Question about Cell Phones
MY CORDLESS HANDSET WILL NOT CONNECT TO BASE UNIT.I CLEANED BATTERIES,CHECKED THEM,HOWEVER ALL I GETIS ERROR............PLEASE HELP
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. Try registering the phone with the base station. After registering the phone you'll be able to see the display on the handset after 1-2 min.s. Leave the handset on the base station for 6-8 hours to let it charge.
Also try and reset the phone by unplugging it for 1-2 hours.
Please tell me the make and model number of your Phone if you need the registering procedure or reset procedure.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Posted on Nov 14, 2009
Handset 1 not charging on either base unit
Check to see if there is any build up on the contacts that voltage flows through and clean it with DEoxit
Feb 24, 2016 | Idect Solo Vintage Styled DECT Cordless...
Hi I have a Cordless Uniden Dect 6.0 and also another one that sitts on a bitter base. My problem is this: the cordless with the smaller base shows the message 'Searching' and wont do anything,...
Welcome to FixYa.
Reset the units/set up by doing the following:
  • Turn OFF all the HANDSETS.
  • Remove the batteries of the HANDSETS.
  • Unplug the power source of the BASE.
  • Unplug the phone line of the BASE.
  • Let it stay that way for 30 mins.
  • Insert the battery again of the HANDSETS, make sure it is charged properly.
  • Plug back the power source of the BASE.
  • Plug back the phone line to the BASE.
  • Register any handset that is unregistered (refer to manual).
Keep me posted.
Jas247
Sep 11, 2011 | Uniden D1680 Cordless Phone
The in use/charge indictor light does'nt come on when i put phone on it. I just brought a new battery.
Check your connections on hand set and base. Wiggle the handset on base to see if handset starts charging... If it does.. clean your connections or you have loose solder connections either in hand set or Base Unit.. Give that a try..
Chris
Sep 03, 2011 | Uniden Cordless Phone
It said base no power
Remove then replace the batteries from the hand set. You should now get dial tojo.
Oct 25, 2010 | Panasonic KX-TGA101S Cordless Handset
Uniden XS 1210 cordless phone won't connect to base unit
try connecting both phones via the base that is working and see if they recognize each other. Let me know if that works.
Jul 21, 2009 | Uniden Cordless Phone
It always losing the line during the cordless calls
* CHECK YOUR AC OUTLET WITH NO LOOSE CONNECTIONS.(remove multi adapters mostly caused problems)
* FULLY RECHARGE THE BATTERIES.
* CLEAN DE BATTERY CONTACTS IN & OUTSIDE THE HANDSET & THE BASE UNIT.
* IS THE BATTERIES DON'T GET CHARGED FULLY IN OVER NIGHT.PLEASE REPLACE THOSE.
* REPLACE WITH ONLY RECOMMENDED RECHARGEABLE BATT"S.
* PLACE THE BASE UNIT AT CENTRALIZED AREA FOR THE MAXIMUM HANDSET RADIATION.
* KEEP THE BASE UNIT AT SAME FLOOR.
Mar 30, 2009 | Panasonic KX-TG1100 Cordless Phone
Vtech ia5870 dual handsets model problem:
http://www.vtechcanada.com/manuals/5870ciben.pdf
from the troubleshooting section of the manual
• Unplug the base unit’s electrical power and remove the battery from the handset. Wait for 15 seconds then plug in the battery place the handset in the base unit and plug in the power. Allow up to one minute for the cordless handset and base to synchronize
not a guarantee, something to try
Aug 30, 2008 | Vtech ia5870 Analog Cordless Phone
ELBT595 Handset Not Turning On
Check the handset battery -- if there is a slight "bulge" on one side (ie: not COMPLETELY flat) then the problem is with the battery. I had that problem and had to order a new one. That said, I just installed the new battery, and while it now charges, the handset won't connect to the base unit. The base unit works (tried the speakerphone), but there is not connection between base and handset.
Feb 18, 2008 | Uniden ELBT595 Cordless Phone
Lost comunication
I solved this problem with a RESET of the handset. Instructions from the Philips website: Please perform a reset of your device. You will not loose your recorded data (phonebook and personal settings are being kept). 1. Unplug the mains of the base station. 2. Remove one of the batteries of each handset. 3. Put the batteries back in and re-plug the mains of the base station.
Mar 09, 2006 | Xact Communication XG2200 Cordless Phone
Cell Phones Logo
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
