Question about DeLonghi Ovens
Oven not getting hot but oven fan ligth working
    Problem Solver:
  • 5 Answers
But if the fan is not working just give it a gentle flick with something wooden like a chop stick - they can easily get stuck if they're not used regularly.
Posted on Nov 27, 2009
  • DeLonghi Master
  • 3,463 Answers
If it is a fan assisted electric ovenn, and the fan is working o/k, then you need to replace the oven element, usually located at rear of oven compartment.
Please rate my solution.
Thanks.
Posted on Nov 14, 2009
apart4u
  • 213 Answers
SOURCE: oven on fan setting not working
For all Free appliance repair videos visit our VIDEOTUTORIALS
here is a video on how to change your fan element
1, If the fan motor in the back of the oven is going round andthe temperature light is on (normally little red light), but there is no heatthen you will probably need a new oven element, these are generally very easyto fit and readily available from our website these can be tested with aelectric meter.
To gain access to the NEFF element you willhave to remove the back plate from inside the oven. Once removed you will seethe fan and element, if youlook closely at the element you willprobably see a small hole burnt in it where it has blown. Sometimes howeverthere is no evidence of a fault but the element is open circuit ie:broken inside the element casing, either way it will need replacing. Someelements will are fixed from inside the oven and some are held in place by nutsfrom the rear of the machine.
2, If your NEFF fanoven is getting warm but takes a very long time to cook or is burning the foodmore on one side than the other, then you need to check if your oven fan motor is working you willsee the blade turning fast if it is ok. if the element is heating but the fan motor is not blowing the heat into the oven thenyou need To replace the oven fan motor is a little moreexpensive and a bit more involved.
3. If you have the opposite problem ie: your oven is over heatingand burning everything then you will need to replace your NEFF oven thermostat
4, A quite common and easily overlooked answer is if your NEFF oven is not working at all ie: noheat and no fan then the chances are that someone has put the oven timer into AUTO mode,simply put oven back to MANUAL mode and all should be working again.
Posted on Jan 14, 2010
barkencoa
  • 3463 Answers
SOURCE: oven not getting hot
If the fan is working, then the oven element has failed, you need to fit a new element., it is behind a removable cover at rear of oven compartment.
Posted on Jan 25, 2009
  • 491 Answers
SOURCE: when turned to fan oven, the main oven is not
IT SOUNDS LIKE THE HEATING ELEMENT HAS BURNT OUT . REPLACE IT AND YOUR OVEN WILL WORK FINE.
Posted on Nov 05, 2009
  • 3 Answers
SOURCE: Fan works but oven doesnt get hot
One of the switches looks to be a 5 position switch. 0=off, 1=Light, 2=fan
Posted on Sep 23, 2010
SOURCE: In my Kompact double oven, the main oven does not
Kompact main oven - fan goes , grill works but oven does not heat up - help
Posted on Dec 06, 2010
Candy Built in double fan oven bottom oven not getting hot
Cheak the coils. Do a continuity test also look for signs of an electrical short(small scorched area) and clean the contact where the coil attaches to the appliance.
Apr 17, 2014 | Candy Ovens
I can't get the stove to heat up! The pilot light is on and the burners all work
check the bottom pilot ligth in the boril at the back to the top that poilt ligth it for the ovens
Oct 18, 2010 | Ovens
Oven getting warm but not hot?
If it is an electric fan assisted oven, and the fan is working o/k, \then you need to fit a new oven element., usually located at rear of oven compartment.
Thanks.
Nov 16, 2009 | Smeg Ovens
Feb 24, 2009 | Ovens
Jan 25, 2009 | Stoves Premier 600EMa Electric Single Oven
Electrolux double oven does not get hot
If it is a fan assisisted oven and the fan is still working, then you need a new oven element fitting.
Plz rate my solution.
Thanks.
Jan 11, 2009 | Electrolux EOU6330 Electric Double Oven
Fan oven not heating up
If fan is working then the element has probably gone
Nov 29, 2008 | Baumatic B904SS Stainless Steel Electric...
Exterior surface of oven gets hot when turned off
What do you mean by very hot? Is it too hot to touch? Hot enough to sizzle when a drop of water is put on it?
Oct 06, 2007 | Dacor MCS130 Millennia Electric Single...
Ovens Logo
253 people viewed this question
Top DeLonghi Ovens Experts
ashburton
Naftali Haskell
Level 1 Expert
Jason Harris
Jason Harris
Are you a DeLonghi Oven Expert? Answer questions, earn points and help others
