Question about Husqvarna Sewing Machines
Is there a diagram of the automatic thread cutter for the husqvarna viking designer se? if so, where will I find it?
SOURCE: Husqvarna Viking Designer 1 Beeper
when i,m doing a machine embrody the thread will fray in the needle and spoil the whole design, i,m afaird to do anything on a piece to keep. what is the best thread to use
Posted on Feb 14, 2008
SOURCE: Husqvarna Viking Designer 1 problems using metallic thread
Try using a bigger needle
Posted on Aug 06, 2008
  • 6 Answers
SOURCE: problem with automatic needle threader On Viking Designer 1 serie
Yes, I fix them all the time. You will need very good eye sight as the wire/metal hook is very small. If you get at an angle where you can see how the hook lines up between the metal flaps that hug the needle, the hook will probably be off center. You will need something very flat, but strong. I have use the exact-o-knife blade, in the handle of course, a knife, and a tiny screw driver. The hook has to line up vertically and horizontally. What usually happens is when we thread the needle it did not line up exactly, and putting pressure on the white tab, bends the hook. Bend it back and you are in business. If the threader does not line up horizontally, the needle threader may have slid down the shaft. This take a special tool. I purchased mine at Sears tools. There are 2 screws on the back of the threader. Move the needle to the highest position and after loosening the 2 screws, you can slide the threader up and down on the silver shaft, this is trickier, because the shaft moves up and down and rotates as it gets close to the needle. I use calipers/hemostats to hold the shaft while I line up the hook.
Hope this helps.
Posted on Jan 07, 2009
SewTechWayne
  • 186 Answers
SOURCE: Service Menu For Husqvarna Designer SE
Hold down the start button and the presser foot pivot buttons at the same time and turn on the power. The machine will make a funny noise and the test screen will come up. You then need to find the sub-menu, I think it says tensions on it but I'm not sure.
Posted on Jan 31, 2009
  • 371 Answers
SOURCE: viking husqvarna classica 100, thread tension
I suspect you are correctly threading the machine but the timing of the needle and bobbin hook is off. When the threaded needle goes into the bobbin area, a pointed hook grabs the thread and loops it with the bobbin thread. Something is catching when the needle starts to come up that is not allowing the bobbin thread to be pulled back through the needle plate opening by the upper thread. With machine threaded and bobbin in place, have the bobbin area open if possible and watch the thread interaction when the needle goes down. To set the hook/needle timing, normally covers have to be removed. Suggest taking it to an authorized Husqvarna Viking dealer for service. You can find the nearest dealer by click on the "Dealer" link at http://www.husqvarnaviking.com
Good luck.
Posted on Feb 11, 2010
How do I turn off thread portioning on Husqvarna Ruby De Luxe. I don't want to adjust the settings but need to turn this off. Thank you
FWIW, I was unable to find any information for turning off the thread portioning function. Unfortunately, this appears to be the thread tensioning system, so disabling the thread portioning would be disabling the thread tensioning--something that is critical to sewing. It appears this model may have some issues and perhaps this one is particular to your machine. It may be best to take it for service.
Perhaps this will help:
Husqvarna Viking Designer Ruby 25 Tension Thread Portioning Deluxe Stitch...
Husqvarna Viking Designer Ruby 22 Bobbin Thread Sensor
Husqvarna Viking Designer Ruby Review Sewing Insight
Jul 01, 2016 | Husqvarna Sewing Machines
Knife cutting knives
Remove the stichplate and snap out the plastic cover over the thread cutter (left most end of machine). This exposes the thread cutter mechanism. You should then be able to position the knife arm back into the mechanism (two pins on the cutter mechanism that insert in a hole in each actuating arm).
Apr 11, 2014 | Husqvarna Viking 1
Viking designer SE sewing and embroider machine -- Thread that has come out of the take-up lever
If this problem persists there is an upgrade on the take up lever that has a plastic clip that holds the thread in better. Check with your dealer.
Dec 31, 2013 | Husqvarna Viking 1
Viking designer se machine Thread that has come out of the take-up lever
Some machines had a special plastic clip that was an update on the thread take up lever. Take it to your dealer for this.
Dec 31, 2013 | Husqvarna Designer I
How to put a thread cutter in husqvarna viking desinger se sewing machine
I believe the plastic cover (gray?) toward the end of the arm (left of the needle plate) is removable by prying (gently) on the front edge and sliding toward you. Unless the cutter is broken, you should be able to figure out how itall fits back together.
Dec 21, 2012 | Husqvarna Sewing Machines
Thread balls up underneath my feed dog when straight sewing. Why?????
Could be needle/hook timing. With machine off do the following to check timing -
remove bobbin and bobbin case.
push needle all the way to the left.
Turn handwheel toward you watching the needle and bobbin housing hook. The point of the hook should line up right above the eye of the needle.
If not timing, clean bobbin area and thread cutter area, removing lint and thread.
Check bobbin tension, should get slight resistance when pulling thread.
Make sure using only Husqvarna Viking bobbins -- most are green but they have new colors now. All will have the Husqvarna logo on them (an H). Make sure the bobbin is unwinding counter clockwise when going through the bobbin case.
Remove fabric. Pull extra long bobbin thread (about 3 inches). Hold upper thread tail in left hand, turn handwheel toward you for 1 revolution. Is the bobbin thread caught by the top thread and pulled through the opening of the needle plate?
If you are still unable to sew without thread balling up, take to an authorized Husqvarna Viking dealer for service or have them send to Husqvarna Viking (SVP) Technical Service Dept for repair. A list of dealers close to you can be found at the Husqvarna Viking website - http://www.husqvarnaviking.com/us
Good luck.
Sep 24, 2009 | Husqvarna Designer I
Sewing Machines Logo
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Derek Massey
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
