Question about AO Smith Pool Pump Motor 1HP Square Flange Swimming Pool Pump Energy Efficient motor
Removed four bolts,can not get motor off - AO Smith Pool Pump Motor 1HP Square Flange Swimming Pool Pump Energy Efficient motor
  • 366 Answers
Depending on the pump you have, you'll need to remove the seal plate from the wet end and remove the impeller before you can remove the motor.
Posted on Nov 14, 2009
What does error code F7 E1 mean on a whirlpool VMW washing machine
This code indicates a motor speed sensing error, the motor can not achieve the correct speed for the cycle selection.
Have the shipping bolts been removed?
This error code indicates that the motor is having difficulty turning.
All four (4) shipping bolts and the plastic spacers must be removed from the rear of the washer before you operate it. Each unit is shipped from the factory with four bolts, which are designed to secure the washer during shipping. Failure to remove all of the shipping bolts, and the four plastic spacers that are with them, can result in noise, vibration or error codes. See your Installation Instructions for details on how to remove the shipping bolts.
Dec 27, 2016 | Whirlpool Washing Machines
The belt broke on this unit...how do I install it?
Unplug the power cord or shutting off the circuit breaker. Remove the belt guard loosen the four bolts that hold the motor to the compressor frame. The holes in the frame are slotted to move the motor for belt tensioning. Remove the old belt by pushing the motor toward the compressor. Place the new belt on the pulleys and hand tighten the four motor bolts. Align the two pulleys with each other. Apply a little tension on the V-belt. Place the bar at the base of the motor and push the motor back using the frame of the compressor as the leverage point & deflect the belt downwards with your finger. You should have approximately ½ inch of free belt deflection. Tighten all four motor mounting bolts & check the deflection of the V-belt and the alignment between the pulleys again. Realign or re-tension as necessary. A correct fit will ensure proper operation of the air compressor. Replace the belt guard on the air compressor and reapply the power. Check the belt movement through the guard and for proper operation of the compressor by following the manufacturer's instructions.
Jan 07, 2011 | Campbell Hausfeld 5 Peak / 1.7 Running HP,...
How do I dismantle and reinstall a front wiper motor on a 2000 Kia Sportage?
Wiper Motor
Removal & Installation
  1. Disconnect the negative battery cable.
  2. Disconnect the wiper motor electrical connector.
  3. Remove the four mounting bolts securing the motor to the firewall.
  4. Using a suitable prybar, carefully separate the wiper motor from the wiper linkage and remove the motor.
To install:
  1. Attach the wiper motor ball joint to the wiper linkage.
  2. Position the motor on the firewall and secure the motor with the four mounting bolts. Tighten the mounting bolts to 75 ft. lbs. (102 Nm).
  3. Connect the electrical connector.
Nov 25, 2010 | 2000 Kia Sportage
How do you get the front plastic parts parts off of a pump to be replaced
You might be talking about disconnecting the plastic pipes. I would take a saw and cut the
pipes where there is enough free space to install plastic unions.
Or you might be talking about leaving the pump body in place, and removing the motor
with the impeller. There should be four stainless bolts holding the motor to the pump body.
Remove the four bolts and slide the motor back..
Hope this helps !!
Oct 28, 2010 | AO Smith SQ1152 Pool Pump Motor
Fixing heater core on Mercury Villager front one
go here for lots of help
http://groups.yahoo.com/group/villagerquest/
Heater Case Removal
  1. Drain the engine coolant. Refer to Section 03-03 for the procedure.
  2. Disconnect the battery ground cable (14301).
  3. Disconnect the heater water hoses (18472) from the heater core (18476) at the bulkhead.
  4. Remove the instrument panel lower center panel (04494). Refer to Section 01-12 for the removal procedure.
  5. Remove the glove compartment and LH instrument panel lower cover (044L97). Refer to Section 01-12 for the removal procedure.
  6. Remove the instrument panel ash receptacle (04810).
  7. Remove the two upper center instrument panel finish panel screws and the two lower center instrument panel finish panel screws.
  8. Remove the center instrument panel finish panel (044D70) and disconnect the cigar lighter socket and cigar lighter illumination lamp electrical connectors.
