Change language While setting up an lexmark x4850 printer, i touched the "right" and "left" arrow and watched the language change on the small screen. I then touched the "check" in the center and the "chinese" was set. Now i can't change it back to english. help!
  • eddie3 Jan 09, 2008
    That fixed the problem. Thank you, thank you, thank you
  • Anonymous Aug 28, 2008
    I inadvertantly pressed the check "save" button on French instructions while scrolling for English in installing my Lexmark X4850. I then backed out of the installation process -- removing the disc of instructions, shutting down the computer and unplugging the Lexmark, as I couldn't figure out how to get the instruction window to read in English. Now, I need to "unsave" the French so I can get English on the screen, and start over again installing with the disc instructions. I have Vista on my Dell Computer. Thanks. AG
  • 589 Answers
Here ya go:
What you will see
The printer display is not in the required language.
What to do
To change the language on the display back to the required language, do the following:
Steps Action 1 Power the printer off and back on. 2 Press the down arrow button (change language - pattlnk_1012007_1117-downarrow.gif) four times. 3 Press the button once. 4 Press once. 5 Press pattlnk_1012007_1045-selectbutton.gif once. 6 Press pattlnk_1012007_1118-downarrow.gif once. 7 Press the left arrow butchange language - pattlnk_1012007_1117-leftarrow.gifuploads/images/pattlnk_1012007_1117-leftarrow.gif" alt="pattlnk_1012007_1117-leftarrow.gif" class="h_mi" />) ochange language - pattlnk_1012007_1117-rightarrow.gifp://i.fixya.net/uploads/images/pattlnk_1012007_1117-rightarrow.gif" alt="pattlnk_1012007_1117-rightarrow.gif" class="h_mi" />) until you see the desired lanchange language - pattlnk_1012007_1121-returnbutton.gif(pattlnk_10120change language - pattlnk_1012007_1045-selectbutton.gif). 9 Press pattlnk_1012007_1045-selectbutton.gif once to save the new setting.
Posted on Jan 08, 2008
  • 3 more comments
  • brian c
    brian c Jan 08, 2008
    Ok, that didn't post correctly.. let me try again..
    Press the down arrow button () four times.
    Press once.
    Press once.
    Press the left arrow button () or right arrow button () until you see the desired language.
    Press the return button ().
    Press once to save the new setting.
  • brian c
    Maybe this will work:
    http://support.lexmark.com/cgi-perl/know...
    &docid=ENUS28656&relevance=1
  • brian c
  • brian c
    FINALLY!!
  • brian c
    brian c Jan 09, 2008
    Oh, c'mon, you cant rate it higher? lol
How do i reset a language on Lexmark P4350 printer
To select the language of your choice on the operator panel, please do the following:
  1. Press Menu.
  2. Press the down arrow until Language: English appears. This is the default language.
  3. Press the left (<) or right (>) arrow to browse to your preferred language.
  4. Press Select.
Source: How to Change the Display Language on a Lexmark P4350 Photo All-In-One
May 23, 2011 | Lexmark P4350 All-In-One InkJet Printer
Display on the printer is in chinese
Press SETTINGS on the control panel.
Press ARROW key left or right to DEVICE SETUP.
Press CHECK
Press ARROW key left or right to LANGUAGE
Press CHECK.
Press ARROW key left or right to language you want on display.
Press Check to accept.
Jan 24, 2011 | Lexmark X4550 InkJet Printer
How do I reset the printer to the english language panel display
Follow these steps to change language setting on the printer display :
1.On the printer control panel, press the Left arrow twice or the Right arrow seventeen times on the Menu button until SELECT LANGUAGE? appears on the printer display screen.
NOTE: If the language is currently set to a language other than English, the Select Language? menu option will appear in that language.
2.Press the OK button.
3.Press the Left or Right arrows on the Select Photos button until your desired language appears.
NOTE: Even if the printer is currently set to another language, the name English will appear in the English language.
3.Press the OK button to select the language. A message requesting confirmation of the selection will appear appears. If the correct language is displayed, press the OK button. If the incorrect language appears, press the CANCEL button and start the selection process again.
4.When the SELECT COUNTRY/REGION? setting appears on the printer display screen press the OK button to continue.
5.Press the Left or Right arrows on the Menu button until the desired country/region appears on the printer display screen.
6.Press the OK button to select the country/region.
Nov 07, 2010 | HP PSC 1610 All-In-One InkJet Printer
Wrong language on the LCD display of the Lexmark X6570 how do I fix?
