Question about Microsoft Xbox 360 Controller
Xbox 360 wireless controller keeps disconnecting during game.
Hey look at the battery holder and in the middle of it there's a hole with a bit of metal (or there should be...) that bit of metal makes circuit at the bottom of the battery's...
long story short fold a small bit of paper (bigger enough to pull out again..) and put in hole (over metal bit) so the plastic bit on the controller can push the metal down enough.
you can test this with your tongue, tongue on battery's and push on the metal you should feel the electricity when you push on it ;-)
Posted on Dec 02, 2009
My wireless controller seems to be defective every time i start my xbox360 the menu always goes up like someone is pressing the up button of the controller is this a common bug??
Posted on Dec 12, 2009
Handling the control too tighty or making sharp and sudden button presses causes permanent damage to control leading to this problem
Posted on Nov 28, 2009
    Problem Solver:
  • 5 Answers
If your using a wireless pad, soudns like dead batteries, just replace the batteries and your away.If your using a wired pad then its a dodgy connector and would probably be easier to take it back to the shop if its still under warrenty. If your good with electronics you could buy a wired controller from somewhere that doesnt have any wire problems, just summin like dodgy buttons, then consider replacing the wire from the dogy button to the dodgy wire pad. Its probably easier than going and buying another pad. Cant trust dodgy abdel these days >>
Posted on Nov 17, 2009
2 Suggested Answers
SOURCE: wireless controllers for xbox 360 disconnect at random times
It sounds like there is a probem with the RF Board (google search it). Problems occur with this from time to time when a sytem is disassembled and reassembled.
Posted on May 19, 2010
How do i reactivate the wireless controller to my xbox 360
How to Configure an Xbox Controller Fotolia.com"> configure-xbox-controller-800x800.jpg Configure you Xbox controller.
The Xbox 360 utilizes two types of controllers: wired and wireless. Like most operations on a video game console, configuring a controller requires little effort. You can either plug the controller into a port on the Xbox 360, or sync a wireless controller using the console's built-in controls.
Difficulty:Easy Instructions
  1. Wired
    • 1 Connect the controller's cable to the in-line release cord. This cord prevents you from accidentally pulling the Xbox 360 along with your controller during game play.
    • 2 Insert the in-line release cord's USB plug into the USB port on the front of the console.
    • 3 Turn on the console to activate the controller automatically.
    Wireless
    • 1 Insert batteries in your wireless controller, if necessary.
    • 2 Hold down the "Guide" button on the controller.
    • 3 Push the Xbox 360's "Connect" button, located on the front of the console.
    • 4 Push the controller's "Connect" button to sync it with the Xbox 360.
Read more: How to Configure an Xbox Controller ' eHow.com http://www.ehow.com/how_7780486_configure-xbox-controller.html#ixzz1PRsAYmUA
here is a video on how to sync your wireless controller to your xbox360 console
http://www.youtube.com/watch?v=GpV-b1de2lM&feature=related
if you think this help please rate me sir thank you so much!!!
Jun 16, 2011 | Microsoft Xbox 360 Console
Tip
Get wireless Xbox 360 controllers to stop disconnecting
By disabling the vibration on the controller, you can keep the batteries in place and the controllers will disconnect less often. If you want to keep the vibration feature on, then use some tape to secure the batteries in place before you put the cover on.
on May 15, 2011 | Video Game Consoles & Games
Keep losing connection with controller and console
try getting new batteries if you have a rechargeable battery pack plug in the charger then dissconnect. If this doesn't work it could be two things either your controller or the 360 cant sent out wireless signals for yor 360. To fix this try a different controller or send it in if you still have a warrenty
Apr 11, 2010 | Microsoft Xbox 360 Console
Wireless xbox 360 controller keeps disconnecting when i fire or get shot evertime whats the problem
I've had this same problem with a few controllers. It's your battery. Well, more specifically the container of the batteries. Chances are, it's lose.
(I would have to keep holding mine firmly in place, while playing games.) The reason it disconnects when you get shot is cause of the controller vibrations. It makes your battery jump out of place, due to not being held in place firmly.
My suggestion would be to either buy a new battery container, or turn vibrations off.
Hope this helps.
Feb 02, 2010 | Microsoft Xbox 360 Controller
Xboc controller constantly disconnects from console
If the controller is continually disconnecting from the xbox, the battery is probably dying. Have you tried installing fresh batteries into the controller ?
Nov 16, 2009 | Microsoft Xbox 360 Wireless Controller
Wireless controllers for xbox 360 disconnect at random times
Jul 18, 2009 | Microsoft Xbox 360 Controller
My xbox wireless controller keeps turing off wheN CHARGED
it could be one of many things,
1)battery wont hold its charge
2)if the bottom corners of the battery pack holder are cracked it will keep disconnecting
3)could be controller.
Jul 04, 2009 | Microsoft Xbox 360 Wireless Controller
Controller keeps disconnecting (not Live) pausing the game
if its wireless try changing the batteries, if its wired get a new controller because the wiring is loose.
May 14, 2009 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Controller Logo
2,315 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
