Question about Audiovox 8912 Cellular Phone
Charge point location - Audiovox 8912 Cellular Phone
CHARGING POINT KAHA HAI
lava model no-ARC1 there is only one charging point so you have to fix your charging point and charge you phone again
May 17, 2017 | Cell Phones
New battery and alternator still will not charge battery
its probably the fuse link located on the positive cable. that would explain the no charge condition. also check battery terminals for cleanliness. the fuse link is a weak point designed into the charging system so in the case of a power spike, the fuse blows out instead of an expensive electrical component. it may be in a fuse box for that matter.
Nov 14, 2013 | 2002 Mercury Sable
Should 1975 lb chappy have juice in points when
Hi, in short you should have no power or juice as you explained at the points ifthey are located inside the flywheel, the power is made when the engine is rotated as the magnetic field and the low tension coil located inside the flywheel create the low voltage, for the ignition coil, if this is the 70cc with flywheel magneto, it will run without the battery connected, on some of the older models, the dc (direct current) wire from the rectifier connected into the red positive battery wire to charge the battery
Aug 03, 2011 | 2005 Yamaha PW 50
My daughter has a nuvi350. She used it to get to a location away from home and now it will only show that as her starting location, We have deleted all locations and the unit shows the same coor. wherever...
I am not entirely clear of what your problem is. But i assume you have set your home location, hece that is why the map always uses that reference to start from.
If it doesa not advance beyond that point when travelling to a new address i can only assume you have no satellite connection.
This is caused by a few things, but the main one is battery level. Make sure its fully charged.
second point is you do not have a clear sky view.
3rd point is you have blown the SIIRF chip lets hope its one of the two minor ones I mentioned
Jun 19, 2009 | Garmin Nuvi 660 GPS Receiver
USB charge point location
YOu need to purchase and install the ACM (audio connectivity module).
If you're in the US I know where to get the ACM. I have the instructions for the ACM install if you're interested. First you will have to spend money on the
ACM - about 300 dollars....
Feb 16, 2009 | 2002 Jaguar X-Type
Air con needs charging on s type 4. litre 2001
The low side adapter is located on the top of the a/c compressor, and the high side is located on the drier. Let me know if this info helps.
Aug 20, 2008 | 2003 Jaguar S-Type
1100
This problem of yours is charging IC is defected already change it with identical rating..
hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE;
Jul 30, 2008 | Nokia 1100
Freon is low on my 1994 Nissan Maxima
You will have to have AC leak detector dye installed, system charged and then driven until it is low on charge again, and then location of leak pin-pointed with a black light, there are electronic leak detectors but the dye method is the best and most accurate.
Jul 28, 2008 | Nissan Maxima Cars & Trucks
Audiovox 8912 Cellular Phone Logo
22 people viewed this question
Top Audiovox Cell Phones Experts
Spud Howell
John Porter
Are you an Audiovox Cell Phone Expert? Answer questions, earn points and help others