  9. Remove the four radio chassis bracket screws and pull the radio chassis (18806) and climate control assembly from the instrument panel (04320). Disconnect the radio chassis electrical connectors, the antenna lead, the three climate control electrical connectors and remove the radio chassis and climate control assembly.
  10. Remove the two heater outlet floor duct screws. Remove the heater outlet floor duct (18C433).
  11. Remove the four RH instrument panel lower reinforcement bolts and the RH instrument panel lower reinforcement (045F08), then the four LH instrument panel lower reinforcement and the LH instrument panel lower reinforcement.
  12. Remove the anti-lock brake control module (2B373). Refer to Section 06-09 for the removal procedure.
  13. If equipped, remove the speed control amplifier. Refer to Section 10-03 for the removal procedure.
  14. Remove the electronic door lock control processor (14B001). Refer to Section 01-14A for the removal procedure.
  15. Remove the passive restraint control module. Refer to Section 01-20B for the removal procedure.
  16. Remove the two center duct screws and remove the center duct (19D633).
  17. Remove the two ground wire bolts.
  18. Remove the three U-bracket-to-chassis nuts.
  19. Remove the four U-bracket bolts and remove the U-bracket.
  20. Remove the two RH and the two LH instrument panel bracket bolts and remove the instrument panel brackets (042C74).
  21. Remove the RH inner duct.
  22. Remove the LH inner duct.
  23. Remove the two accelerator pedal and shaft bolts and then the accelerator pedal and shaft (9725).
  24. Remove the accelerator pedal stop screw and then the accelerator pedal stop (9816).
  25. Remove the heater outlet duct screw and remove the heater outlet duct.
  26. Remove the temperature blend/panel bypass door actuator motor. Refer to the procedure in this section.
  27. Remove the panel/floor/defrost door actuator motor. Refer to the procedure in this section.
  28. Remove the three A/C evaporator register duct screws and remove the A/C evaporator register duct.
  29. NOTE: The A/C evaporator/blower motor assembly does not have to be removed in order to remove the heater assembly.
    Remove the four A/C evaporator/blower motor assembly screws to aid in the removal of the heater assembly.
  30. Remove the four heater assembly screws.
  31. Remove the heater assembly.
Sep 30, 2009 | 1996 Mercury Villager
2001 kia sportage need to get info on how to change the timing belt, 2.0 motor forward facing motor, needs power steering replaced, timing belt.
Below are the steps..
Disconnect the negative battery cable. Remove the two fresh air duct mounting bolts on the radiator. Loosen the fresh air duct clamp at the intake housing. Remove the hose at the resonance chamber. Remove the frech air duct. 2bea4d1.jpg Remove the five cooling fan shroud bolts. ab00c68.jpg Remove the four thermo-modulated fan nuts. Remove the four thermo-modulated fan cooling fan shroud at the same time. 289c5ca.jpg Loosen the two generator mounting bolts(A and B). 2a96c03.jpg Loosen the generator drive belt from the generator by loosening the adjusting bolt(C). Remove the generator drive belt. Remove the fan pulley. Remove the four splash guard mounting bolts and splash guard. f912ce0.jpg Loosen the A/C idler puller nut(A). c0690b5.jpg Remove the A/C drive belt by loosening the adjusting bolt. Loosen the power steering pump lock bolt and mounting bolt. 843d3b3.jpg Remove the power steering belt. Remove five bolts and the upper timing belt cover. Refer to Timing Belt. Remove two bolts and the lower timing cover. Refer to Timing Belt. Loosen the tensioner lock bolt and pivot the tensionder pulley outward to remove the tension from the timing belt, then re-tighten the tensioner lock bolt. 7ca4ca0.jpg NOTE: Tightening Torque : 27-38ft·lbs(37-52N·m) Mark the timing belt rotation for proper reinstallation if it reused. Remove the timing belt. Be careful not to allow oil grease on the belt. c5d4c02.jpg Regards, Jeep Brainy
Sep 16, 2009 | 2001 Kia Sportage
Where is the windshield wiper motor on a 2007 Dodge Caravan and how do I replace it?
