Onkyo receiver HT-r340 with no sound turns off, standby flashes
I have an onkyo 5.1 receiver (HT-r340) and the problem y that no suond comes out of the reciver and no matter what I do nothing happens and then the receiver automatically turns off and the stanby lucght flashes. Any suggestion ?
5 Suggested Answers
  • 3 Answers
SOURCE: onkyo HT-R560 receiver
The unit most likely blew up a capacitor. If you look in through the slots on the top of the unit you should see 2 big black caps (C6901 and C6902) with shiny silver-ish tops. I should also point out that you probably flew up a 125v 8A (F901) glass fuse on the board that the AC cord plugs into. The glass fuse can be found at Radio Shack, but the caps are a bit more troublesome to find. They are 10,000uF 69v and thats just not a standard part, so you may need to up the voltage requirement and buy a 75v cap. Total to fix the amp yourself: Should be about $35 with shipping.
Posted on Nov 07, 2009
  • 5 Answers
SOURCE: My Onkyo HT-R510 will shut down after several
Might be over heating. Make sure you don't have anything sitting directly on top of it. I even put a little fan blowing outward at the back of my system to keep it cool.
Posted on Feb 13, 2010
  • 23 Answers
SOURCE: receiver shuts off at higher volumes
The receiver may be too under powered for your speakers or the speaker ohm's may not be matched for your amp.
The reason it is shutting off is likely because the amp is becoming overloaded. At lower volumes the amp can handle the load of the speakers, but at higher volumes the power supply of the amp can't keep up with the power demand the speakers are pulling.
If you were previously able to turn the reciever high without turning off, then there is likley something wrong with the amp or possibly a blown speaker.
Try measuring the resistance of the speakers if you have access to a multimeter. They should normally read 8 ohms for home speakers, but some common home speaker impedances in order from (I'm assuming) most common to least common are are 8, 4, 2(bose), and sometimes 10 or 12 ohms. The lower the number of ohms, the more power the amp will need to put to the speakers and the more chance you could be overloading your amp.
Posted on Mar 30, 2010
SOURCE: I CAN'T GET MY ONKYO HT-R340 AV RECEIVER TO TURN
I have the same problem during years, I have the same av rereiver and the device switchOff (even in standby). The red led is not visible. During several hours, rare time minutes it is blocked.
I sent it, the last year to the official technical service and they said me that nothing matter with it!!!
The worst buy made by me, goodluck, if you have solution I will be pleasure of your information
Juan Luis Santiago
Posted on Feb 05, 2011
When we watch a tv there is no sound my home theater
Hi Violeta, sorry for the delay in responding. When you say "when we watch TV there is no sound", are you using the TV's built in applications? Please email me directly at askOnkyo@us.onkyo.com, Thanks, JT
Mar 09, 2015 | Onkyo Ht-r340 A/V Receiver
Onkyo ht-r530 subwoofer stopped working
Turn the out put leval down on your sub, End the reciever, I was turn up to high,End that will cause it to cut out.
Oct 20, 2012 | Onkyo Ht R530 Receiver 7.1 Surround Sound...
Black and white picture from blu ray player
Run the Blue Ray straight to the TV and see if the picture is still in black and white. If it is you know that your reciever is fine and the problem lies in the player or the TV. If the picture is normal then you probably have a bad HDMI IC that will need to be replaced.
May 09, 2012 | Onkyo TX-SR607 Receiver
I CAN'T GET MY ONKYO HT-R340 AV RECEIVER TO TURN ON, IT WAS WORKING FINE , STANDBY LIGHT IS ON BUT DOES NOT TURN ON. ANY SUGGESTIONS?
Juan Luis Santiago
Sep 09, 2010 | Onkyo HTR500 Receiver
I have an Onkyo HT-R8230 receiver and I can not get any sound out of the center channel or the subwoofer. The sub will not even power on. It stays in the standby mode and there is no manual on/off button...
The manual is available at retrevo.com.
If you don't have the center and sub defined in the Onkyo they will never work. See page 20.
If that is all set and you still have problems...
To prove the center speaker works, connect it to one of the front channels.
To prove the sub works, connect it via RCA cable(s) to the Tape Out and play something containing deep bass. You should see it come out of standby and hear something, albeit only the deep bass.
Aug 03, 2010 | Onkyo HTR500 Receiver
I have an Onkyo HT-S6100 home theater not sending picture to TV.
I just fixed mine with the same problem. Apparently, the HT-R667 and 606 receiver that comes with 6100 has a problem with the HDMI board. Onkyo wanted $500 dollars to fix it, costed me $16. Here's how to fix it. http://www.highdefforum.com/high-definition-receivers-recorders-players-tivos/121956-repairing-onkyo-htr667-aka-606-a.html
and the youtube vid: http://www.youtube.com/watch?v=gj0x5S9ez5U
Good Luck!
Apr 04, 2010 | Onkyo TX-SR605 Receiver
Onkyo ht-r670 receiver is new and will not turn on. red standby light is on. but no display. also remote doesn't have any effect.
I would check any fuses first. The power transformer could also be open.There is a stanby supply that provides 5 volts that is always on . This is what supplys voltage for the standby light and the cpu. When you press the power button the cpu trips the power on relay that provides the 120v ac to the main transformer. If the transformer is open nothing happens. Onkyp part # is 2301798. Check the windings for continuity.
Dec 31, 2009 | Onkyo Audio Players & Recorders
Dec 04, 2009 | Onkyo TX-SR501 Receiver
Onkyo receiver (HT-R430) cutting out after a few seconds
This problem is related totally to the remote control.Pres the CRL button rapidly during that 3 sec interval and get the nunmber down
Nov 12, 2007 | Onkyo HT-S680 System
600 people viewed this question
 Grubhead
Grubhead
