Question about Sony RDR-HX725 DVD Recorder/HDD Recorder
Hdd error Dvd powers up "welcome" message shows for couple minutes then...... HDD Error appears and machine locks up. Any suggestions grateful as warranty has run out!
  • DarrenR Jan 27, 2008
    I have exactly the same problem. Switch on - message starts up with Welcome message then Load, takes about five minutes and then a message HDD Error appears. You can do aboultely nothing, no buttons work, just stuck on this command.
    When error first occurred I switched machine on / off and managed to restore it and it worked fine, the disk had about 30gb of space left. A daylater problem occurred again. Seems to be some start up problem. I believe the data is still intact.
  • 99 Answers
Try replacing the red sata cable which runs from the HDD under the DVD drive to the main board on the right-hand side. these are a common problem on these models, there cheap and unreliable. you can purchase a better quality cable from a computer store for little money. HDD ERROR is'nt necessery an HDD fault as i found out with my rdr-hx525. if however the HDD is faulty and you buy a replacement, once installed you will need to pair the new HDD with the unit by entering the service mode by unplugging the AC then while holding down open/close and play together then re-insert the AC lead while still holding open/close and play and wait until you see an "S" in the display then let go and the service mode will appear on the tv screen. go to no.9 HDD mode, press enter then go to no.3 Write ID then it will say "execute write ID?" yes and press enter and then it will say "writing HDD serial ID.... OK" once this is done, exit the service mode by keeping your finger on the power button for approx 10secs. your DVD recorder should now recognise the new HDD. if you don't follow this process, you will still have an HDD error message as your DVD recorder will have your old HDD installed and won't recognise your new one. given the amount of time since you posted this fault, you may still have the unit in question in which case i hope this solution is helpful, or for anyone else with the same problem.
Posted on Nov 24, 2008
    New Friend:
How much time needed for the hdd error fixing ?
Posted on Jan 23, 2013
  • blintiminti
    blintiminti Jan 23, 2013
    how much time needed for the hdd error fixing ?
My Sony rdr hx725 shows only 'welcome' on the screen when I start it, but for the rest it is dead. As the guarantee has been expired, I desperately need a solution. Who can help!
Posted on Jun 27, 2010
  • dido41987 Sep 15, 2010
    Date Ref. No. Model
    22.01.09 09HV002 RDR-GX120, RDR-GX220, RDR-GX330, RDR-GXD360, RDR-HX520,
    RDR-HX525, RDR-HX720, RDR-HX722, RDR-HX725, RDR-HX727,
    RDR-HX730, RDR-HX920, RDR-HX925, RDR-HXD560, RDR-HXD760
    Set Freezes after “WELCOME” Message on FL Display
    The set may freeze after “WELCOME” appears on the FL display, and may refuse to power on.
    This symptom is very similar to the SATA cable issue described in Technical Bulletin 06HV027, but must not be
    confused with it. Therefore, make sure to check the procedure below BEFORE applying TB 06HV027.
    Voltage output of the DC-DC converter IC is not correctly stabilized.
    Replace IC601 on the bottom of the logic card (RD-060) with an MP2105DJ-LF-Z, needs solder for SMD, or a very small one.
This is what ive done, put the ac cable out then reconnect, when ur see welcome in the display, quickly press ''eject and play'' and hold them till u herd the hard sound of the van, then release the buttons and wait till the number 5 is on the display, u should see a menu screen like a bios, press 9, 1 time then press 4 to format, if it shows NG, then return and press 5, its called '' Format Check'' , if this doesnt work either then ur hard drive is broken, if it works with format u should wait couple minutes, if it works with format check u should wait 10 minutes, when its done press return and unplugg the ac cable, i hope this information is useful good luck
Posted on Jul 08, 2008
My 725 completely locked up and the only cure was to leave it overnight unplugged.Plug it back in next day and all is well.See buzzbomb5 posting.On one of Sony's web pages it made reference to the noise this machine makes in standby,and suggested turning off the auto clock.I have since done this and would you believe it, no problem for over a week now.Perhaps someone from Sony can suggest if this is the cure for the problem,and, if there is a fix, so i can use auto clock again.
