Question about Acer Aspire 5315 Notebook
I have an acer laptop and it is not turning on . the battery charger is plugged in and the charger light is on . help?
  • 2,567 Answers
There could e a problem with the battery. A fast check to determine whether you have a problem with the power adapter, power cord or the laptop's battery is to turn off the laptop, remove the battery, connect the power adapter, turn on the laptop & see if it works.
If the laptop works directly from the power adapter with the battery removed, then the power adapter is good. In this case we can suspect that the battery is defective & needs to be replaced.
Try also to reseat the main components of the notebook: the battery, the AC adapter, the memory modules, & the hard drive.
After that try switching it on & see if the problem was fixed.
Posted on Nov 14, 2009
I used it the night before it was fine i plugged in the charge and it wont turn on at all
laptop charger for acer aspire 3600 3680 series 3650 3610
www.amazon.com/LAPTOP-CHARGER-ACER-ASPI...
Amazon.com, Inc.Amazon.com: LAPTOP CHARGER FOR ACER ASPIRE 3600 3680 SERIES 3650 ...When I was looking for a charger cable for my laptop, i was not sure whether I ... it was really good and worked, it heats up a little bit but for now its working ...
When your acer aspire 5738 z laptop adapter is not working ...
docslide.us > Business
Aug 18, 2015 - When Your Acer Aspire 5738Z Laptop Adapter is Not WorkingA ...Quicker Charging of Laptop Battery with an Acer Aspire 3600 AC Adapter ...
batteries-store.pblogs.gr/.../when-your-acer-aspire-5738z-laptop-adapter-...
Jan 14, 2016 | Acer Aspire 3600 Laptop Charger...
Acer aspire one shows no power light when charger is plugged in...charger shows 6 volts
Hello, I'll do my best to help you out.
The Acer One have one weird problem, and that is of the mother board. "Naaahh, how can that be?" you may ask. The BIOS in the motherboard have a bug, in which in a certain amount of time it will shut down the Netbook and it will give you the impression that it's dead. But it isn't. As you posted it here, the power supply is working fine. I'm not sure if it's still available, but there is a patch, which it will allow you to flash and fix the Netbook. Now, I'm not able to share the patch with you just because there is no detIl on your Netbook, for example, I own an Acer One ZG5. If yours happen to be the same exact model, let me know and I'll do everything I can to share the patch with you and how to flash it.
Mar 24, 2014 | Acer Aspire One PC Notebook
Not charging Acer Aspire 5732z, now won't turn on!
If it does not work with the Charger while the battery is out then I would say either your charger is bad, the dc power jack where the charger plugs into the laptop is bad or you've got motherboard issues. Does the charger have a light on it to indicate that it is on when plugged in the wall? Do you see any lights when you plug the charger into the laptop?
Take an ink pen and see if the little pin inside the computer where the charger plugs is loose and moves a bit. If so that is probably your problem. If the pin is tight and the charger works, then you've got motherboard issues.
Mar 29, 2012 | Acer Aspire Computers & Internet
I have acer aspire 4551 where if I press the power button on the screen will not turn on, only power LED that lights up while the other led is not lit. I've tried to do the bios update by pressing the...
JUST REMOVE THE BATTERY FROM THE LAPTOP & ALSO THE CHARGER. LEAVE FOR 5 MINUTES THEN REINSERT THE BATTERY AND THEN CHARGER. NOW TRY TO START IT . SHOULD WORK. ELSE PLS REPLY
May 15, 2011 | Acer Aspire 4551 Notebook
Hi i have a acer aspire 5100-5674 laptop, i was using the computer when i saw the orange light meaning low battery, my computer was plugged in however... the next minute i know everything got turned off...
The first step is to check both the charger and the battery at a shop. If both are good then it could be a connector problem where the charger plugs in
Aug 16, 2010 | Acer Aspire 5500 5570-2609 Laptop
I HAVE A LAPTOP ACER AND THE POWER DOES NOT TURN ON
It could be a battery problem. Try switching to AC mode by plugging in to an AC outlet using your Acer power chord (battery charger also). If the charger led don't light, it means it's defective and it can't charge your battery. Please try another power chord or battery charger then. Just remember to take out your battery when using your laptop in AC mode to lengthen your battery life. Regards!
Jul 05, 2009 | E-Machines eMachines Desktop PC
I CANNOT OPEN!!!
Hi, Try running you laptop with the battery and the AC adapter. If by plugging in your adapter there is no light indicator likewise or no powering up, then presumably there is a problem with the power supply circuitry in the motherboard. Normally the laptop should work with just the adapter, just the battery or both the battery and the adapter. If it will not perhaps your best bet is to seek professional repair service since this would require opening the motherboard. In most instances, this involves an smc fusible link, regulator transistors or even just cold solder or loose connections. Hope this be of some help/idea. post back how things turned up or should you need further information. Good luck and kind regards.
Sep 24, 2007 | Acer Aspire 5500 5570-2609 Laptop
Acer Aspire 5315 Notebook Logo
80 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
