Question about Briggs & Stratton Ignition Kit 2-8 HP Engines with Breaker Point Ignition #5012D
I get one spark on plug, then nothing. It is a
I get one spark on plug, then nothing. It is a 1972 Briggs and Stratton 15 hp that has been running good. Slight cold natured but once warmed up is a great runner. I pressure washed the engine and replaced a leaking fuel line. It cranked up fine, then stalled. Now I get excess fuel leaking from carb (Have a kit I expect to put in) but when I pull plug, ground it to engine, and turn engine over, I get one strong spark then nothing. Pulled ignition component cover and points (Breaker in nomenclature) appears clean and not pitted. Have not tried to adjust. Turning over see weak, intermittant spark at point.
    Sergeant:
  • 399 Answers
Hi y could have a sticking float in your carb causing it to flood
Posted on Nov 15, 2009
Spark plug gap
How to Gap a Spark Plug - YouTube
? 2:57
https://www.youtube.com/watch?v=IuW3svdqKZM
Oct 15, 2012 - Uploaded by ChrisFix
How to correctly gap a spark plug. This is a fast and easy video on how to gap a spark plug and spark plug gap ...
FAQ: Find My Engine Spark Plug & Gap ' Briggs & Stratton
www.briggsandstratton.com/.../identifying-the-correct-s...
Briggs & StrattonFollow this step-by-step image guide to locate spark plugs in different Briggs & Stratton engine types. ... Spark Plug Type & Gap Chart for Briggs & Stratton Engines. Now that you've found the part you'd like to replace, you can use the chart below to identify the genuine Briggs & ...
Spark Plug Gap - AutoZone
Dec 15, 2015 | Cars & Trucks
Spark plugs foul immediately
Fouled plugs may be caused by oil leaking into the cylinder. Does it smoke when running (cold), are you using up the crank oil. Black smoke is excess gas comsumption, blue smoke is oil burning. If your plug is fouled with black carbon, you are most likely running to rich.
Apr 07, 2014 | Briggs & Stratton Briggs Stratton Vanguard...
18 hp briggs and stratton no spark
unplug oil senso still no spark un \plug shutoff wire to coil still no spark replace coil
Nov 15, 2012 | Briggs & Stratton Briggs Stratton Intek V...
22 hp b/s won't stay running
check spark make sure its bright blue but sounds like a dirty carb needle valve isnt opening enough not letting enough fuel in
Jun 25, 2012 | Briggs & Stratton Briggs Stratton Intek V...
20 hp intec runs wide open
24 hp briggs. replaced cam, exhaust lobe was unhardened. now it doesnt fire on that cylinder. plug is wet. spark tester shows spark,please help.
Mar 30, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Where does the wire go off the points?
wire goes to the coil.condenser lead is attached to the same connection on the points.
Oct 01, 2009 | Briggs & Stratton Ignition Kit 2-8 HP...
I craftsman 20 hp twin mower quits after waarm up
SOUNDS LIKE A FUEL PROBLEM OR DIRT WHAT OTHER SYMPTONS DOES IT HAVE
Jul 08, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Briggs & Stratton Ignition Kit 2-8 HP Engines with Breaker Point Ignition #5012D Logo
463 people viewed this question
Top Briggs & Stratton Hammering Experts
Dan Webster
Dan Webster
John Trevino
JOHN LAPIER
Are you a Briggs & Stratton Hammering Expert? Answer questions, earn points and help others