Wiper Motor: Service and Repair
Removal
REMOVAL
The front wiper motor comes as a unit with a wiper pivot on each end and mounts to a shaft that holds these two inner pivots.
1. Disconnect and isolate the battery negative cable.
2. Remove the wiper arms.
3. Disconnect the washer hose at the in-line connector located near the air cleaner housing.
4. Lift the cowl grille and disconnect the washer hose grommet from the hole in the wiper module. Pull the washer hose and the grommet
completely through the wiper module tub hole.
5. Remove the cowl grille.
CAUTION: Be careful not to scratch the cowl grille on the corner of the hood.
6. Remove the four brace nuts holding the wiper tub to the lower windshield fence.
7. Remove the four bolts underneath the wiper tub inner brace holding the tub to the bulkhead.
8. Remove all four inner support brace mounting nuts and pull the inner braces just free of the mounting studs.
NOTE: The wiper tub will drop down slightly.
9. Disconnect the driver and passenger side wiper link ends at the inner pivots.
10. Remove the two left wiper motor assembly mounting nuts.
11. Remove the two right wiper motor assembly mounting nuts.
12. Partially lift out the wiper motor assembly out of the wiper tub.
13. Disconnect the wiper motor electrical connector.
14. Remove the wiper motor assembly the rest of the way from the wiper tub and remove from vehicle.
Installation
INSTALLATION
1. Install front wiper motor assembly onto wiper tub.
2. Connect the electrical connector to the front wiper motor assembly.
3. Install the four mounting nuts. Tighten nuts to 9 Nm (80 in.lbs.).
4. Push the four inner support braces onto the studs and install the four nuts. Tighten the nuts to 9 Nm (80 in.lbs.).
5. Install the four bolts underneath the wiper tub inner braces that hold the wiper tub to the bulkhead. Tighten the bolts to 17 Nm (150 in.lbs.).
6. Install the four nuts holding the wiper tub to the lower windshield fence line. Tighten nuts to 7 Nm (65 in.lbs.).
7. Apply grease to drive link bushings.
NOTE: Make sure to use Mopar(R) approved grease.
8. Attach the driver and passenger side outer wiper linkage to the inner pivots on the front motor assembly and firmly snap into place.
CAUTION: Do not apply too much force to engage link bushing or damage can occur to the drive link bushing.
9. Position the cowl grille in place.
10. Install the washer hose and grommet into the wiper tub.
NOTE: Be sure to properly seat the washer hose grommet into the bottom of the wiper tub.
11. Connect the washer hose at the in-line connector located by the air cleaner housing.
12. Install the cowl grille.
13. Connect the battery negative cable.
14. Verify that the wiper motor is in the Park position by cycling the wipers system. When done, remove keys from ignition.
15. Install the wiper arms.
16. Align the wiper arms and tighten nuts to 35 Nm (25 ft.lbs.).
17. Install the wiper arm nut caps.
Sep 13, 2009 | 2007 Dodge Caravan SXT Minivan New Cars
Have crafsman 5500generac generator need to seperate genhead from
Remove all wiring. Remove four stator bolts. Remove stator. remove rotor through bolt tap end of rotor us a shaft in the rotor tighten bolt in tapped hole to remove rotor.
Mar 25, 2009 | Watts Onan Portable Generator - 4000 ,...
How do i replace the belt
There are four bolts holding the motor to the chassis. Remove the four bolts, slide you hand back along the belt and released the belt from the transmission pulley. Once this is done, turn the motor and pump upside down and you will see the three star screws that hold the pump on. Remove the screws and slide the pump off. If the pump is stuck you will have no choice but to break the pump off and replace it.
Mar 11, 2009 | Maytag Atlantis MAV7551 Top Load Washer
AO Smith Pool Pump Motor 1HP Square Flange Swimming Pool Pump Energy Efficient motor Logo
256 people viewed this question
Top AO Smith Pool & Spa Experts
Jay Finke
Jay Finke
Larry Maranto
john h
Are you an AO Smith Pool and Spa Expert? Answer questions, earn points and help others
