds that might got stuck between the rollers. Also if your printer has a sensor, there could also be a tiny piece of paper blocking it, thus sensing a paper jam.
Aug 31, 2009 | Canon BJC 3000 InkJet Printer
Can't print in black ink.
Wipe the cartridge of cotton,don't use water.Make sure the black is not empty.
May 19, 2009 | HP PSC 2175 All-In-One InkJet Printer
Paper is getting jammed hence not printing
Sounds like somthing is caught in the left hand side try looking in it with a flashlight and see if you can see somthing stuck like a twistie tie/sticky label/ staple / sticky tape.... If its in far try using a ruler or a few pieces of paper stacked together to dislodge it.
May 06, 2009 | Lexmark Z2420 Printer
KL-3015 paper jam at lower paper tray
Hi, the roller is available from this link. http://www.precisionroller.com/search.php?add2cart=19976
Nov 04, 2008 | Konica KL-3015 Laser Printer
Line down the right stide in the megenta area of the self test and blurrred print on the right side
Step1
If you're setting up the printer or changing the toner or ink cartridge for the first time, double-check the instructions to make sure that you installed the cartridge correctly and, for new printers, that you have removed all the pieces of cardboard or plastic packing material.
Step
Check to see whether paper is feeding from the paper tray. If it's not leaving the tray at all, try feeding a page manually (if that's an option) or using a different paper tray. Sometimes a problem with the tray can be traced to a broken spring or a piece of plastic.
Step
If paper is feeding from the tray but jamming in the printer, examine where the jam is occurring and then inspect the printer carefully to see if you can find what is causing the problem. A piece of paper, for instance, might be blocking the paper path.
Step
If paper is feeding through the printer but coming out blank, check to see whether the printer is out of toner or ink. A defective toner or ink cartridge could be the problem.
Oct 31, 2008 | HP PSC 2175 All-In-One InkJet Printer
Printer is printing blurry
Clean or replace the ink cartridges and select a better print quality from the front panel of the printer.
Jan 03, 2008 | HP Photosmart 2710 All-In-One InkJet...
Sticky photo printing and poor quality
GO IN TO PRINTING PREFERENCES on computer AND CHANGE SETTINGS TO MATCH THE KIND OF PAPER YOU ARE USING OR CHANGE PRINTING PREFERENCES TO PHOTO WHEN PRINTING PHOTOS
Sep 10, 2007 | Dell 924 All-in-One InkJet Printer
HP LaserJet 1020 Printer Logo
59 people viewed this question
Seeker5211
Seeker5211
