Question about Sony Cameras
Dropped sony camera randomly turns on batery is
My daughter dropped her camera - we tried to charge the battery but the camera randomly turns on and off - camera dept at store said that if camera is dropped it will no longer work - any help??thanks
    President:
  • 2,761 Answers
The drop likely damaged the lens tube (housing) or jarred the zoom mechanism off of its track. Either condition causes the camera to shut down to prevent further damage. There is no safe DIY fix, but the camera can be professionally repaired. Contact Sony through their web site or visit a local camera shop (not the department store) and get a repair estimate -- you will need to decide if the camera is worth the cost of the repair.
Posted on Nov 15, 2009
Why doesn't it recognize the correct battery?
hi,
If your camera do not recognize the original battery, it means some wrong information is stored in its software data, to override this please open the camera take out the small memory backup lithium battery, short the battery contact , after a five minutes connect that battery again.
Mar 02, 2016 | Sony Video Cameras
It will not turn on// green light flashes then goes out.
You have a problem with the CCD circuitry, and this will require a service, not something we can do on this forum, unfortunately..
Jun 28, 2008 | Sony Mavica MVC-FD200 Digital Camera
The camera wont turn on.
Appears that your battery has gone to battery heaven - replace it.
May 08, 2017 | Sony Cyber-shot DSC-W30 Digital Camera
I have sony cybershot dsc 10 digital camera but it dsn't power on batery charge is full
Please make sure that the Battery in the Camera is fully charged.
Please check if the issue is with the battery charger. Make sure that the Charge Lamp in the Battery Charger is lit when connected to the Wall outlet.
You can try recharging the battery pack for almost 6 hours as initial charging.
If you've another battery pack, try using the same to check if the issue is with the Camera or with the battery.
You can also try turning on the Camera by connecting the optional ACL-S5K AC Adapter. This Adapter can be used for turning on the Camera, it cannot be used to charge the battery pack. For charging the battery in the Camera, the supplied battery charged needs to be used.
If the Camera is not turning on using both the AC Adapter and new battery, then the Camera may require service.
Thanks for using FixYa.
Jan 10, 2011 | Sony Cyber-shot DSC-H10 Digital Camera
I have sony digital camara but it dsn't power on batery charge is full
Jan 10, 2011 | Sony Cyber-shot DSC-H10/B Digital Camera
Hi my battery won't charge on my Sony Mavica...daughter dropped it about 2 feet onto carpet...charge light is flashing
the charge light flashing means the battery is damaged or very dead .. some charger will not initiate charging if the voltage gets too low ..thats a safety feature ... if those are the original batteries then they are past due for replacement anyhow ..
Jan 19, 2010 | Sony Mavica MVC-CD500 Digital Camera
Lens stuck in the out position. Have switched off, taken out batteries, tried again...
The lens has probably got something in the retraction mechanism that is stopping it retracting. This can be something as simple as sand or grit or as a result of a drop or knock. In most cases the camera will need to be stripped apart to remove the lens assy before it can be repaired. This is best left to a professional camera repair shop.
Nov 05, 2009 | Sony Cyber-Shot DSC-P200 Digital Camera
MY DAUGHTER'S SONY DSC-W55 CYBER-SHOT WILL NOT TURN ON
It seems bad. Usually problem with PCB. Ask your daughter if there was possibility to get even drop of water (rain, drink...) inside - in that case you should let the camera dry, but your chance is not big. I´d like I was wrong...
Sep 18, 2009 | Sony Cyber-shot DSC-W55 Digital Camera
Cannot turn on my Kodak easyshare c713
Hi I had the same problem with my daughters c713. Tried several bateries found out that the camera is specific with its bateries brand. When i put in new ones from kodak itself from my sons camera a c913 the c713 turn on again. Tried a new pack local brand checked them first and voltage was ok but didn´t work again. Back in those from kodak and ok again. Tried philips also ok.
So try different brand and find out. Good luck.
Jaap Davids The Netherlands
Jun 17, 2009 | Kodak EasyShare C713 Digital Camera
No Power
Try to replace the batery or take out the battery.
Jul 23, 2007 | Sony Cyber-Shot DSC-P7 Digital Camera
Cameras Logo
248 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
