Question about Whirlpool Duet GHW9150P Front Load Washer
Washer blinks F 11 - Whirlpool Duet GHW9150P Front Load Washer
  • 4 Answers
Below is what the manual recommends. I have a friend who had this same problem, he had to purchase a new control board, as the connectors had become dislodged from the board. he tried to resolder them, only to have the problem re-occure again a few months later.
Google "washer duet servicemanual.pdf" for the tech manual. SP
Serial Communication Error
Communication between the Central Control Unit (CCU) and the Motor Control Unit
(MCU) cannot be sent correctly.
Potential Causes
• Check Wire Harness connections to the MCU, the motor, and Central Control
Unit (CCU)
• Check the Drive system for any worn or failed components
• Check MCU
• Check CCU
• Check Motor
Posted on Nov 15, 2009
Blinking lid locked light and green sensor light on machine won't start cycle
The good ol' Whirlpool Lid Lock Flashing Light Problem - ApplianceBlog
www.applianceblog.com/.../42456-The-good-ol-Whirlpool-Lid-Lock-Fl...
Dec 11, 2013 - 10 posts - ‎3 authors
Red Lid Lock light flashing intermittently when you try to start a cycle. ... I'm going to post what SENSING does first, then you will need to locate your tech. ... start with thelid lock on and blinking, or the unit will not start and spin. FIXED Sense light on light humming noise won't start ...
Aug 9, 2015
Whirlpool WTW4950XW not working
Nov 2, 2013
Stacked GE washer/dryer lights Blinking doeent start at ...
Feb 20, 2012
More results from www.applianceblog.com
Washer Sensing led (Green) on with the lid locking led (Red ...
www.shopyourway.com > Manage My Life > Questions
... this: Sensing led (Green) on, the lid locking led (Red) blinking with a clicking noise ... red led light goes off green led light stays on and the washer does not start.
Oct 27, 2015 | Washing Machines
Main spout emits water. Side spouts do not. After just a few minutes, light blinks 11 minutes on and off. Cause?
Thank you for your inquiry, Judy Mudgett!
From the information you have provided your Frigidaire washer is displaying 11 minutes and lights are blinking. Sounds like you may have a possible issue with your control panel or miscommunication. I would suggest resetting your washer and you can do that by unplugging the power cord for roughly ten minutes. If you continue to have a problem with your display I would suggest having a professional technician come out and perform a proper diagnosis and repair. Hopefully this is helpful. -Matt
Feb 19, 2015 | Frigidaire Affinity Series FAHE4044MW...
Hi, i have a problem. My Sony Trinitron (kv-29cl11k) tv tries to turn on and then click out and the stand-by light just blinks. This has been getting progressivly worse. It is like a relay will not stay...
11 blinks do not occur to Sony Trintron TVs. It should be 10. Ten blinks - Check Q8014 and Q8013 for shorts, leakage, or bad solder connections on the " D" board. If the transistors are bad, check R8051 and IC8005, also on the "D" board. If you wish to get more details about these blinks, check the site linked here. Blinking codes and fault detection to many brand TVs, including Sony are given in detail. These blinks are called, blinking codes, and fault indications. From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside it. Check the site, and get more details. http://electronicshelponline.blogspot.com/
Pull up previous posts or type in the brand name and model number to of your set, to its search box, and press 'Enter' or view it in Mosaic / Timeslide option.
Aug 28, 2013 | Televison & Video
Panasonic Plasma standby button flashes 11 times
11 blinks Fan SOS PB Board. 11 blinks of standby light to Panasonic Plasma indicates a fan trouble. Check it. If you want to know more, check this link.
Jan 12, 2013 | Panasonic VIERA TH-42PR10 42 in. Plasma TV
E25
hello,
All error codes start with the letter "E". An error code of E11 will have the five indicator lights flash once and the Start indicator light flash once.
Some models of Frigidaire washers come with a digital readout display that informs the operator of the unit's function and any errors.
Error codes indicate that a problem has occurred and should be addressed. Different models of Frigidaire washers may vary in their fault displays.
Some washer models use flashing lights at the unit's start, door lock, wash, rinse, final spin and control indicators to display error codes.
If the five indica
tor lights flash more than nine times, this signals a letter in the error code. The letter "A" stands for 10 flashes, "B" for 11, "C" for 12, "D" for 13, "E" for 14 and "F" for 15 flashes. An error code of EB2 will have the five indicator lights flash or blink 11 times, and the Start indicator light blink twice
hope this help?
thanks.
Oct 23, 2010 | Dishwashers
F/ll blinking is there a switch in case of flood?
If you had a flood and any water got into bottom of machine, you have probably shorted out a motor control board. These board are either in the lower back right or front left corner bottom. A qualified service tech should be called to do this repair.
Feb 02, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Sony trinton 27inch red light blinks 11 times
those LED flashhing codeds are useless. You most likely have a problem in the high voltage circuits. You should bring that one to a local shop as it's very nlikely you can fix it yourself, and the high voltage circuits are dangerous.
Nov 06, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
HE2 Plus blinks F-11
Look for the technical brochure. Mine was on the lower kick panel taped inside. I would not take off the back panel first. Maybe the top or the lower front if it is a front loader. It tells you how to do diagnostics and what the codes mean.
Jul 22, 2009 | Kenmore HE2 Plus Front Load Washer
Whirlpool Duet Washer has done GREAT for two years..now suddenly,
this means your drain pump is clogged--- there are 3 screws at the bottom of the lower front panel. Remove these screws and there is a drain pump cleanout located in the middle. Twist this off by hand can clean out the debris--- WATCH OUT LOTS OF WATER will come out so have towels ready.
Jan 19, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Sony tv kv24ls35u 11 blinks
Sony does not have 11 blink code it only goes to 10 blinks. You can Try self-Diagnostic mode- Press---- display,5,vol- then power when set comes up it should have codes telling you which circuit has problem.
Jan 03, 2009 | Sony KP43T75GRAY 43" Rear Projection...
Whirlpool Duet GHW9150P Front Load Washer Logo
101 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
