Question about Sony STR-DE545 Receiver
Over heating machine shuts down... - Sony STR-DE545 Receiver
    Problem Solver:
  • 12 Answers
What is the speaker rated its from the original manufacture
Posted on Nov 17, 2009
My LG has an ie error that persists even when the valves and inlets have been checked, the machine shuts down while filling with wate. Had the machine less than 3 years, how do I fix this?
it could be the heating element, if the heating element is damaged the pcb will cut the power. as its detected a fault. the element has a resistance if it goes up or down in resistance the pcb detects this as a fault. you can test this by removing the wire to the heater element, it will fill up with water then but when it comes to heating water it will shut of as a fault. and show a code.
Jun 26, 2017 | LG Washing Machines
Treadmills are shutting down after persons are running on machine. The power is tripping, shutting down. After break or machine is turn on it works again
Chances are the treadmill started by shutting off in the middle of a workout and has gradually gotten to the point that it will not run long, or turn on at all, in some cases. This is most likely caused from a worn deck and belt. If the belt and deck is not routinely waxed, it wears down and causes friction. This friction builds up heat which can fry your electronics. The machines circuit breaker shuts the machine down to protect the major electronic components. This protective measure, built in by the manufacturer, will only help for so long. After a few times of shutting down due to the heat, it actually does damage to the electronics. The result and correction usually ends up being a new deck, a new running belt, and in most cases that have gone on too long, the motor control board. I am attaching a link for the service manual for further information. Parts for Matrix T3 Treadmills T3x T3xi Belts Rollers Decks SPORTSMITH...
Aug 27, 2013 | Matrix T3x Treadmill Deck Treadbed Parts
Commercial espresso machine
Sounds like the safety thermostats on the machine is tripping because the machine is overheating or the circuit breaker is tripping because machine needs more amperage.
Nov 14, 2012 | La Marzocco Coffee Makers & Espresso...
Shut down
When the PS3 is on, does the light on the front appear to be yellow or red?
This could indicate that the machine is over heating and is shutting down to prevent any damage to the cpu.
The internal fan might be clogged with dirt etc.
Aug 03, 2012 | Sony Playstation 3 (PS3) Console
What might be the cause when machine gets hot when shut down
When the CPU overheats then it will shut down (i.e. thermaloverload) and won't boot up again until it has cooled down. If this is theproblem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are cloggedwith dust.
Check the CPU fan to see if it spins freely, if not replace the fan.
If the fan and heat sink is clogged with dust the remove the dust and make surethe vents are clear and dust free. Use a can of compressed air to do this.
Feb 24, 2012 | HP G62144DX Laptop
Pc keeps shutting dowen
You might want to check on the heat protection for your machine's CPU. This sounds like the CPU gets to a heat level that triggers internal protection from damage by excessive heat.
-a.
Jun 06, 2010 | Gateway GT5220 PC Desktop
Water in resovoir boils away. Do I need a thermostat?
Listen to the unit after you make a pot of coffee. You will hear it start heating the water and then after the water heats up you will hear the unit shut down. If it is not shutting down and is continuing to run then yes you need a new thermostat.
Dec 02, 2009 | Bunn VPS Coffee Maker
Neptune mdg3000aww starts heating and runs fine but stops heating shortly after start up can restart heater starts again and shuts down
If the machine keeps running but just not heating you have a thermostat issue. It could be the operating therm. or the high temp limit therm malfunctioning, shutting off the element.
If the machine stops running completely, check the door switch.
Jul 09, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Gas dryer heats fine but shuts down before the drying cycle is over taking longer to dry clothes. Lint trap and exhaust tube cleaned out.
You are going to most likely need a vent cleaning. The dryer is getting too hot and shutting off because it is not exhausting good.
Apr 29, 2009 | Kenmore 94702 Front Load Stacked Washer /...
Indesit w113 washing machine
check heating element (rear of drum at the bottom) for open circuit, replace if needed, occasionally the timer will start to click round continuously, indicating the machine has a fault, the machine shuts down waiting for the water to heat up, elements available at most appliance shops but you may need to order specially?
Sep 01, 2007 | Washing Machines
Sony STR-DE545 Receiver Logo
91 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
