Question about KitchenAid KGRS807S Gas Kitchen Range
I have a kitchenaid gas range and the door is stuck in lock
I turned on my self clean this morning and just when I started the cycle my son opened the oven door cancelling the self clean. I tried to start it again but the lock in stuck and I can't close the oven door now.
    Problem Solver:
  • 17 Answers
Hold the oven door lite switch closed and put it on selfclean it should activate the door lock
Posted on Nov 14, 2009
Gas range oven door with not open
Your self cleaning cycle is running. When self cleaning is running the door is automatically locked and will not unlock until the self cleaning cycle completes or self cleaning is turned off. You should be able to just turn off the self cleaning cycle and the door will unlock. Do not try to pry open the oven door. You will just damage the door and/or the catch.
Oct 15, 2014 | Amana ARGS7650SS Gas Kitchen Range
I started a self clean on my oven, and then shut it off, the door opened, now it will not close, seem like the latch is in the lock posistion. help
For an oven self cleaning problem, the first thing to check is the door lock motor and switch assembly. Every self cleaning oven door has a locking mechanism to prevent the door from being opened during the cleaning cycle. An oven self cleaning problem often happens after a clean cycle has been run. If that happens, more often then not the lock assembly will need to be replaced. The door lock motor and switch assembly, over time, fail due to the high temperatures that are encountered during the cleaning cycle.
Here is the part to order.
All parts come with a 365 day, any part, any reason return policy.
Feb 02, 2013 | KitchenAid KGRI801PBS Gas Kitchen Range
Kitchenaid KGSS907 oven door locked while in self clean mode
It locks so you dont open it during the cleaning cycle. It gets very hot so it burns everything stuck fast to a crisp. after cycle is over and temp drops it will unlock. dont worry about a small amount of fire as long as it dosent get too big it should be fine. Might make alot of smoke though.
Dec 27, 2011 | KitchenAid KGRA806PSS Gas Kitchen Range
I entered the "quick" option for self-cleaning my
It has a safety that will not allow the door to open while the temperature is high in the oven. oven temps can reach 700 degrees during the self clean cycle. allow the unit to cool completely and see if it works then. if not, let us know.
Nov 20, 2010 | KitchenAid KGSI901PBS Gas Kitchen Range
Maytag gas oven after self-clean cycle door locked "dr" on displa
unplug it and let it stand for a few minutes
let the e- prom clear
plug it back in, should unlock
if it does not you need a new sensor
Sep 27, 2009 | Maytag MGS5770 Gas Kitchen Range
Amana Oven Door won't open. Latch to lock it is broken.
After pressing Self Clean, Adjusting the Time and Pressing Start, the self cleaning cycle shows the # F57_ on the read-out. I tried to cancel and now the door opens, but I can't get the Bake to begin when I press Start. No matter what I press LOC flashes on and off, but the door is unlocked and the heat is off.
Please help!
Susan, PR
Apr 17, 2009 | Amana ARGS7650SS Gas Kitchen Range
Oven Lock stuck open before start of self-cleaning cycle
Sounds like you bent the door where the lock is. You might have to replace the door.
Mar 12, 2009 | General Electric Stove/Oven/Range Chrome...
Lock on oven is locked and door open
look towards the center of the door, next to the "self clean latch" youll see a thin metl "plunger", try pressing this in and then restarting a clean cycle, then quicklly cancel clean it should reset the lock/latch mechanism
Jan 21, 2009 | KitchenAid KGRA806PSS Gas Kitchen Range
DOOR SHOWS OPEN BUT IT IS NOT
After self cleaning the range the door won't open....
The oven door lock needs approximately 1 hour to cool down before the oven door can be opened after a self cleaning cycle has finished. If the lock does not open after the oven has cooled down, you can try....1) Unplugging the range or shut off the circuit breaker for 5 minutes. Plug the range back in or turn on the circuit breaker. Set the clock and try moving the door lock lever or opening the door. 2) Set the self-clean cycle again and only allow it to work for 15 minutes. Cancel the self-clean cycle and allow the oven to cool. Gently try moving the door lock lever or opening the door.
Hope this may help;
DON'T FORGET TO HELP
Sep 06, 2008 | KitchenAid KBMC140HSS Convection/Microwave...
Kitchen Aid KGRA806PSS
hmmm....that interlock is dependent on a temperature sensor, to ensure that no one opens that door when it's too hot inside. I'm assuming that it's still locked, even after the temperature has dropped off?
Feb 26, 2008 | KitchenAid KGRA806PSS Gas Kitchen Range
KitchenAid KGRS807S Gas Kitchen Range Logo
1,459 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
