Question about Eureka 2586 Upright Steam Vacuum
Have a Eureka model 2596 steam cleaner vacuum that leaks the soap out. any idea what is wrong?
reddevil6
  • 1673 Answers
SOURCE: Leakage from eureka deep steam carpet claeaner
You will just have to take it apart to see if a hose is loose, came off, or is cracked.
Posted on Jun 17, 2008
  • 21 Answers
SOURCE: Looking for the instruction manual for the Eureka
Go to http://www.eureka.com/service/manuals/80244.pdf this is a direct link to the owners guide for your model or you can call customer service at 800-282-2886 and request a hard copy
Posted on Jul 19, 2009
nwj2468
  • 76 Answers
SOURCE: new Eureka 5893 BVZ looses suction
eureka is about the most helpless website ever!!! did u try cleaning the filters?
Posted on Aug 22, 2009
  • 3 Answers
SOURCE: I want to replace the belt on an upright eureka
I just replaced the belt on my 4481. Very simple. Be sure unit is unplugged. Unlock handle and let it lay down. Remove two screws on plastic cover. I purchased my belt at target for 2.54. Part number anywhere is Eureka U. Remove the roller brush. Loop belt around drive motor first and then around roller brush inserting the roller back into place belt side first. Replace cover and your ready to go. 10 min fix.
Posted on Sep 04, 2009
SOURCE: No suction or spray - Eureka Atlantis Steam Cleaner
I got the machine working. I think because it hadn't been used for awhile that the seals were dried out. I wet them and let it sit for awhile and then I could push the containers all the way in and seated them properly. Then it started working no problem and I got to clean my carpets.
Posted on Oct 06, 2009
Where can i get the shampoo? Can i find the owners manual online?
you should be able to get the shampoo at wal-mart and any place else they sell the steam cleaners. You do not have to use the eureka shampoo for this unit, however, it is more recommended.
I mean you can use the hoover, and dirt devil shampoo if you can find that, or something generic. Because the machine is mixing the soap for you with the water, anything will work.
As for the owners manual, you can get it here.
Nov 19, 2010 | Eureka Atlantis 2595A Upright Wet/Dry...
Oct 05, 2009 | Eureka Atlantis 2591A Upright Steam Vacuum
Does it matter what kind of cleaner I use on the Deep Cleaner Model F5821
Yes it does matter which cleaning solution that you use in your steam cleaner. If you use the wrong cleaning solution it may cause problems with the cleaning solution dispensary system. Different steam cleaners use different cleaning solutions. You should always use the steam cleaner solution for your specific cleaner. I have learned this the hard (and expensive) way.
Hard to recommend this but it will work in a pinch. You can use a small amount of liquid laundry detergent diluted with hot water (about 2 table spoons to a gallon) as a stand in for the real deal. DO NOT put the laundry soap solution into the cleaning solution reservoir (the wax content will clog the soap dispensary system). Lightly apply to the area to be shampooed (do not soak). I have used a plastic coffee can with holes poked in the lid like a watering can to apply the soap solution. Use the shampooer to do the scrubbing and remove soapy water from the shampooed area. Fill your soap reservoir with clean hot water. The laundry soap does most of its job during the rinse. Go over the shampooed area with the shampooer moderately soaking the shampooed area to with the hot rinse water. Remove as much of the rinse water as possible. Liquid laundry soap has a high wax content (makes your cloths soft) and if it is not rinsed thoroughly after it is dry the remaining wax will attract dirt faster than the surrounding areas. Other than that it works for a good stand in for the proper detergent in a pinch. As a bonus it smells great.
From what I understand as unorthodox as it is, it works well in small doses, and I don't believe that it causes any damage to the other parts of the steam cleaner as steam cleaners survive drawing up worse things into them than laundry soap.
I hope that you find this helpful
Good Luck!
Jul 28, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
New Eureka 5893 BVZ looses suction
Jul 05, 2009 | Eureka 5893AVZ Bagless Upright Cyclonic...
Bissell steam cleaner model 9300 not putting out soap
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
,b..,
May 14, 2009 | Bissell ProHeat Turbo Deep Cleaner Upright...
Jun 14, 2008 | Eureka 2576A Steam Vacuum
NEED MANUAL OR INSTRUCTIONS FOR DURABRAND DUAL POWER VACUUM/BLOWER
I have an Eureka Atlantis Opti Heat Carper Shampooer Model 2596. I do not have an instruction book. What I need to know is how much carpet cleaner & water to mix together.
May 02, 2008 | Vacuums
Leaking Carper Shampooer
I have an Eureka Atlantis Deep Steam Extractor and it does the same thing. It's not new but it hasn't been used much.
The manual says to "push the tank in until it snaps into place". Everything looks fine across the board so I believe this particular model is just a bad design overall.
My recomendation: Get a new carpet cleaner from Target or Wal-Mart.
Please let me know if this helps. Good luck!
Feb 28, 2008 | Eureka Atlantis 2595A Upright Wet/Dry...
Eureka deep steam cleaner
When these stop picking up water, I assume it is spraying the water out, is because of a missing seal, where the suction port is, or a filter is clogged. Tank isn't set down like it should be.
Jan 02, 2008 | Vacuums
Eureka 2586 Upright Steam Vacuum Logo
48 people viewed this question
Top Eureka Vacuums Experts
JoeVacs
Alan Matzke
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