Posted on Feb 03, 2008
HL-L8350CDW series Unable to print 0A. How do I fix this?
"Print Unable 0A" indicates that a hardware malfunction has occurred.
- If the error message is "Print Unable ZC", refer to: "Print Unable ZC"
1. Power the machine off by holding down the power button. Wait a few seconds and then power the machine back on.
-If no error message appears on your machine's display, go to Step 2.
- If the error changed to "Self-Diagnostic" on your machine's display, contact brother for warranty service.
-If "Print Unable 0A" returns, contact brother for warranty service.
2. Leave the machine with power ON for 15 minutes.
- If "Self-Diagnostic" or "Print Unable 0A" returns, contact brother for warranty service..
Brother Authorized Service Center locator
Jan 12, 2018 | Office Equipment & Supplies
Hp colpr laser jet 2840 machin showing error 3 .what is a problem
Welcome to Fixya Support
I am Michelle, and i will be assisting you regarding the issue
please take out the print cartridge
wait for the insert cartridge message to appear
unplug the power cord
wait for 2-3 minutes
plug the power cord back in
turn the unit on and reinsert the cartridiges
check for functionality
Nov 21, 2010 | HP LaserJet 2840 All-In-One Printer
I just bought an IBM Thinkpad r31 for my kids, that may have a connection problem, or it may be with the HDD or controller. It comes on intermittently, and when it boots, may only stay on for a few minutes...
It's the HDD, its spin-up time (the time it takes the motor on the platters to reach normal operating rpms)  is too great so the system can't decide if it's a hard or soft problem so it freezes.
Nothing more you can do, replace it.
Jul 07, 2010 | IBM ThinkPad R31 2656 Notebook
DVD player locked on "welcome" wont respond to any buttons
The dvd player appears to be unable to start up, unplug the machine and plug it back in after a minute, try again, if the unit still fails to start up, its probably a hardware issue.
A Firmware disc might help, or it might not if the player is unable to read it.
You should take this to your dealer for warranty repair or take it to a local repairer, or buy a new one, they don't cost much.
you can also try unplugging it for a longer perioid.
Sep 10, 2009 | Sony RDR-GX300 DVD Recorder
Dvd not playing
Welcome to Fixya! Have you tried the Cleaning Disk that you can get at Most Radio Shacks???? Works really good on mine whenever it does this!
Jan 18, 2009 | Sansui VRDVD4005 DVD Player/VCR
Dvd frozen
any storms around? sounds like a power spike tanked it
Jul 26, 2017 | Sony RDR-HX727 160Gb DVD Recorder / HDD...
Cannot start dubbing
I'd guess you are using cable TV-some cable companies put their own copyguard on the cable signal, Comcast, in my area does this. The DVD sees the 'do not copy signal' and won't do it.
Try recording directly to DVD without using the HDD drive. If you get a playable disk, I doubt it is your machine. If you don't get a playable disk, that plays in THAT machine-it is the machine..
Jun 07, 2008 | Televison & Video
Pioneer DVR-540HX DVD recorder Error message 'REPAIRING HDD'
Greeting, I have same problem too, and now recorder is in warranty service. HDD sucks. This recorder is piece of ****. HHD is noisy and poor quality.
Stay in peace
Nov 17, 2007 | Pioneer DVR-540HX DVD Recorder/HDD...
LG RH177 Recording
once you have set timer record, you must then put machine in standby mode,once in standby mode you will have a little timer display in panel,should then come on when time to record
Aug 13, 2007 | LG RH177 DVD Recorder/HDD Recorder
Sony RDR-HX725 DVD Recorder/HDD Recorder Logo
4,173 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
