Question about Cell Phones
Phone just turned off..i got it back on once..it went off again & won't come on.also felt like it was getting hot.
  • 749 Answers
Hi, you can try a hard reset, simply take out the battery for 30mins and put it back in. If this does not solve your problem its most likely the battery that will need replacing.
Hope this helps
Muzzi_123
Posted on Nov 14, 2009
What causes the hold indicator to go on. When I shift to drive 3 the hold button comes on and the gear doesn't Shift. This morning I cleaned the air filter sensor and it went off, it shifted to 4th gear...
If I'm correct-- you asked yesterday & a woman gave you
a great answer about the hold feature on the dash
Now I will tell you that all along -- I felt you had a transmission
problem & most likely an internal one & a very very costly repair
coming
All anyone can do on this site is guess at these questions
You I assume have continued to use the vehicle & may very well
have ruined not only the trans, but any chance for a simple less
expensive repair (I did once own a trans shop) Very Very few
do not come out & get rebuilt, once they act up & continue to drive it
Nov 25, 2014 | Cars & Trucks
Ford taurus 2001 car start but once the car is cut off it won't start up again until it cools off the car is not running hot.
After you kill it, when you try to start it back up, does the starter turn the motor? Or is it froze up (will not turn over)?
Mar 12, 2012 | 2001 Ford Taurus
Dried some clothes the other night and when I went out to take the clothes out the next morning the dryer was hot on the top and in the back of the control panel. I unplugged the dryer and took the top...
More than likely, the motor centrifugal switch is stuck. You should be able to turn off the element with the timer control switch. If the timer switch is on and the dryer is not running, the element should be off, unless the motor contact is stuck closed. You will have to get to the motor and 'un stick' the contact.Its a bit tricky, you may need help.
Jul 21, 2009 | Kenmore 62802 Electric Dryer
Set wont turn on, Beeps.
Try Resolder all of the Big Diodes around power supply.
Feb 18, 2009 | RCA P52960 52" Rear Projection Television
My amp stays in protection mode
Does it go into protect in the vehicle if you disconnect the speaker wires from the speaker terminals of the amp?
Nov 29, 2008 | Sony XM-2002GTR Car Audio Amplifier
Dryer stays hot hours after using it
The heater has failed and/or is shorting to the case. Remove the rear panel. The heater is on the right side, attached to the heater housing with two screws.
Jun 25, 2008 | Kenmore 62802 Electric Dryer
Cell Phones Logo
21 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
