Question about RIM Blackberry 8310 8320 8330 Curve 8100 8110 8120 8130 Pearl Car Charger / Veh
How can you purchase a car charger for usual car. My bigger problem is I apparently put to many items 0n my card and in the interior memory. I download and insult just about everybody. I want to be able to especially for you you, trying to solve it myself is entirely too confusing.
  • 350 Answers
What is you question exactly?
Posted on Nov 14, 2009
My cigarette lighter keeps blowing out the fuse fir it I've put in a 20amp n that blew out when I plugged in the charger n put a 30 amp that work for a couple hours n put the charger back again in it...
Never put in a bigger fuse than what it calls for. You must have a bad socket that is shorting out or the item you are plugging in is shorting it out.
Aug 03, 2011 | Chrysler Sebring Cars & Trucks
I just purchased 2 new sdhc class 6 cards from ebay. I put them into my jvc everio camcorder and it says "memory card error". Do I have to format them, or are they bum cards? Thanks
I doubt there is anything wrong with the cards. Cards usually come pre-formatted, but you could try formatting them and see if it makes a difference.
However, I expect that your problem is down to compatibility. Many cameras, especially those that are a couple of years old, won't work with SDHC (high capacity) cards. SD and SDHC cards fit the same slots, but they are slightly different. SDHC is not backwards compatible. Unless your camera's manual specifically mentions that you can use SDHC cards, you probably can't. I believe the largest capacity SD card is 2GB. Anything bigger will be SDHC.
Dec 24, 2010 | Cameras
Have very small internal memory.
Hi, Does your phone have an external memory slot? if yes you can get an external memory card to store more items on your phone.
But if it doesn't, that means the phone you are using doesn't have enough place to collect or store items.
Just an advice,You can get another phone with bigger memory size.
Have a nice day.
Sep 12, 2010 | LG KG290 Cellular Phone
After sitting for a few days the car needs to be jumped
Charge the battery with a battery charger and have it load tested. If it shows good after testing, you have a power draw in the system somewhere.
Check obvious items such as interior lights or glove box light staying on, then put an ammeter between either of the battery leads and the battery and pull fuses one by one till the draw disappears or diminishes substantially. That will be the circuit that serves whatever item is giving you the problem, then you need to do some tracing to check exactly which item is causing the draw.(while testing, keep in mind that if the door is open it will draw for interior lighting)
Also check alternator output... an alternator that is under-charging can also draw power with the engine off....usually caused by a bad bridge rectifier inside the unit (get a rebuilt one).
May 20, 2010 | 2000 Jeep Grand Cherokee
How can i download from pc to mobilephone
You have a few options;
  1. Purchase a USB Data Cable and download Nokia PC Suite from Nokia website. You can then transfer items from your PC to Phone and vice versa using the Data Cable.
  2. Purchase a USB Bluetooth dongle and downbload Nokia PC Suite from the Nokia website. You can then transfer items from your PC to Phone and vice versa using the Blutooth.
  3. Purchase a Memory Card Reader and simply drag and drop items onto the memory card using your PC, then put the memory card back in the phone.
May 21, 2010 | Nokia 6500 Slide Cellular Phone
I purchased an SD card for my LG 8500 Chocolate Touch and put music on it, but when I put it in my phone it says it's adding music but it doesn't!! What am I doing wrong?
You must Format the card 1st. Take the card out, slide it into the larger SD card it came with and install that into your slot in your PC (if you do not have a Mini SD slot, then maybe your camera or a friend does). You will have to delete everything on the card, then FORMAT the card, slide it out of its holder, reinstall it, turn on the phone on, now you are ready to open 2 Windows Explorer windows of the same size- then Drag-N-Drop... or, use a program that came with the phone, if you're lucky enough to have received one. I have the blackBerry TOUR and it didn't come with an application like that, so I drag and drop. I do have 2 Creative Muvo Brand mp3 Players which are 4 yrs. old and they came with a cool Application, each- but this $400 BlackBerry did not. Good luck and I hope YOU have a Card reader in your PC. If not, go online to your Favorite PC/High-End electronics website and find one which will fit in one of your 'open' 3.5" slots (Floppy Drive size- usually have 2 per PC face...?) and it will install to an open USB link on your motherboard (unplug the PC before taking off the side panel or outer cover of your PC and definitly before attaching the USB link. You may have to link a Molex power connector to the back of the Memory Box, also. If you do not have a 3.5" or a 5.75" slot open for an Interior Installation (the 5-3/4" bay will need a compatible 5-3/4" to 3-1/2" bay faceplate to install in the larger bay- which MIGHT come with the Memory Reader itself) then try to find an external USB Memory Reader. It may be a little more expensive, but it is a 1 link connection. I hope you get what you are looking for.
Jan 03, 2010 | LG Chocolate / 8500 Cell Phone Car Charger...
Recently purchased Sony Cybershot DSCW180. Took 3
Yes, you need to have memory stick because camera has limited internal memory that can store few pictures only.
Put new memory card, format it through camera Menu and copy internal memory pictures to memory stick, take our memory card from camera and delete internal memory pictures either one by one or format internal memory through camera Menu.
Thanks.
Dec 02, 2009 | Sony Cybershot DSC-S950 Digital Camera
RIM Blackberry 8310 8320 8330 Curve 8100 8110 8120 8130 Pearl Car Charger / Veh Logo
Top RIM Cell Phones Experts
Computer Repairing
Computer Repairing
Longtime User
Jason
Are you a RIM Cell Phone Expert? Answer questions, earn points and help others
