Question about Frigidaire GLTR1670A Front Load Washer
Frigidaire GLTR1670A Front load washer won't final spin
Washer will not do final spin on any setting. Followed trouble shootting in MFG book. My load is balanced, the load is not too light, and I use HE detergent.
A lot of folks seem to have this same problem. Please help!
Annette
  • johnpubv2 Feb 23, 2008
    Washing machine will not do final spin at end of cycle. Pump drains, and tub rotates, but machine does not spin dry clothes.
    From the troubleshooting electrical diagram, I have the following results when testing:
    Switch Continuity
    When Switch is on Heavy - Off position 1A - 1C = 0, 3A - 3C = 0, 5A - 5C=1, 7A - 7C=0
    When switch is on a different wash setting, the results are proper as stated in diagram: 1A - 1C = 0, 3A - 3C = 1, 5A - 5C = 0, 7A - 7C=0
    Voltage testing on speed board:
    10 pin between 1,2,6,&10 and ping 5 on 6Pin. 1,2, & 10 = 120V, but pin 6 = 35 V. It should be 120 V. Any idea what the problem is?
    Continuity testing on speed board, 6 pin: Between pin 1,2,&3, I get closed connections. The diagram states that it should be approximately 3 MegaOhms. Is this right. I get ohm readings only in the lower range of my multimeter e.g. 200 Ohms.
    So, do I have a messed up switch AND a dead speed board? An how do I get the switch out to replace it? Do I have to dismantle the entire top of the machine including the suspension springs for the tub?
    If anyone has some ideas I would greatly appreciate the advice.
  • Anonymous Mar 23, 2008
    I hate my stupid front load washing machine. Nothing but problems. Thanks all I wanted to say. Mine won't drain at the final spin. But at this point, I'm ready to junk it. It's not even 2 years old.
    President:
  • 1,294 Answers
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too. Use front loading powders.
Rate me pl.....if helped. Click on 'thanks for trying' if not helped, your prob will be back for someone else to solve.
Posted on Feb 11, 2008
No spin cycle
Did you check to see if there is a broken
belt present
Dec 04, 2007 | Frigidaire GLTR1670A Front Load Washer
Starts Banging really ******* spin cycle, then quits... seems like the drum is loose.
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front loadwashers can make..
Washer Problems Washer noise when spinning
heatman101
Aug 12, 2011 | Frigidaire GLTR1670A Front Load Washer
Washing machine does not spin or drain
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Jan 02, 2010 | Frigidaire GLTR1670A Front Load Washer
Frigidaire front load washer GLTF1240AS0 - noisy and leaves dirt/oil on clothes in dotted pattern (so dirt being put on thru drum at final spin?). Could it be oil leak? bearing?
good call.....
your bearing is leaking into the machine
you can verify this by simply removing the back
if the side walls are covered in ablack spray pattern
sometimes it does not leak on both sides (in and out) but if it is leaking your machine will get progressive louder in both aggitate and spin
Oct 09, 2009 | Frigidaire GLTR1670A Front Load Washer
Frigidaire front load washer no spin
sounds as if theres something stuck in your drain pump, youll need to remove the lower acess panel(2 screws across the bottom front of unit) you'll see teh pump in the rigth hand corner. i would remove as much water as possible before trying to remove the hose to the pump or you will get soaking wetaferer removig the hose youll be able tro see what trapped in oyu pump preventing free draining.. VERY common problem.DISCONNECT POWER THE DRAIN PUMP IS ALWAYS LIVE!!!!!!!!
Oct 19, 2008 | Frigidaire GLTR1670A Front Load Washer
Frigidaire GLTR16704 Front Load Washer 417.39012891
Time for a new one.
Sound like you have done the main shaft bearing.
Nov 18, 2017 | Frigidaire GLTR1670A Front Load Washer
Doesn't spin the clothes dry on the final spin but spins at high revolutions without a load of clothes
I have read that if the pump is not draining the tub completely, there is an interlock that prevents the high speed spin from engagin. I have had debris caught in my pump several times (kids!!) with similar issues. There is a trap on the line leading from the tub to the pump which is "supposed" to capture debris, but it doesn't work all that well. Check your pump.....
Dec 18, 2007 | Frigidaire GLTR1670A Front Load Washer
Front load Frigidaire Gallery washer
You are having a door switch problem change it out and you will have a new washing machine.
Dec 14, 2007 | Frigidaire GLTR1670A Front Load Washer
Frigidaire front load washer problems
My problem is that water is still draining when it goes to final spin. final spin is not working properly. then machine shuts itself off before timer.
Nov 16, 2007 | Frigidaire GLTR1670A Front Load Washer
Frigidaire GLTR1670A Front Load Washer Logo
106 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
