Question about Honeywell Home Security
MY HONYWELL PIR HAS 8 WIRE CONECTIONS WHICH ONES DO I USE? I HAVE 6 WIRES
    New Friend:
  • 36 Answers
What model is it
Posted on Nov 28, 2009
  • Cecelia Mann Oct 20, 2011
    the numbers on the inside of the thermostat are 32003725-003 and the other one is 154604000797731
How to wire slave pir to a master unit touch swtich on a stairwell with two-way switches
sounds like two way switching , 2 switches wired parrell 1 to 1 2to 2 3 to 3
power 2 and 3 , but seek professional advice if using mains
Jul 19, 2014 | Elkay Computers & Internet
Tip
How to Crimping Network Cables
Tools and Materials You Will Need
Crimper with RJ-45 die.
Wire stripper
Wire cutter
RJ-45 plugs
Cat-5 UTP cable
Optional Tools
Wire Tester
Procedure
1. Strip off insulation
2. Untangle wires
3. Place wires in correct order &
straighten.
4. Trim wires to desired length.
Note:
If the wires are too long the plug will not
crimp onto the insulation for strength.
5. Slide wires all the way into the plug.
Make sure not to disrupt the color
scheme.
6. Crimp plug.
7. Repeat steps 1-6 for the other end.
8. Test wire using optional test equipment
or between working computer and hub
for patch (straight through) cables ,or
between switches for crossover cables.
Wire Color Scheme
Pin Color Diagram
1. Orange / White
2. Orange
3. Green / White
4. Blue
5. Blue / White
6. Green
7. Brown / White
Patch Cable
(Straight Through)
Both ends follow this
format.
8. Brown
Pin Color Diagram
1. Green / White
2. Green
3. Orange / White
4. Blue
5. Blue / White
6. Orange
7. Brown / White
Crossover Cable
One end as a patch cable
and the other as follows
8. Brown
on Dec 08, 2009 | Computers & Internet
PIR switches and house wiring is incompatable?
Several possibilities. First use standard light bulbs until it is working. Some of the PIR have triac outputs which need a minimum amount of current to work. CFL and LED lights can be a problem with electronic switches/dimmers.
The PIR needs electricity to operate. The black and white wire are probably power and return, there is no neutral to connect to the PIR. Unless you can get a different PIR that does not need line power to operate you are out of luck. There may be some that can cycle steal power and would work but I am not familiar with them.
I assume the three way is a three way PIR and the lights that are flickering are electronic such as LED or CFL.
If you talk to one of the people where you bought the switch they may help you free of charge.
Good Luck
Feb 23, 2014 | Electrical Supplies
PIR MODE SET UP
I use mine set up for motion sensitvity..this means something must enter the units field of view to be photographed..I set it for maximum distance and to take a photo every couple of minutes..I use an sd card thats 2mb yours may use a 4 6 or 8..look into the window display and see how many photos it will take..mine will do 3000 on the 2mb card..make sure the card is unlocked before putting it in the camera..and you have new batteries in it..
Jan 15, 2014 | WGI INNOVATIONS Video Cameras
Wiring diagram for a p i r to a light
They all wire the same. The black wire on the PIR connects to the incoming (usually black) hot or switched wire. The red wire on the PIR connects to the light(s), usually a black wire. The white (neutral) wire from the PIR connects to BOTH the incoming white wire and the white wire that goes to the light(s).
Jan 17, 2012 | Home
I am installing honywell thermostat rth111/rth221 old thermostat has two wires that are yellow and need to know where to hook up
First things first. What type of system? Heat only, boiler or furnace? Central cooling.
Do NOT take wires off the old thermostat yet, or mark the color wire, to the terminal letter. Most times W,Y,G,R, terminals and maybe even a C terminal.
Your new thermostat should have the same letters. Sometimes they mix up color wire with terminal letters...... example (yellow wire to w terminal)
Also turn off power to equipment it is controlling. It is not high volts but you can short out the transformer. Hook uo wire color to same letter terminal on old stat, to new stat. Thats it.
Nov 12, 2011 | Honeywell Programmable Thermostat Heater
How to wire
This should replace any existing single pole (one location) switch. You have two wires on the pir, black and blue and then the ground. The black hooks to the hot or common wire. It may be black, but it will be the hot wire. The blue wire hooks to the wire going to the light. The ground hooks to the green or bare.
Mar 05, 2011 | Leviton Decora Wall Switch With Pir...
Chevy 95 g20 van 8 cylinder wiring order spark plugs
1-8-4-3-6-5-7-2 The #1 spark plug is the front spark plug on the drivers side and the cylinder location in order from front to back on the drivers side is 1-3-5-7 and on the passenger side it is 2-4-6-8. The ignition rotor rotation is clockwise.
If your Distributor cap is not numbered then replace the new wires, or transfer the old ones to the new distributor cap one wire at a time. Identify the #1 spark plug wire and start from there.
Apr 23, 2010 | 1995 Chevrolet G20
Two of the plug wires got switched and i dont know which ones. its a 99 durango slt with 5.2 liter. if i had a picture or diagram to tell me where each plug wire goes i could fix.
the firing order is 1-8-4-3-6-5-7-2 , distributor spins clockwise, so find number one on the distributor cap and then the next cylinder will be #8 and so on in a clockwise direction
Mar 18, 2009 | 1999 Dodge Durango
Home Security Logo
749 people viewed this question
Top Honeywell Home Security Experts
Sean
Jay Finke
Jay Finke
Are you a Honeywell Home Security Expert? Answer questions, earn points and help others
