Question about LG KS360 QWERTY Keyboard Phone BRAND FREE10 TOP UP
Trying to accept a music file by bluetooth but flashes up memory full.
I cant get music to transfer to my LG 8575 samba
Music can be transferred to this phone using a USB cable or through Bluetooth. To transfer your song using USB cable,
  1. You will have to connect your phone to a computer,
  2. Be sure to have the USB cable of your phone, then you connect it to the computer,
  3. Then you click on open file to view folder as soon as the Auto play comes up on the screen of your computer,
  4. That way a page will open with the files on your phone,
  5. Go to the music you want to transfer to the phone, then you right click on it and copy the music,
  6. Go to the page where you have your music and paste it there,
  7. That way your music will be on the phone.
To transfer through Bluetooth, ensure the phone you are trying to transfer music from has bluetooth on it. Ensure the bluetooth is on, then you follow the steps below:
  1. Go to your phones menu,
  2. Select the settings, and turn on your bluetooth from there,
  3. Then you go to the phone you want to transfer the song from,
  4. Select send via bluetooth,
  5. It will search for the available bluetooth that is turned on,
  6. Once it finds yours, select it and the music will attempt to be sent to your phone,
  7. Accept it on your LG phone, then a page will load,
  8. That way the music will be sent to your phone.
Be sure that your phone has a large memory that can receive the file, be sure also that the musics size is not larger that 7mb, if not, it might not load on your phone and says memory full. If your phone allows memory card, the moment you transfer the music to your phone, then you browse it out from your multimedia and transfer it to your memory card, to avoid the memory full error from coming up.
Hope this was helpful. Thank You for using FixYa!!
Jan 12, 2011 | LG VX8575 Cell Phone
Plz tell me how to get my lost micro sd password on nokia 5130 express music.
Please follow these steps:
1.Go to file manager on your mobile.
2.In the "SETTINGS" choose SYSTEM folder and select the file named "MMCSTORE".
3.Send that file to your PC using Infra Red or Bluetooth.
4.Open this file in notepad. You can find your required password in that file.
Hope this helps. If you need any more assistance, don't hesitate to come back to us. Else, if the problem is solved, please do ACCEPT this solution. Best Wishes. Thanks for using FixYa.
Nov 05, 2010 | SanDisk 2GB microSD Memory Card
Text memory full states on notification cant receive texts but i have no messages saved so i st .arted clearing out stuff tha had a storage i still have full memory. HELP PLEASE
Dear Sir\Madam,
I had a similar problem, and I was able to solve the problem by simply following the below steps. 1. If probably your phone has a bluetooth device and you have been receiving gallery files(i.e. Photos, Musics or Videos) via bluetooth, note that this files are stored too on your phone memory not the memory cards and this may consume space on the phone memory. So, try and move those files that you received via bluetooth in your received folder on your phone memory to the location of your memory card. This may probably free the space on your phone. 2. if you have been receiving bluetooth files as a message into your phone depending on the type of phone you are using, simply save them into your memory card by selecting the memory card path and delete them after saving so as to free space on the phone memory. Then try to delete as well some unwanted or junk messages from your phone in have more space on your phone memory.
Hope the information actually help. Regards
Sep 03, 2010 | Cell Phones
Poor manual and when i try transfering music thru bluetooth, it tells me failure, disk full. I have an 8gb flash card in it so should be plenty of memory.
It's because you are transffering the music to the phone's memory, instead of the memory card. Go to Bluetooth, Settings, Storage Location, and choose memory card. Now transfer a file to see where it stores, if it's a music file it should store in MP3, if it's any other file, it should be in a folder called Received.
Sep 29, 2009 | Cell Phones
Can't save music to external memory
ive been trying for ages to do this and its so easy but no one seems to be explaining it easy! Your phone without the memory card only holds one or two songs. you must have songs in there for it to say memory full. Go to this song press options , file, move to extrenal. Now try and send a song through bluetooth. You will be able to recieve it now you have freed up spave on the phones own memory. Remember to save it to external straight away so u can recieve the next item. Easy peasy!
Aug 21, 2009 | LG KS360 QWERTY Keyboard Phone BRAND...
Unable to receive via bluetooth
Hi buddy,
Please check wheather ur memory is free or not then try to take the files from bluetooth.
Check both phone memory and memory card memory
Jul 29, 2009 | Nokia N90 Cellular Phone
Inserting a 2gb micro sd mem card in lg webslider to have xtr spa
You have to move each song/file to your external memory straight away after recieving it via bluetooth because it goes straight onto your phone memory. Seach your phone memory and move all photos, videos, music etc to ext.memory by selecting the file-select options in lefthand corner- move to external memory. If your phone cannot find your external memory then you havent formatted your memory card. Go to Settings-Memory Status(way way down the bottom of list)-External Memory-Format(lefthand corner). Just remember to move each file to ext. mem. straight away.Its a pain but you have to do it manually, the phone doesnt do it for you.
Apr 21, 2009 | PNY 2GB microSD Memory Card
LG Secret
hey! i also had the same problem. i could only send files through bluetooth but couldn't receive them but recently i found out it's becuase my handset common memory was full. so if you delete some files u have on ur handset memory..u may be able to receive files again. this worked for me but im not sure if you have the same problem as i did. i thought that the files received on bluetooth would go to my mircoSD memory chip thingy but apparently it didnt. SOOOO if ur able to send files through bluetooth it should mean that the bluetooth connection itself isn't the problem....i think. it's just ur handset common memory that is full. u can go check the memory space by going to Setting ->Memory manager ->Hanset common memory.  Hopefully this helps!
Nov 04, 2008 | LG Secret ? KF750 Cellular Phone
My Sony Bluetooth problem
Deleting files from your memory card is not enough. Usually the files received threw bluetooth will stored to phone memory and then prompted to store somewhere else by the user. So delete/move unwanted files from phone memory to memory card. Delete all the messages stored in your SIM card too.
Nov 13, 2007 | Sony Ericsson HBH-610a (Auto Pairing)...
Nokia 7373 memory card
the phone memory is full thats why you cant receive anythink.try to delate some messages and move some of your pictures,videos songs on your mmc.
Sep 05, 2007 | Nokia 7373 Cellular Phone
LG KS360 QWERTY Keyboard Phone BRAND FREE10 TOP UP Logo
16 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
