Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Have replaced drive gear on Craftsman GDO. Everthing engages and chain moves but door only opens 3 inches are so. Have ajusted opening cointrol on side to max and only 3 inches. When I unlatch GD from trolly, move on track but only part way does not move to end of track stay in middle of track. Please help.
    President:
  • 3,197 Answers
Loosen the chain enough that you can remove it from the pulley on top of the motor unit. Now with the door closed run the motor until the pulley turns in the clockwise direction and stops. Put the chain back on the pulley and tighten. You may have to tweak the up and down limits now.
Posted on Nov 14, 2009
Testimonial: "Thanks GDO is working prefect! Glad I found this site."
My 20 yr. old Craftsman 1/2HP chain drive GDO (139.18590) will click and hum for a second but the door doesn't move when I press a remote or wall console. The door moves freely manually and I checked the...
If your door is stuck in the open position the trolley is most likely jammed against the bolt just in front of the motor unit. You should be able to loosen the chain enough that it releases the pressure on the trolley and then close the door. While the door is closed, locate the 'up limit' control which is on the side of the motor unit. Turn this control 2 full turns in the opposite direction of the arrow printed on the cover and then tighten the chain.
Feb 21, 2010 | Sears Craftsman LiftMaster Chamberlain...
My GDO makes a noise as if it's turning inside, but the chain is not moving. Is it fried?
The drive gear is stripped. The part number is 41A2817 and is available at any good door opener service company. It comes with instructions.
Jan 31, 2010 | Sears Craftsman LiftMaster Chamberlain...
It moves up a few in. then stops. Then you push the button again it closes hard aginst the floor. I disconneted the dr andf it still dose the same thing.
The opener has lost track of what is open and closed. This MIGHT be due to damaged gears, but first get a manual and do the initial setup work.
You could disconnect the motor and manually move the carriage back to where is should be, then engage the motor again.
If this is a chain drive, the chain may have slipped cogs until it thinks the door is up when it is only inches up.
Jan 09, 2010 | Sears Craftsman LiftMaster Chamberlain...
My Craftsman GDO model # 139.53990D does not open when I push the wall button the motor clicks but does not engage. I have been trying to adjust the travel limits and it now moves all the way back to the...
You need to remove the cover of the motor unit and check the drive gear. It sounds like it is stripped. Your explanation is a little confusing though. You say it moves all the way back to the cover protection bolt and then you say it won't open.
Jan 03, 2010 | Sears Craftsman LiftMaster Chamberlain...
My garage door opener moves about 8" then reverses direction before touching the limits
Remove the cover and take a look at the drive gear. It is white nylon and is just in front of the motor. It is most likely stripped. You can purchase a new one at Sears or any good door opener company. It comes with instructions.
May 31, 2009 | Sears Craftsman LiftMaster Chamberlain...
Craftsman GDO, Model 139.53600. moves 4inches up/ down
Find the increase travel adjustment screw and turn it clockwise 1/4 to 1/2 turn.
Jan 14, 2009 | Sears Craftsman LiftMaster Chamberlain...
Craftsman GDO Will not close
readjust the sensor controls on the side of the unit
Dec 28, 2007 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
197 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
