Question about Pioneer DEH-P6800MP CD Player
No sound I recently disconnected my radio to install a gps, and i reconnected the radio wires, everything seemed to be working fine, however, no sound came through any speakers on any function. In order to see if it was my headunit or harness, i attached the older factory stereo and it worked out fine. Now I know that it is in either the connections or something else, not the speakers....please help.
  • 43 Answers
Check your remote turn-on lead connection - you may have a factory amplified system which isn't getting turned on, which would explain the no sound.
Posted on Feb 23, 2008
Bmw x5 cd changer no disc
absolutely no idea ,do you have anything else plugged in that could cause the sound cut off although you say the radio works?or has a plug come loose in the back of the radio ,you could try one of them radio fitting centres as you never know some young lad comes out presses a button and it all works as you had the mute on or something but the radio works ,is it a built in cd player or a remote unit ? in my time a 8 track was the in thing these modern things are welll beyond your ancient dinasaur here .
Jan 30, 2014 | Cars & Trucks
Cd plays but no sounds comes out
Depending on the radio, if you didnt touch your radio when you installed GPS then the CD player could be bad, check the manufactures website for troubleshooting tips then check google, also next time post the brand and model number so we can know what you have to help, hope this helps you.
May 31, 2013 | Car Audio & Video
The unit turns on then shuts off after a few seconds.
This could be a bad speaker or speaker wire. I had this same problem recently. In my case it was the powered sub-woofer. I disconnected the speaker wire from the back of the receiver(with the power off, of course). When I powered up the receiver, problem solved, it worked fine. I then made sure the wire was not shorting out, carefully reconnected everything and the sub works too. I never found the cause, but it has worked fine for several months now.
You can start by disconnecting all the speakers. If the receiver powers-up reconnect them one at a time to find the bad wire/speaker. If it is not the speakers, disconnect all attached devices. If the receiver still won't power-up go shopping for a new one. It is not worth repairing. It is less expensive to replace it.
Remember, always turn the power off and set volume to zero before disconnecting or connecting anything! You don't want to cause any damage.
Nov 06, 2009 | Yamaha HTR-5790 Receiver
Instrument panel guages quit. Getting 'No Bus' error in odometer.
That wire needs to be hooked to the factory radio , part of the PCI bus - serial data communication network . I know on GM vehicles if the radio isn't hooked to the bus the vehicle will not start an run . Don't know if Dodge vehicles are that complex . http://www.dodgeintrepid.net/31-car-audio-video/58412-why-pci-bus-connection-radio.html http://www.carsondemand.com/IDLdocuments/Learning%20Guide/4450-t9r0k5io6vxazm80x5ire9zj4.pdf
You mite call a aftermarket installer an ask or the dodge dealer
Feb 28, 2017 | 2005 Dodge Ram 1500
Could radio wiring be causing my truck instrument panel to fail?
That wire is probably data. What you may have to do is get a radio-relocation harness, contact your local car audio shop. The company is Metra out of Florida. You will need to get this harness, possible p/n 70-6512. That way your OE radio data bus remains connected. I have this harness in my inventory, but I am in Edmonton, Canada..
May 24, 2009 | Panasonic Car Audio & Video
2001 dodge neon radio
Also had no radio but flashing bass/treble indicator lights. As suggested by another post, I disconnected neg. batt. cable and pulled the "interior cluster" fuses, re-set them and then reconnected batt. cable. This fixed the radio.
Apr 04, 2009 | 2001 Dodge Neon
Radio cracking/no sound
I disconnected the amp and ran jumper wires between the two harnesses basically creating an amp bypass everything now works fine.
Jul 14, 2008 | 2002 Chevrolet Monte Carlo
Pioneer DEH-P6800MP CD Player Logo
115 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
