Question about Olevia LT32HVM 32 in. LCD Television
Bright Screen, very little contrast or color comming thru LCD.
Went to mount the screen on the wall, and also had a problem shaking the screws out of the base mount. After mounting and leveling the screen on the wall it seems like the lamp is in front of the LCD's instead of behind it. When I pushed on the bezel corner to tilt it the wall mount, it restored the the image for a few days the way its supposed to look. Now its back to the same look. It seems as if the brightnees is turn up all the way.
  • sparkytoo Jan 10, 2008
    I tried adjusting color temp, and brightness and all of that and it did not fix it.
  • lenzo Jan 11, 2008
    it seems like the color is off like red is a real deep red and has a green tint to it.
Just go to menu on remote/then go up or down on the remote located around the enter button till you see picture press enter/ then go up or down till you see color temp set it at 6500 press enter that should take care of the problem
Posted on Jan 09, 2008
My screen broke moving on my sony flat screen. Tv
I would try contacting<a href="http://www.tvvideorepairil.com">flat screen tv repair in Chicago, IL</a> because that's where I went when mine broke.
Oct 03, 2013 | Universal 40-42 Inch Flat Screen Panel...
Hi I have a digimate tv model modl lt321c2m1 and I am wondering if I can mount it on the wall. Can I?
Please look on the back, there should be 4 mounting holes (for Metric screws) Iin what is called VESA mounting pattern. Just measure the pattern.
http://en.wikipedia.org/wiki/Flat_Display_Mounting_Interface
When you buy the mounting bracket, it will come with a bag of Metric mounting screws to attach your TV to the bracket.
Jun 13, 2011 | Digimate DGL32 32 in. LCD Television
Contrast is way too bright, not screen brightness, contrast. is there a contrast adjust button?
Right click on your main screen. Go to properties, or graphic properties, then you will find there is a contrast adjustment within. Usually under color correction.
Mar 24, 2011 | Toshiba Portege 4000 Notebook
Princeton 19" went from bright white to dull white
david78910, First disconnect and reconnect the monitors VGA plug from pc vga port a few times to make sure of good connection at the port. Report back here with results! If that doesn't fix your "pink screen" symptom, then possible bad inverter supply inside unit or the CCFL tubes may have lots and lots of "on" hours use on them and need to be replaced. Yes, you could also have bad (almost dead) switch-mode-power-supply inside unit if "known-good" monitor works perfectly with your pc. 12fixlouie
May 20, 2010 | Princeton Digital VL1916 19" LCD Monitor
How do I remove the stand to mount the TV on the
the TV will mount to the wall via the VESA screw mounts on the back of the LCD. If it is a smaller, monitor sized LCD then the screw pattern will be either 75x75mm or 100x100mm. On larger TVs is it usually 100x200mm. Sometimes the base is screwed into this mount and othertimes to the bottom. Simply unscrew it from the screen. Be sure that the wall mounting kit can handle your LCDs VESA screw pattern, screen size and screen weight.
Feb 07, 2010 | Televison & Video
I have a 37
Metric M5 screws, the wall you buy will be supplying with mounting hardware.
http://www.toptvmounts.com/
http://www.mountsdirect.com/
http://www.mountsmadesimple.com/
Just Google " wall mount for xxxxx"
Nov 24, 2009 | Televison & Video
Burnt out LCD B&W screen on Northstar 951X GPS.
Electro Mavin (mavin.com) sell replacement new unused Optrex DMF-50174 Displays units for $25.00. Order one.
Take small screws out of the back of the Northstar 951x and carefully remove the cover, disconnect the old display unit (just one ribbon, one power connector and two screws).
Replace the display with the new one.
Replace cover and screws.
Now take your loved ones on a small holiday with the money you just saved yourself!
Sep 19, 2009 | Northstar 951XD GPS Receiver
L13V36 Dark Screen, picture can be seen in bright light.
If the backlight lights up for a second it's probably fine - It lay odds on the display inverter in the screen. Actually finding parts for anything made by gateway may be difficult, however. They do not sell spare parts. Considering the size of the LCD i bet it would almost exceed the replacement cost of the screen to repair it
Dec 30, 2007 | Gateway FPD1960 19" Flat Panel LCD Monitor
TV shuts off with high color images . Example: explosions,bright lights etc
Normally, the screen control being up a little to high, would cause this problem. If no one has worked on this unit when it started may be a sign of something else, for example, the 200 volt line may be running a little low. Check the brightness and contrast for starters and if that doesn't help, then, the screen control would be my next step. Hope this helps.
Jun 03, 2007 | Mitsubishi WS-55809 55" Rear Projection...
Olevia LT32HVM 32 in. LCD Television Logo
75 people viewed this question
Top Olevia Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you an Olevia Televison and Video Expert? Answer questions, earn points and help others