Select a different language after initial setup
1 From the control panel, press Settings.
2 Press left or right arrow repeatedly until Device Setup appears.
3 Press tick.
4 Press left or right arrow repeatedly until Language appears.
5 Press tick.
6 Press left or right arrow repeatedly until the language you want appears on the display.
7 Press tick.
8 Press left or right arrow until Yes appears.
9 Press to save.
Hope that helps, if it does please rate my help. Thanks
Nov 03, 2010 | Lexmark All-in-One Printer with PictBridge
Trying to set up printer need english instructions
If you have just connected the power to the unit for a first time install and turned it on, use the up/down arrows to get to the correct language. Then click OK.
If you are past that point and have to change the language. On the product control, click the button next to the copy button on the all-in-one. Then on the control panel, touch the top right corner, the left middle side and then the left bottom corner (one at a time) to access the Language Menu. Then touch the button next to Set Language for a list of available languages. Use the up/down arrows to select the language you need and click OK. If you also need to change the region, press the button beside to Set Region to get that list. Use the arrows to change the region and click OK.
Finally hit the Back button twice to exit the menu.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01674731&cc=be&lc=en&dlc=nl&product=3831669 for pictures/details.
I hope this helps.
Jun 07, 2010 | HP Photosmart Compact Photo Printer
How do I have printer switch from empty paper tray 1 to the full 550 paper tray 2
Hi. You need to do tray linking. When one linked tray is empty, paper feeds from the next linked tray. The size and type settings for all trays must be set from the Paper Menu. To set the paper type or size:
1. On the home screen, touch Menu button
2. Touch Paper Menu
3. Touch Paper Size/Type.
Note: To link the multipurpose feeder, Configure MP must be set to Cassette in order for MP Feeder Size or MP
Feeder Type to appear as a menu item.
4. Touch the right or left arrows to select the same size paper from all paper sources to be linked.
5. Touch the right or left arrows to select the same type paper from all paper sources to be linked.
Note: When the Size and Type settings are the same for any trays, the trays are automatically linked.
6. Touch Submit.
Submitting changes appears.
7. Touch Home to return to the home screen.
Hope this helps.
Mar 16, 2010 | Lexmark X464DE Mono Laser MFP, 38ppm A4...
How can i change the language.
To change the language on the display back to the required language, follow these steps:
Step Action 1 Power the printer off and back on. 2 Press the pattlnk_10312007_1543-pattlnk_9242007_1455-settingsbutton.gif button once. 3 Press the right arrow button (pattlnk_1012007_1117-rightarrow.gif) twice. 4 Press the pattlnk_1012007_1045-selectbutton.gif button twice. 5 Press the left arrow button (pattlnk_1012007_1117-leftarrow.gif) or right arrow button (pattlnk_1012007_1117-rightarrow.gif) until you see the desired language. 6 Press pattlnk_1012007_1045-selectbutton.gif once. 7 Press pattlnk_1012007_1117-leftarrow.gif or pattlnk_1012007_1117-rightarrow.gif once. 8 Press pattlnk_1012007_1045-selectbutton.gif once.
I am going to post this but it may not come out like it is on the website.
If it is not legible, I will direct you to the support site to obtain it.
Wayne
Aug 21, 2009 | Lexmark X5070 InkJet Printer
Language on Printer Window Screen
Here's a possibility:
Hit the menu button, scroll down to the 3rd option (Device Defaults)
Hit the "check" mark
Scroll down once to language
Hit the right (or left) arrows until you see English
Good Luck!
Jan 29, 2009 | Lexmark X8350 All-In-One InkJet Printer
Change LCD screen back to English
Issue: How do I change the language setting of the LCD?
Solution: Change the display language settings (MP170)
LCD Appears in Japanese (or other foreign language) Upon powering on the machine for the first time, the LCD will prompt to select a display language. If a language other than English is selected, the setting can be changed by following these steps.
  1. Ensure the machine is powered on.
  2. Press the <Menu> button as many times as necessary to display [SYSTEM SETTINGS].
    1. From the Copy mode standby screen, press <Menu> 7 times.
    2. From the Scan mode standby screen, press <Menu> 1 time.
    3. From the Memory card mode standby screen, press <Menu> 6 - 12 times.
  3. Use the right arrow twice to select [OTHERS] and then press the <OK> button.
  4. Use the right arrow three times to select [LANGUAGE SETTING] and then press the <OK> button.
  5. Use the right or left arrow to select the appropriate language and then press <OK>. Choose from the following language settings.
    1. JAPANESE
    2. ENGLISH
    3. GERMAN
    4. FRENCH
    5. ITALIAN
    6. SPANISH
Sep 11, 2007 | Canon PIXMA MP830 All-In-One InkJet...
369 people viewed this question
k24674
jasbo
jasbo
