Question about LG enV VX9900 Cellular Phone
How do I manually program a LG VX 9900G phone to use Cricket? Verizon service is off.
Have a lg vx1000s that was verizon flashed to cricket. It has been hooked up through cricket previously, however i spent 12 hours trying to hook it up yesterday, finally got far enough that they took my cc...
Try *22804 it seems to work for verizon phones that are failing on *288 more often than not.
However if your phone was fully flashed you may need to have it reprogrammed since these phones need to be programmed to your number, without this most likely you will only get talk and text.
Dec 26, 2010 | LG VOYAGER VX10000 Cellular Phone
Manuelly programming lg vx 9900 to cricket service
any missing info should be provided by your reseller.......
here is what I found...
Note: Some Programming must be done from the internal keypad / QWERTY Keyboard.
Alternate Programming Sequence for the VX9900 (Orange) or for newer software versions.
[#] [#] + [7][7][6][4][7][2][6][9][9][0][0] + [SEND]
OTA PROGRAMMING
Step 01:
Change ESN in billing system.
Step 02:
Power up the handset.
Step 03:
Dial *228 + SEND
Step 04:
Follow the VRU prompts
USE OTA Where Available. If OTA is not available follow instructions below.
Top
AKEY PROGRAMMING
Step 01:
Generate a random A-Key and power phone on.
Step 02:
With the flip CLOSED, press 2539 + * + * to access AKEY INPUT MODE.
Step 03:
Press 1 for Akey Entry
Step 04:
New AKEY displays, enter 26 digit A-key then press OK when complete.
PROGRAMMING COMPLETE
Feb 03, 2009 | LG enV VX9900 Cellular Phone
Can you offer any tips on how to flash a verizon lg envy2 phone over to cricket service?
Hello acrtool667, Yes you may want to get in contact with Verizon First and ask if they can unlock that phone for you. Since both Verizon and Cricket use CDMA technology in their phones, there might be a way to make that device compatible with cricket service.
Dec 06, 2008 | LG KU990 Viewty
Invalid esn#
CDMA cell phones generally cannot be used on any other network than the one that the ESN is programmed to. For example, Cricket ESNs can only be used on cricket, Verizon ESNs, can only be used on verizon... It doesn't matter if you change the firmware or not, many other service providers will not accept another service provider's ESN.
Aug 07, 2008 | LG CHOCOLATE VX8500 Cellular Phone
Flashed to cricket a lg vx8500 but the programing code 000000 dont work pls help n cricket didnt know how to do it either
you should reach a nearby mobile shop which is an autherised dealer of lg phones.they will tell u the code
Mar 02, 2008 | LG CHOCOLATE VX8500 Cellular Phone
Lg EnV VX9900
You might not be able to use that becasue thats a verizon feature and they have there network info bassically permenently installed in the hardware. If you open the flip phone, hit menu, and hit " 0 " it will give you a service menue, password is all 0's
Dont mess around in there, you could mess up the phone, but if you look at the setting, somewhere in there it will show you that verizon has there info in there even though cricket flashed it, you cant change it. At least no way that i have found.
Jan 08, 2008 | LG enV VX9900 Cellular Phone
Help
Uh .. LG 8500's were only issued for Verizon wireless. Therefore Cricket may not run as it's provider. Have you called Cricket to ask if this phone is a phone they can offer service to??
Dec 07, 2007 | LG CHOCOLATE VX8500 Cellular Phone
Change internet setting
ya Go to internet settings and cofigure the settings manually to Cricket - its so simple, Get the Configurations from the service provider
Nov 09, 2007 | LG Chocolate Clamshell VX8600 Cellular...
LG enV VX9900 Cellular Phone Logo
497 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
