Question about Motorola Canopy 5.2 GHz Wireless Access Point - AES Encryption (5201AP)
Im using Motorolla canopy 5.4 and 5.7, both ,they are confiruged whith ip addresss in the range of class A, my problem is that in lot of them i cannot access thru web page, what should be wrong on this case, configuration in the motorola, or wrong configIration switches or routers, thnx for any addvice Regards Fadil
  • 358 Answers
I would advise you to be sure that your routers are MDI/MDIX Compatible, (i.e it can allow you to use either a straight-through or cross-over cable).
If not, then try using a cross-over cable when connecting the routers together.
Also, try making your router's LAN configuration to be DHCP and the one for your Wireless Access Point Static.
Then make sure that they are all in the same Subnet. This is also very important.
Try out these few troubleshooting steps first and keep me posted about the problem.
Hope it helps.
Goodluck
Posted on Nov 20, 2009
Hi, I have a D-link Dir 655 router, partly wireless but I cannog access it with 192.169.0.1 (default gateway) Ping 192....... is ok (3x reply) My internetexplorer says that it is an online router but...
well the ip address you type is incorrect you must put it as 192.168.0.1 because you are using the class C ip address. there 5 classes of ip first is A it ranges from 0-127. class B ranges from 128-191 class C 192-223 class D is not for commercial used it is reserve for multicast used. it ranges from 224-239 class E is not also commercial used but it is an experimental used it ranges from 240-255 the first three octate are for the network while the last octate is the host
May 15, 2011 | Computers & Internet
I have a set Motorola Canopy 2400BH but i forgot ip address and username and password, how can i access it for using.
You need to user an Override Plug, which can be fabricated this way:
To fabricate an override plug: 1. Install an RJ-11 6-pin connector onto a 6-inch length of CAT 5 cable. 2. Pin out all 6-pins. 3. Short (solder together) Pins 4 and 6 on the other end. Do not connect any other wires to anything. The result should be as follows: Pin 1 ? white / orange ? Pin 1 Pin 2 ? white / green ? Pin 2 Pin 3 ? white / blue ? Pin 3 Pin 4 ? green ? Pin 6 Pin 5 ? blue ? Pin 5
Regaining access to the module To use the override plug 1. Insert the override plug into the RJ-11 GPS sync port of the AP. 2. Apply power to the module through the Ethernet cable. RESULT: The module reboots with the default IP address of 169.254.1.1, password fields blank, and all other configuration values as previously set. 3. Set passwords as desired. 4. Change configuration values if desired. 5. Save the settings. 6. Remove the override plug. 7. Power cycle the module.
You can view more details at:
http://www.canopy-wireless-solutions.com/AppicationNotes/APManualIss5.pdf
Apr 30, 2011 | Motorola CANOPY 2400AP (2400APBC)
I have conected 4links by motorolla canopy in a
try to check firewall settings whether it is enabled or not
Aug 28, 2009 | Motorola Canopy 5.7 GHz Wireless Access...
Oil change on b class
hello good afternoon
Could you please tell me where is the drain bolt in a class B mercedes 180 CDI 2009 model . is it the one which has got a terminal to connect a pipe ,19mm bolt ( in comparison whith what is found on a lawn cutting machine .....) , or is it the 13MM bolt at the flat bootom of the engine ?
thanks a lot .
Jun 12, 2009 | 2006 Mercedes-Benz B-Class
Problem D-Link DI-704P
then configuration problem then re-configure it check ip addresss, dns value, firewall, proxy server any antivirus is on then off it. some they also create a problem
Mar 09, 2009 | D-Link DI-704P Router
About n/w printer
If you have the network enabled 1022 you need to find out it's current IP address. To do this press & hold the Go button on the top of the printer (the large button) for 5 - 10 seconds or until the printer starts to print. This prints out the configuration page.
The printer is set to get an IP address via DHCP from the factory, but once you have it's IP address you need to give it a static IP address. You can do this by typing the IP address into a web browser & go to the network tab. choose an IP address that has not been allocated already & apply the changes.
You will need to type the new IP address into the browser if you want access to change further settings.
You can then add the printer using the new static IP address.
Sep 16, 2008 | HP LaserJet 1022 Printer
Edimax wireless-g broadband router
please confirm if the router is a 6104K, or a KP or Wg or another model as the K and KP are not wireless, a "W" will denote wireless capability...
Not all manuals are available for download from the Edimax website but heres a start...
Connect the router to your PC with a cable... leave the modem disconnected to start with
open internet explorer and type in enter the default IP address 192.168.2.1 (broadband router’s IP address) into your PC’s web browser and press <enter>
This should bring up a user/password dialog box. By default the user name is "admin" and the password is "1234".
Confirm you are getting this far and we'll go the next steps
Jul 06, 2008 | Edimax BR-6104K Router (br6104k)
Factory Default Motorolla Canopy 900mhz. AP
all you need is a phone cord (that you dont want to use anymore) just ground the number 4 and 6 wire together and leave the rest alone. plug it in the canopy and then power it on. It should then be at the default ip. I think its 169.254.1.1 or 192.168.100.1.
Jun 16, 2008 | Motorola Canopy 5.2 GHz Wireless Access...
Not connecting to internet
When you power down the canopy, what happens is you also do a hard reset which from your post re-establish the connection.
One of the many possible causes is that the canopy is loosing its DHCP lease on its assigned IP add. This may be a security feature/measure of your ISP limiting assigned IP add through a DHCP server for only a couple of hours to clients such as yourself. If this is the case then you have to bring this to the attention of your provider;
Another that you can try is to telnet to the canopy interface and check its settings. Its IP add is 169.254.1.1(255.255.0.0). Newer versions uses the 10.X.X.X (255.0.0.0) series, pls check which one you have.
Alternately, what can be done is to do a soft reset (not powering down/hard reset). Right click on your Networking icon in the System Tray and click on "Repair".
Other areas you can check/try are your router settings (if you are using one), settings of HTTP1.1 through proxy connections in IE, fix DNS (you can get them from your ISP). If you are using XP, there is also a registry tweak for DNS errors resulting to no connection (winxp_dnscache.zip).
Hope that this be of some help/idea. Pls post back should you need additional information.
Good luck and kind regards.
Dec 31, 2007 | Motorola CANOPY 2400AP (2400APBC)
Motorola Canopy 5.2 GHz Wireless Access Point - AES Encryption (5201AP) Logo
307 people viewed this question
Top Motorola Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Motorola Computer and Internet Expert? Answer questions, earn points and help others
