Hi i have a mitubishi wd62627 tv it will not come on i was advised it probaly was the lamp my husband put in a new lamp and still the the tv will power up. i hear the tv but there is nothing
  • 7 more comments
  • rosnjer75 Nov 14, 2009
    there isnt any lights in the back of tv when tv is plugged up it blinks for a few seconds then nothing befor the tv went out for good every time i turned it on it cut off by itself also the remote doesnt work even with new batteries
    hi i am still waiting fro an answer from you how could i accept a solution if you just asked a few questions concerning my tv do you have a solution?
    i did as you said and the lamp color is a blinking yellow i cant see any error codes because the tv will not come on
    sorry about the remark your reply had not showed up on my computer thre is no power light or a timer light only the lamp light blinking yellow
    hi my husband readjusted the cover and now the lamp light is a steady yellow should he try again thanks
    hi i did press menu and device at the same time now the lamp light is blinking yellow my husband who can fix things say it is like the lamp is not setting in the housing therefore the cover cant be properly closed any suggestions thanks
  • rosnjer75 Nov 15, 2009
    hi i know you want this to be over the lamp is mitsubishi same as in the tv could the new lamp be a dud or is something else wrong i guess i will have to send it back and try again thanks for all your help
    hi how can we test the bulb and where do we go to test it thanks
    the tech guided me through several steps to get to the bottom of the problem. The problem was resolved because it seems the lampi bought was defective. will post new message if the tv gets fixed once i receive a new lamp thanks
  • 10,594 Answers
Want to ask couple of questions about TV symptoms,
1- Does lamp fire up and produce light/ do you see any light at rear of TV?
2- Does TV show any screen display or Menu contents?
Waiting your reply.
Thanks.
Posted on Nov 14, 2009
  • 7 more comments
  • Shahid Electronics
    Shahid Electronics Nov 14, 2009
    OK, this Mitsubishi WD-62627 has self diagnostic program and in case of any internal problem, protection will activate and shut down TV. There are three front panel LEDs, “Power”, “Status” and “Lamp”. Which LED is lit, the color and whether it is blinking or steady. Let me know any LED is blinking with what color to find out reason.
    Unplug TV for minute, replug back in, turn it ON and let it complete booting cycle, it will shut down and led will give you error code as said above. I need that info please.
    Thanks.
    a solution?
    I just provide you info and asked few more question. I never asked to accept answer/ solution as we are still in process. Its may be automated system, please just keep posting replies to fix this TV.
    Thanks.
    Right, Lamp light blinking in yellow.
    Its an error code that means either Lamp Cover has not been placed back or Lamp Cover is not fixed properly. There is safety switch in lamp cover area that will be pressed by lamp cover and TV will turn On.
    Please recheck Lamp Cover and make sure it has been fixed correctly.
    Let me know further question, if any.
    Thanks.
    Its OK, I got problem reason in your TV and suggested its solution. Please post back if problem still there.
    Below image shows Lamp Cover that is either not placed back or not fixed properly and causing problem.
    Steady yellow light shows that lamp is bad/ old enough, put new lamp but you have new lamp that means problem is some where else in TV. Since TV is not in front of me so have to exchange few emails/ comments to fix it.
    Below is an image of error codes for this TV, taken from its service manual, that will help.
    There is another procedure to read out error code for techs as follows..
    Pressing the front panel “DEVICE” and “MENU” buttons at the same time, and holding for 5 seconds,
    activates the Error Code Mode. The LED flashes denoting a two digit Error Code, or indicating no problem has occured since the last initialization.
    Note: The front panel buttons must be used, NOT those on the Remote Control.
    Let me know led blinks to determine problem section.
    Are you sure replacement is Mitsubishi original?
    Please take out lamp and put it back carefully to make sure that its in place properly.
    I can email you service manual copy of this TV, if that can help your husband to fix.
    Thanks.
    Shahid Electronics Nov 15, 2009
    I'm here to help you.
    Yes, new lamp can be bad, testing it will clear that doubt.
    Please post further question about TV problem and will be replied gladly.
    Thanks.
    New bulb/ lamp can be tested in similar TV and local TV repair shop can help you to test it.
    Thanks.
Mitubishi wd-73738 turns off after 1 min
Weird noise is high pitched or even grinding sound? Sounds like a fan but is not?
