Question about Canon EOS-5D Digital Camera
Trouble with my Canon 5D
My charger is saying that two of my batteries are fully charged but they are not registering in my camera that they are charged. Is it the charger? Or could it be my camera? Or both batteries? I just recently switched from using my grip to not. Could that have screwed things up? I guess I'll have to buy a new charger to see if that's the case. Has anyone ever had this problem and it turned out to be the camera and not the charger/batteries? I guess I'm just wondering if I should send it in to Canon.
Thanks so much!
Cheers,
Missy
    President:
  • 2,761 Answers
Your problem may be due to weak/worn out batteries or corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, your batteries may need to be replaced, or the camera may have a problem that requires professional repair.
Posted on Nov 15, 2009
Mark iii 5D will not turn on- battery is fully charged. I have tried taking the memory card out, battery out, lens off, etc and then replacing all of the above and restarting, but nothing happens.????...
And you are sure the fully charged battery also has enough capacity to power the camera? or it only reached a certain voltage so the charger says it is charged?
Also did check the contacts on the battery and in the camera?
Make sure the battery has enough power, by measuring the voltage with a multi meter. The voltage should be higher than what is printed on the battery.
Mar 15, 2015 | Cameras
Battery charging
Depends on how much the battery is in use, and how much battery life is left.
If it's relatively new (3 years old) and fully empty, it could be full by 2 hours - 2 h 30 min. If it gets really hot before that time, it's full by then.
Mar 06, 2014 | Konica Minolta Dynax 5D / Maxxum 5D...
How many hours do I need to charge the battery of a new canon camera?
It depends on what camera battery, but usually about 2 - 3 hours. (The LC-E6 battery that comes with the 5D Mark II, charge time for a new battery is 2.5 hours). The canon charger should blink green while charging, then go to a solid green when the battery is charged.
Feb 14, 2011 | Canon Cameras
I have a Canon G5 and am on my third set of rechargeable batteries (I bought an extra Canon rechargeable battery when I purchased the camera and then 2 Canon brand replacement batteries when the first 2...
Thank you for such a detailed description, wishing others would take your lead. To the problem camera designated batteries (other then AA rechargeable) have always been a bit of a sore spot for me because the user is compelled to purchase a specific battery. As much as I prefer the name brand accessories for the camera there come a point where you just gotta venture forth with third party accessories. There is nothing wrong with using an "off" brand in fact what I've found is that is some cases they are a better battery. Again back to the problem. I grasping thoughts on how to word this but, here goes. As much as the manufactures would like you to believe that these batteries do not form a memory they do. Also the battery can trick you into thinking it's fully charged when in fact even though the charge light is saying completed it's only got about 1/3 charge. I've worked with Canon's BP 511 and now the "new" BP 511A for many years The BP511A or equivalent is the better battery. What needs to be done is to drain those batteries down until they stop, let it cool don't take it from the camera to the charger. Time the battery when you put it on the charger, meaning not to the second but what you would "normally" do is plug the battery into the charger and leave it right. Well what's possibly happening is that within ten minute the ready light is coming on, (something stupid going on in the battery) So check the battery stat of charge after say 15 minutes and if it says it ready (drum roll please) remove the battery unplug the charger for a few seconds and place the battery charger back onto the wall outlet and plug the battery back into the charger and look at your watch again. I've had to do this as much as three times until the thing would get the idea it was to take a charge "normally" about 2 hours will bring it back up. There is no device I've found to completely drain one of these batteries so over a period of time in your case one year the batteries begin this fit. I've since replaced the BP511 for the better BP511A's or equivalent. I'm not pointing a finger because myself and staff do the same thing and pull the battery before going to a shoot if it's showing partial discharge and the thing gets put onto charge and we start this cycle all over again. Be careful of the charger as well meaning don't just disconnect the battery and put it back on charge when it's going the cycle thing disconnect the charger from its power source as well because it holds a memory for a few seconds and will just shut off in a few moments if you don't.
Long story but I've been doing this now for 9 years since the dawn of Canon's 30D Cheers
Jan 16, 2011 | Canon PowerShot G5 Digital Camera
Camera will not power up, no lights no beeps nothing, the battery is fully charged and I have replaced the CMAOS battery
Is this an older camera? Is the battery the original? Has it been unused for a lengthy period of time and allowed to completely discharge? It may be dead even though it registers charged in the charger. Clean the battery contacts in the camera with a cotton swab lightly dampened with rubbing alcohol.
Dec 19, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Canon 5d lcd
If its a year, request that canon fix it free of charge under its warrenty.
Charge the battery, and or buy a new battery to see if its fixed. Bestbuy if there is one close to you is the first place I look for a battery.
May 20, 2009 | Canon EOS-5D Digital Camera
My battery charger shows (green) fully charged when it is dead
THis is really a sign of a bad battery that is always being detected fully charge but its really drian , so it will be better for you to replace that battery.....
Dec 01, 2008 | Canon PowerShot SD550 / IXUS 750 Digital...
Canon EOS-5D Digital Camera Logo
93 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
