Question about Texas Instruments TI-86 Calculator
Won't power on even though i've installed new batteries. There is no corrosion on the battery terminals.
  • Texas Instru... Master
  • 7,993 Answers
Check that the terminals in the battery compartment are clean and shiny. Remove any powder left after battery leakage. Insert fresh batteries in calculator. Make sure you respect the polarity diagram. +-+- (Many malfunctions come from incorrectly placed batteries).
After replacing batteries, calculator is restored to defaults and screen display may be too loght or too dark
To adjust the screen: Darken or lighten display
To darken screen
Press [2nd] key and release it.
Press and hold [UpArrow] until screen is dark enough.
To lighten screen
Press and hold [DownArrow] until screen is light enough.
Hope it helps.
Posted on Dec 05, 2009
Battery terminal corrosion
Make sure you have radio security code before removing battery leads. Remove battery leads, -ve lead first.
Clean grey oxide coating from battery terminal posts and inside battery lead terminals with abrasive pad (eg. Scotchbrite coarse) or abrasive paper and wipe clean with cloth. Liberally coat battery terminal posts and inside of lead terminals with general purpose grease or petroleum jelly. Install battery leads to battery, +ve first then -ve, and tighten securely. Do not over tighten. Spread excess grease over top of battery post and lead terminal to ensure all moisture is excluded. Replace terminal covers. Should be good for a long time.
Dec 03, 2012 | Chrysler Town and Country Cars & Trucks
Bike won't start. No voltage to fuel pump fuse on 2008 Ultra Classic Electra Glide. Have power on all other fuses. Any suggestions?
Get some good electrical cleaner spray displays that connection scrubber with alcohol, make sure the fuses good and try again pulled a plug-in out, even though you charge the battery make sure the battery has 12.67 V of starting juice. How was your battery may be needed. New battery
Sep 29, 2012 | 2008 Harley Davidson FLHTCU Ultra Classic...
2004 Ford Explore won't turn over
whilst you are trying to jump start it check if you jump leads are good and powerful enough to sent the power to your battery,check if your battery terminals are clean enough to accept the power given,or is your battery not completely dead and even you are boosting has not the power to increase the needing one to start and is just for lights only?
Sep 17, 2012 | 2004 Ford Explorer
Nikon S8100 digital camera won't power on even with new battery.
1_ recharge the batteries or replace
2) clean the contacts batteries with contacts cleaner very well with carefully
3) see if the battery is loaded in WRON direction
4) memor card slot/battery cover is open.
5)poor contact between camera and battery terminal adjust the contacts and clean.
God bless you
Jul 31, 2012 | Nikon S8100 Digital Camera
New battery still won't start 2007 Lexus RX 350
Did Robert Garcia's advice work for you? I have the same problem
Jul 16, 2012 | 2007 Lexus RX 350 FWD
Won;t power up at all. New batteries but I did not replace back up battery. should I? Tried the contrast fix. Son said he dropped it and it got kicked down hall at school. One year old. Any hope?
If new batteries did not solve the problem, the next thing to check would be the battery terminal.
If the battery terminal is rusty, the battery power won't contact and the calculator won't turn on. So, use a flat small screw drive to scratch the battery terminal so that there would be contact.
If the above is not the problem, the next to check would be the wire connecting the battery terminal to the the calculator's main board. There is a wire between the battery terminal and the calculator board. When the battery is inserted, the power from the battery goes from the terminal to the board through this wire. There is a possibility that this wire is cut in-between or is loosing contact. In this case, you need to get a small screw driver and carefully disassemble the calculator in order to check the wire.
If the wire is intact, use a light brush to brush the calculator board as there might be dust on the board.
If non of the above helps, then it means the calculator is dead and needs a replacement.
Regards.
Sep 13, 2011 | Texas Instruments TI-84 Plus Calculator
Put in a new atl wont charge
If both the alternator and the battery are good, either the alternator isn't turning fast enough (slipping belt or engine idle speed too slow), or you have a wiring problem.
To check your wiring, look for the "1" terminal on the back of the alternator (left side of spade terminal connector). When you turn the ignition key to the run position without starting the engine, the alternator warning light should be at full brightness. If the bulb is burned out, the alternator will not get the excitation current it needs to start up (it goes through the bulb). With the engine running, you should measure 12 Volts at the 1 terminal (this is the excitation terminal).
Another thing to check is whether the battery charge wire is good. If it is corroded inside at the battery clamp end or burned out, you won't get charging even though the alternator appears to be working. If you don't have an ohmmeter, you can make a quick test by adding a new 8 AWG wire between the output terminal and the battery clamp. If the battery now charges, the original wire is bad. If this works, I recommend installing an inline fuse at the alternator end no larger than the largest size used in your electrical system, just in case something happens to the jumper wire. That way you won't burn out your alternator.
The heater/AC issue could very likely be a separate problem, but inadequate power may keep that system from running properly. (Note: low idle speed or belt problems will also be detrimental to AC performance.)
Jul 10, 2011 | 1989 Chevrolet Corvette
Burner won't ignite it is a cal flame have to lite with a match
Linda, changing the battery in the electronic ignition will probably solve the problem. To change it, unscrew the ignitor button cap and remove it. The battery will be in the holder inside. Take note of which way the old, burned battery is facing, because that's the way you want the new battery facing, when you install it. While the old battery is out, check inside the battery holder for corrosion on the terminals. If you see any, use a Q-Tip & WD40 to clean the corrosion off.
Hope this helped you troubleshoot and solve the problem. Happy Grilling!!
Jul 02, 2011 | Cal Flame Grilling
1990 plymouth colt, new alternator, still won,t charge. what tells alternator to charge battery?
Have you also had the battery checked? If the battery is bad, then it won't charge. All of the terminals need to be checked for corrosion. All wires must be secured properly. Check to see if the ground cable is properly attached to the frame of the vehicle.
May 03, 2011 | Ovens
Camera will not turn on even though battery is charged
your new batteries may be worn out to the point that they won't accept a charge, but the problem you describe is frequently due to corrosion on the battery contacts inside the camera. Remove the batteries and wipe the camera contacts firmly with a clean cloth (heavy corrosion buildups may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment, clean the contacts at both ends of the batteries, and reinstall them in the camera.
thanks
Apr 21, 2011 | Cameras
Texas Instruments TI-86 Calculator Logo
120 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
