Question about Hampton Bay 54 In. Flemish Pewter Ceiling Fan with Heater
Fan Problem We went to turn off our fan one night with the remote and all it would do is dim the lights not turn it off when we hit the off button. When we first turned it on that night one of the lights on the fan went out, would that have anything to do with it? Please help, thank you.
Sometimes a remote draws moisture either from the air or someone spilling a drink on it. i'm not saying this is the problem but it's worth a shot. take apart your remote. don't worry, remotes are usually the shell, rubber buttons, and the little green board. not much to lose and easy to put back together. take a dry cloth and wipe off the green plate front and back. try not to touch it but on the sides. replace it back together and try it out.
Posted on Jan 12, 2008
My light on my ceilinf fan will only stay on dim.. What can I do to fix it.. It only operates bt remote
if fault is not on remote , you may need to bring down the ceiling fan and check on stuck electrical contacts and sensors to fix the problem.
Dec 28, 2013 | Hampton Bay Indoor Ceiling Fans and Light:...
My Harbor Breeze remote control fan no longer responds to my remote controller. The first sign of problems was when the lights began flickering momentarily when I tried to dim them. Then the lights went...
this black box is a watt governor for the lights. just remove it, and wire direct. then you should be fine, just let me know the outcome!! the box should have vent slots in it. part # for hunter fan. i do not know if its the same as harbor breeze. --- part # 98480-02, this is what makes lights flicker. if need be replace remote. go to www.harborfans.com and click on support to find phone number for assistance. have a good day !!
Dec 15, 2010 | Dryers
We just moved into this house and there is a hunter ceiling fan in our bedroom. The 1st night we tried to dim the lights so I could sleep but now the lights refuse to turn off. If you press the button on...
it sounds like the receiver control (located within the fan unit) is faulty. This is a small electronic control module that receives the signle from the remote control transmitter. The receiver can be accessed by removing the light mounting plate that holds the light to the body of the fan. OF COURSE IT DEPENDS ON THE MODEL FAN THAT YOU HAVE, HOWYOU EXACTLY MUST ACCESS THIS RECEIVER CONTOL. I suggest you call the manufacture and explain the situation; they can confirm my suspicion and give you any further thoughts to be sure of the problem, as well as send you a replacement part.
Aug 10, 2010 | Hunter Dryers
I have a Hunter fan with remote. The fan or the light comes on by itself with no one around
See my post below: (Sorry, we're in the same boat)
Hunter ceiling fan with remote, have 5, 4 are seriously impaired! Lights dim to half strengh after variable time 10 seconds-30 minutes. And lights or fan turns on randomly (come home & fan on full blast), and one in which the lights won't dim (just blinks when try to dim)! Hunter "kinda" admits there is serious problem with remote but doesn't have a solution. Tells people to try changing to different code due to possible interference (pain in **** to change code on ceiling base!), was totally ineffective. Then replaced receiver in ceiling base (another total pain) in 3 fans with new ones sent Hunter, still totally useless. Hunter's suggestion, don't use the remote, just use the pull chain. If I had wanted a pull chain fan, I'd have bought a pull chain fan. TOTALLY USELESS! Moral of story: If you want a remote ceiling fan (my friend found out that all their remotes are made by the same company in Taiwan), don't buy Hunter!!!!! P.S. I found a "Kinda"- fix for the lights dimming to half strenth. After turning on the lights, wait 1 second, then dim lights slightly, they will then stay on the strength that you dim them to. - P.P.S. When I changed the receiver in the one where the lights won't dim, it "solved" that problem...Now it has the same problem as the others, lights or fan turn on randomly!
Apr 02, 2010 | Hunter 52" Ceiling Fan With Light And...
I think our house is haunted. Just installed
See my post below: (Sorry, we're in the same boat!) Hunter ceiling fan with remote, have 5, 4 are seriously impaired! Lights dim to half strengh after variable time 10 seconds-30 minutes. And lights or fan turns on randomly (come home & fan on full blast), and one in which the lights won't dim (just blinks when try to dim)! Hunter "kinda" admits there is serious problem with remote but doesn't have a solution. Tells people to try changing to different code/channel on the remote due to possible interference (pain in **** to change code on ceiling base!), was totally ineffective. Then replaced receiver in ceiling base (another total pain) in 3 fans with new ones sent Hunter, still totally useless. Hunter's suggestion, don't use the remote, just use the pull chain. If I had wanted a pull chain fan, I'd have bought a pull chain fan. TOTALLY USELESS! Moral of story: If you want a remote ceiling fan (my friend found out that all their remotes are made by the same company in Taiwan), don't buy Hunter!!!!!
- P.S. I found a "Kinda"- fix for the lights dimming to half strenth. After turning on the lights, wait 1 second, then dim lights slightly, they will then stay on the strength that you dim them to. - P.P.S. When I changed the receiver in the one where the lights won't dim, it "solved" that problem...Now it has the same problem as the others, lights or fan turn on randomly!
Mar 20, 2010 | Hunter 52" Ceiling Fan With Light And...
Light dims but won't turn off with remote
I am affraid that there is not an economical solution for your fan. Afterf four years you probably have a dust build up on circuitry causing a short and excess heat. If you have a source of compressed air for instance an air compressor or a keyboard cleaned you can try blowing out the inner components of the fan. Good luck.
Jul 04, 2009 | Hunter 52" Ceiling Fan With Light And...
Remote wont' work after changing battery
Seem like you have a bad lectronic control circuit in that fan.
Jun 29, 2009 | Oasis Hunter 54' Ceiling Fan
Fan and dimmer remote does not work
The remote is a Hampton Bay remote that should dim the light and fan on and off. I replaced the battery and do not have a red light when I press the button. Light and fan does not turn off with remote.
Mar 01, 2009 | Universal Remote Control Hampton Bay...
Possible remote control problem
Have you tried holding the dimmer switch for 16 to 20 seconds?
Oct 21, 2007 | Hunter 20531 Vista Brushed Nickel Ceiling...
Hampton Bay 54 In. Flemish Pewter Ceiling Fan with Heater Logo
43 people viewed this question
Top Hampton Bay Dryers Experts
Steve
Craig Butler
Craig Butler
Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
