Question about Toshiba 65H80 65" Rear Projection Television
Need instructions on removing the front screen for ceaning spider webbs
    Top Expert:
  • Toshiba Master
  • 14,553 Answers
THERE IS A BETTER WAY TO DO THIS THEN REMOVING THE SCREEN--IT CAN BE DONE BUT UNLESS YOU KNOW EXACTLY WHAT YOU ARE DOING YOU COULD DAMAGE THE SCREEN.
Here is what I would suggest checking out first.
1) With the set unplugged remove the back cover.
2) With the cover off if you can see the three large black lens---and have enough room---get a swiffer type duster on a rod and carefully reach up inside from the back to get all the webs out.
3) If this works---it is also a good idea to wipe the three lens clean of any dust--do not remove the lens--it is not needed--you can clean then with a paper towel with glass clean sprayed on it--they are glass not plastic.
Let me know if you have questions--I am here to help.
If this information has helped you, rate this solution as I do this here for FREE.
SD TECH
Posted on Nov 15, 2009
  • Antal O. Juhasz Jan 15, 2013
    Can you clean the mirror too from the back ? I'm trying to ffigure out how to get to them. Thanks antalo@satx.rr.com
I own a toshiba rear projection tv model 57h83 and dust has accumated behind the screen along with some spider webbs (don't even ask how the damn spider got in there?! anyway, i would like to take the...
Its usually easier going though the back of the tv. Use a vacume also, you want to draw out all the comtaminats not blow them in with canned air. Dont wipe the lenzes of the crt tubes. Beware the tv holds charge even when unplugged. Hope this helps,.
May 29, 2011 | Toshiba Televison & Video
It has a spider web inside the screen and I need to know how to clean it because it is directly in the center of the screen
The best way to get at it is through removal of the front screen. Start by removing the front speaker grill-should just pull off (snap fitted). Then remove the front control panel (4screws). Next remove 4 screws from bottom of front of screen- the screen should ten just pull off -also snap fit- Make sure the set is unplugged before you begin- Once the screen is off you can also clean the lenses and the mirror (if glass) use a soft damp cloth.
Sep 26, 2009 | Toshiba 50H82 50" Rear Projection...
How do I dust inside the screen of a Rear projection TV?
Unplug tv first Usually you can pop the front screen off the set. There may be two hidden catches depending on the model. You may want to use two people for this. Once the screen is off removed the spider web and clean the back mirror with some windex, don't clean the inside of screen with any cleaner. Replace carefully the screen making sure it clicks back correctly
Mar 13, 2009 | Philips Magnavox 51MP392H Rear Projection...
Spider web behind front of screen
Take the front speaker grill, and ther will be a few screws on the bottom of the screen. Remove those and lift the screen up and out.
Feb 14, 2009 | Hitachi 53UDX10B 53" Rear Projection...
Bearings on a indest wie 167 washing machine
You can download a user manual for your m/c, but not a repair manual, Go to>
www.indesit .co.uk
Follow the links. To remove the spider, remove the rear panel, remove drum belt, undo drum pulley, you may have to heat the screw holding the pulley,undo all screws that you can see holding the spider to drum rear.
Withdraw spider, you may have to use some force to pull it off.
Fit new bearings or spider, and reassemble..
plz rate this solution.
Dec 15, 2008 | Indesit WA 115 Front Load Washer
SPIDER BEHIND THE SCREEN !!
removal of the screen on this unit is not to difficult. to remove the screen you will need a t20 bit. the torx 20 screws on the back side of screen then the torx screws on front panel. be carefull that screen is easy scratched.
Oct 30, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Psp
you can get a New replacement LCD for $35 at www.blackberry8100parts.com
Dec 26, 2007 | Sony PlayStation Portable (PSP) Console
Dirty screen but it is behind the outside screen.
The front screen with the frame does remove from the cabinet giving you access to the mirror and CRT lens. Remove the speaker grill,remove the four screws on the bottom of the frame, then working underneath a corner proceed to pop the rivets holding the frame to the cabinet. It will seem impossible at first because you have to use a lot of force to pop each one out.When reinstalling,a rubber mallet may help popping each rivet back in (I am not kidding when I say they are tight)
Oct 24, 2007 | Hitachi 50UX57B 50" Rear Projection...
Toshiba 65H80 65" Rear Projection Television Logo
133 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
