Z-70 copier won't turn on
Flip the switch but nothing happens mainly I need to know if there is any buttons i need to push or something before it will turn on
thanks
    President:
  • 2,072 Answers
Most likely the low voltage power supply had gone bad.
Less likely is a bad on off switch .
Posted on Jan 09, 2008
Frigidaire galaxy series makes ice but won't dispense
If nothing at all happens then check the micro switch on the lever/button section. This will probably require taking the dispenser section off. If nothing at all is happening its as though it doesn't register the dispense, if the switch worked then at least something would happen ie the flap, the drive motor etc
Jul 08, 2013 | Refrigerators
Linx Hoover platinum won't turn on
more than likely you'll have to order a new handle. Those machines are built in pieces so you just cant replace switch, motor, etc....
Feb 13, 2013 | Hoover Platinum LiNX Cordless Stick Vacuum
JBL Flip won't turn on
this doesnt help. how can i get back on?
Jan 11, 2013 | Harman Kardon JBL Flip black
Husqvarna 316 electric chain saw won't start
It could be a blown fuse in the plug, a quick continuity test on the fuse will tell if its blown, there is also a micro switch activated by the hand guard, i have had to change a lot of these because the hand guard does not push them in far enough, just try grabing the grey hand guard and twisting it clockwise to push the switch in further at the same time press the triggr ( BE CAREFUL WHEN DOING THIS IT IS ONLY A TEST ) if it starts you need a new micro switch. If the is ok and you have done the test it will have to come apart to check the wiring and the motor, let me know if you need help with this.
Jun 30, 2012 | Garden
Push start and motor hums, but nothing else works.
Hi, If you release the start button, does the hum stop? It sounds like hte start winding in the motor is bad. You can try and start it manualy by truning the timer on, open the door so that you can turn the drum with your hand. You will need anoth person there so that one of you can hold the door switch button in and the other push the start button. While pushing the start button, try turning the tub and see if it starts. This will give you an idea on the motor bad or not.
I hope this helps. Please let me know if you need any more assistance.
Thanks
Vic
May 12, 2009 | Dryers
Solve System Error E001
it needs a new fixing unit. Youll need to call a tech for this, the finixing unit cost the dealer 180 bucks and the make up is around 50% so its not a cheap unit. There also adjustments that need to be made in service mode so you really need a Canon tech that knows how to get into the service mode and make those adjustments for the new part.
Jan 16, 2009 | Canon imageRUNNER 210S Copier
Our borrowed Flip (Ultra?) seems to be frozen ON.
I have the same problem and found something that kinda worked for me. Hopefully it'll work for someone else. Turn on the flip while holding down the - key. It should power up normally and allow you to view/record etc. Several videos say "Invalid Format" or something like that on the screen, but most are ok and I can record. Better than a completely dead one.
Nov 26, 2008 | Pure Digital Flip Video Ultra Camcorder
Kenmore dryer series 70 won't turn on
most of the time it is the door switch that goes bad,also you can check the main fuse inside the dryer on the blower box,and always make sure your dryer vent and wall vent are clear to vent,let me know what you find-mike
Oct 26, 2008 | Kenmore 63942 Dryer
52 people viewed this question
k24674
jasbo
jasbo