Dec 14, 2012 | Mitsubishi WD-57833 57" HDTV
I have a Mitsubishi WD-62627 DLP. It is six years old. I have had to replace the lamp cartridge twice in the past 18 months. In the past when the lamp failed the light on front of the TV would turn red....
this sounds silly but I had the same problem . due to heat and wear and tear. Make sure the vented air holes are not blocked by dust and the back of the TV is in a well ventilated area where air can circulate.You can use a paint brush and compressed air blowing the debri away from the inside circuitry.
Jul 22, 2011 | Mitsubishi WD62627 62" HDTV
I just put a new lamp in my projection tv.....it is a kdf-42e2000....now there is a pink line on the top of the screen and a blue line on the bottom of the screen......the lamp i installed was a XL2000...
HI ,
I Advise to fixed that Lamp again ( sometime you fixed but one of any wire miss connectivity ).
Or Remove and fixed again all related Jack's you removed lat time.
If everything's OK , then Change lamp. try other one.
Shahzad - IT
DUBAI - U.A.E
Mar 12, 2011 | Sony Grand WEGA KDF-42WE655 42" Rear...
As soon as i turn tv on timer light flashes and even if i push the reset button it will not go off. so tv will not even turn on
did you replace the bulb recently? if so you need to go into the menu and reset lamp controls ...its in your owners manual if you did not sorry thought this might help as i had same issue in the paast
Sep 27, 2010 | Mitsubishi WD62627 62" HDTV
We replaced the lamp in our toshiba tv but only the red steady light and blinking green light goes for 8 times then steady red/green this is the second lamp I have put in with same results-old one really...
you just have to call the manufacture so they can help you reset your tv the tv has to know that you did put a new bulb in there just like your printer asks you did you replace the ink the tv has a simular question. you probaly missed the re-sync question that pops up when you turn tv on and you use your remote arrows to answer its easy the maker of the tv can give you the rest info then you will not have that problem anymore.
Nov 04, 2009 | Televison & Video
Viore model:RPT50V24DX/SMS shuts off and LAMP light blinks
Turn your set around. Locate the square access panel located on the lower right. Remove the 4 screws. Remove panel. Then push down tab on cooling box, it will look similar to a horn. Lift and remove. Lamp will be visible towards the back. Locate the pull handle,it is made of strong wire and it will be folded sideways. Pull open the handle. Look for screw on the left side of the lamp. It secures the lamp in place. Remove the screw completely. Now pull the handle firmly and voila! The lamp will slide out. To install new lamp just reverse the process. NOTE!!! Do not touch the lamp with bare hands. It will damage it. Wear surgical gloves or handle with a cotton cloth...
Aug 26, 2009 | LG 42LC2D 42 in. LCD HDTV
Where can i find the lamp in mitsubishi tv 62"
I ordered mine through Best Buy in CA, where I bought the TV
Jul 11, 2009 | Mitsubishi WD62627 62" HDTV
When I turn on the TV, nothing comes on. No pictures or sound. Red light comes on where it says lamp. Do I need to replace the lamp. Please kinldy advise . Ty
Yes. You need to replace the lamp. Mine did this when my lamp burned out.
You can try pressing <menu> and <device> at the same time, and you'll get a code flashed out to you (tens digit followed by unit digit). You'll likely see one of the following codes:
  • 34 Lamp abnormality
  • 36 Lamp Ballast or exhaust fan failed.
  • 38 Lamp temperature too high
  • 42 Lamp Fan Failed
But the user's manual and the repair manual both say that a red lamp light means your lamp isn't working (most likely it needs to be replaced).
May 10, 2009 | Mitsubishi WD62627 62" HDTV
I've got green spots on my Tv screen
Their is no more you can do.
You probaly waited too long. Your light engine may be damaged. If so, you need a new TV.
You need a professional.
Stop using the TV until it is repaired.
Call the manufacturer to find you nearest authorized service center.
MR. TV Sales & Service Inc
Milwaukee Wisconsin 53405
(414) 762-8600
Established 1974
Mar 24, 2009 | Panasonic PT-52LCX66 Projection Television
No picture
First thing to do is check the lamp... i know that sound basic but it is always the first question at the shop
Aug 08, 2008 | Mitsubishi WD62627 62" HDTV
Televison & Video Logo
47 people viewed this question
Top Televison & Video Experts
Electro Med Services...
