Question about Video Cameras
Panasonic hdc-sd1 FAULT SHOWING ON LCD SCREEN:- PLEASE CONNECT TO AC ADAPTOR AND BATTERY I AM ALREADY IN PC MODE, BATTERY IS CONNECTED AS IS USB LEAD,  BUT MESSAGE IS ASKING ME TO DO THIS, IT WILL NOT LOAD ON TO MY MAC
  • 1 more comment
  • Anonymous May 10, 2008
    I have the exact same problem!
  • Anonymous May 18, 2009
    same problem. please help us :)
  • Anonymous May 19, 2009
    same
I came across the same problem and even though you seem to be powering the cam from the usb lead and battery, you also need to plug the ac adapter into the camcorder otherwise it won't let you go any further, asuming i'ts not plugged in already, the question isn't that clear...
meanwhile my hdc sd1 is not even turning on, so think yourself lucky
Posted on Feb 01, 2009
6ya staff
SOURCE:
How do I upload a video to my PC?
The message about the AC adaptor is precautionary. Uploading a video can take quite a while. It would be disastrous to have the battery run out of juice before the operation is finished because the file would be ruined and you'd have to do it over again.
Jan 07, 2015 | Panasonic PT-47WX53 47" Rear Projection...
HDC-SD1 No Power
Battery could be discharging or worse, power transfer within can is broken
Jul 21, 2014 | Panasonic HDC-SD1 Camcorder
When connected to ac adaptor it will turn on and toshiba leading innovation appear, but after that no program will displayed, but when i disconnected to the ac adaptor the programs runs normally. the
This is strange.
I think your ac adapter power cord is bad. Get another one from ebay at: http://www.ebay.com
Just put in your computer's make and model, not the model of the battery in the ebay search.
For example: Toshiba Satellite Pro L300 AC Adapter
It might be your lcd screen's inverter, but it's strange. Anyway test the inverter by plugging in the ac adapter and when the screen goes blank try the steps below.
Shine a flashlight on the dark screen to see if you barely see the icons on the desktop. If so, then the LCD Inverter is bad.
Plug in an external monitor and see if the display shows up on it. It can be any kind of monitor even the old big fat crt monitors as long as it has a vga cable to connect to your computer's vga port. If so that proves your video card is ok. The video will show on most systems when you reboot without you having to do anything. Some systems will require you to hit the FN (Function key) + F1 thru F12. Hold down the FN key then hit the correct key for displaying on the monitor (F1 thru F12). The correct key will normally have CRT/LCD on it or it will have the icon of a display.
If you see no icons by shinning a flash light and the external monitor works, then your screen is bad. If you see no icons by shinning the flash light and nothing shows on the external monitor, then most likely your video card is bad.
May 20, 2012 | Toshiba Satellite Pro L300 Notebook
How to connect to computer
Please follow the instructions below to connect your Lumix DMC-LZ7 Digital Camera to your computer
1.Install the software ( LUMIX Simple Viewer or PHOTOfunSTUDIO-viewer-) in the CD-ROM (supplied) to your PC.
2.Set the camera to a mode other than the PRINT Mode.
3.Turn on the camera and the PC
4.Connect the camera to the PC via USB Cable (A) as shown in the diagram.Cable (B) is the optional AC Adaptor ( No need if batteries are used )
4. The drive appears in the [My Computer] folder ( If you are connecting the camera for the first time,the required driver is installed automatically and then the drive appears in [My Computer] )
5. The following message is displayed on the screen during Data Transfer
Jun 19, 2011 | Panasonic Lumix DMC-LZ7 Digital Camera
Panasonic HDC-SD1 camcorder will not turn on
Are the Batt's full? because this looks like you have not enough power to keep the camera on.
Jun 06, 2010 | Panasonic HDC-SD1 Camcorder
Can hdc-tm20 connect a firewire cable?
From what I have heard this camera has no firewire, but it has USB download to PC and AV sockets, I hear that a new version soon will carry the firewire mode as I like many other camera user's do find that the firewire to PC connection is the best, but saying that if you record on the flash mem mostly you can plug that card into the latest PC's anyway, if you can do that then it will be very high def movies indeed.
I would not like to use a USB download cable as you will find picture suffers badly.
May 22, 2010 | Panasonic HDC-TM20 High Definition...
Uploading pictures
Cameras can't upload if low on power. Charge batteries or plug in the ac adaptor to an outlet and try again.
Sep 12, 2009 | Panasonic SDR-H40 HDD Camcorder
Can I use 32gb sdhc card on Panasonic hdc-sd1 camcorder
The camcorder only supports 4GB SDHC cards.
Regards
Jun 30, 2009 | Panasonic HDC-DX1 DVD Camcorder
IMovie capture is poor quality.
hello referring to the SD1 from Panasonic, i recommend to deinterlace the captured clips with "JES Deinterlacer" before editing them with imovie. be careful to use "apple intermediate code" at the output of JES Deinterlacer. i clearly get better results this way, max recommendable size at 1280x720p when exporting QT files... kind regards, bruno
May 26, 2008 | Panasonic HDC-SD1 Camcorder
Panasonic HDC-DX1
What did you try so far? Maybe this user review (not mine) has a bit of an answer?
Feb 01, 2008 | Panasonic HDC-SD1 Camcorder
Video Cameras Logo
644 people viewed this question
Top Video Cameras Experts
Al Rush
Ekse
Marvin
Marvin
Are you a Video Camera Expert? Answer questions, earn points and help others
