Question about Maytag Performa PAV2200
Makes squealing noise when spinning - Maytag Performa PAV2200
    Problem Solver:
  • 17 Answers
Those machine are known to have bad transmissions you should have it checked it may be under warranty
Posted on Nov 14, 2009
Noise squeal
check for drive belt condition and tension. Check that all pulleys spin freely and are not making the belt slip.
Aug 23, 2014 | 1997 Ford Aerostar Extended
Wahser makes loud noise trying to stop spin cycle It seemed to spin ok and agitate but made terrible noise when trying to stop
Take the belt off and run the motor alone if you hear a high pitched squealing noise to check for motor bearing damage or wear. If you still hear the noise without the belt, it's the motor bearing. but more than likely its the brakes, or the belt itself ,, a solinoid signals the machine to stop which in turn applies brakes just like a car only smaller, when these wear they tend to do the same as a car and squeal , its just an indication your machine is up for some maintenance,
Jul 25, 2011 | Washing Machines
My aprilair's humidifier motor began to make loud squealing noise
Put some lubricant, oil, WD40, etc. on shaft of fan. Spin the fan with your finger and work the oil into the shaft until the fan spins freely again. Reassemble and problem will be gone for 2-3 weeks. Repeat again until you want to replace the fan motor.
Dec 31, 2009 | Aprilaire 700 Humidifier
Washing machine makes squealing noise during the
when belt was changed did you find the old belt to be oiley . it maybe leaking oil from trans . and the belt will keep failing till oil leak is corrected.. mm
Dec 14, 2009 | Washing Machines
Craftsman Tiller makes loud, shrill, squealing noise when tilling
Noise comes and goes sound like metal on metal not a belt squealing
Apr 03, 2009 | Craftsman Garden
Dictaphone 2710 noise problem
This squealing noise is caused by the capstan motor. The bearings have dried up and it's metal on metal - causing an awful squealing noise. As soon as you put in a cassette, the motor begins to spin - causing the squealing noise.
Aug 11, 2008 | Dictaphone Audio Players & Recorders
Loud squeal during wash and spin cycles, maytag atlantis washer
Squealing normal occurs due to belt slippage. I would check your belts (look for cracks. Check the belt tension as well, most washers have an adjustment, normally on the motor that allows you to increase the tension of the belt.
If part of a belt gets torn and it is long enough, it will hit any part of the washing machine within range and make a clicking noise at every revolution of the motor.
I am pretty sure you need new belts. You should be able to remove a few screws and open the back cover. Between the pulleys there is a tensioner...loosen that so you can remove the belt easily. replace it with a new belt and adjust the tension.
hope this helps
Feb 23, 2008 | Washing Machines
Squealing noise during spin cycle
The spin cycle activates the fast mode on the motor, squealing normal occurs due to belt slippage. I would check your belts (look for cracks. Check the belt tension as well, most washers have an adjustment, normally on the motor that allows you to increase the tension of the belt.
Jul 08, 2007 | Whirlpool LSB6200KQ Top Load Washer
Washing Machines Logo
95 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
