Question about Canon CanoScan 9900F Flatbed Scanner
When I push the scan or file button I get a pop up that says "There is no application registered for this event". How do I get it to scan? I have a CanoScan9900f
  • Lissa Nixon
    Lissa Nixon May 11, 2010
    Hi tobrien55 You don't have the software necessary for the scanning and probably the driver as well. Click on the link below.http://www.usa.canon.com/consumer/contro...
    Download the Driver
    Download the Software (Toolbox) . Make sure you select the correct Op system for the tool box
    Install the driver and the software
    Try a scani am quite sure, you will be successful this time. If this answer is helpful, please give a rating. Have a good day luciana44
  • 292 Answers
Hi tobrien55
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=351&modelid=8743
  • Download the Driver
  • Download the Software (Toolbox) . Make sure you select the correct Op system for the tool box
  • Install the driver and the software
  • Try a scan
Have a good day
luciana44
Posted on Nov 15, 2009
When I push the SCAN button I get a message that asks me to 'specify the program where the scanned image is transferred'
You need to set up the destinations in the Canon software. First launch the Canon Scan-Gear Toolbox. The Scan button on the scanner is the same as Scan-1 button by default but no software is linked to this button. Click on the Scan-1 button then choose Set. Then set your application that you will want to work on the scanned image. Select your application (Photoshop Elements, for example) - the exe file if using Windows. (You may need to browse the Program Files folder and then the individual application folder (C:\Program Files in recent versions).) Then click Open and then Apply to confirm this. You can also select the file type that you want the scans to be saved as in this settings window.
If you want to change the scan destinations, then click on Settings (on the far right). You will see the drop-down menus for each of the scanner buttons. Select the desired function for the scan button and click OK. (Scan-1, Scan-2 and Scan-3 can be linked to other software.)
I hope this helps.
Oct 10, 2011 | Canon CanoScan N670U Flatbed Scanner
I HAVE CANON LIDE 30 IT DOESNOT WORK IT GIVES ME A MESSAGE THAT THEIR IS NO APPLICATION REGISTERed for this event
The driver is trying to open your chosen 'image edit' (application) software (MS Paint, PhotoShop, Panintshop Pro or whatever), BUT you have uninstalled it, moved it or not chosen one ....
Go into the Control Panel, Scanners & Cameras, choose the LIDE scan driver right click for 'properties', Events tab, Select an Event pull down = 'scan start button' (or whatever) and select (browse to) your image edit package ..
Jun 11, 2011 | Canon CanoScan LiDE 30 Flatbed Scanner
The scanner is not scanning as fast as it says its suppose and we just got it why is this
Hello
Make sure EPSON Smart Panel is installed.
If you are using Windows XP:
Click the Events tab in your scanner's Properties dialog box and make sure Take no action is not selected. Also, make sure the desired button is selected in the Select an event list box, and Start this program is selected.
For Windows Me, 98, and 2000 users:
Click the Events tab in your scanner's Properties dialog box and make sure the Disable device events check box is clear. Also, make sure the desired button is selected in the Scanner events list box, and the desired application in the Send to this application list is selected.
For Mac OS X users:
When in Classic mode, the buttons are disabled. Quit Classic mode. Initially, only the user who installed the scanner software can scan using the buttons. Other users must start EPSON Scanner Monitor in the Applications folder before using the buttons for the first time. From then on, pressing a button will automatically start the application assigned to it.
Jun 10, 2011 | Epson GT-2500 Flatbed Scanner
Whenever we try to open skype a dialoge box apppears showing fatal error failed to load library d3d9.dll.
You will have to re-install the Skype application in order to get rid off the error.
Please follow the below step:
1. download and install the Revo uninstaller application online(It's free).
2. Look for the "Skype" application and select the "uninstall" option.
3. Select "Advance" scan and remove all the remaining files of skype.
4. Reboot the computer.
5. download the d3d9.dll file from the following website http://www.dll-files.com/pop.php?dll=d3d9
6. Copy the d3d9.dll file and paste it at the following location C:\windows\system32
7. You will have to register the dll file before installing the skype application. To register the dll file:
Click on "Start" menu and select the "Run" option or Simply Windows key+R
Then, type regsvr32 d3d9.dll and click 'OK" .
8. Once the dll file is registered, you can install the Skype application and continue using it.
I hope this should fix the issue.
Thanks, Vicky
Dec 27, 2010 | Compaq Presario 5000 PC Desktop
MFC 8860DN No applications are registered for this event. Take no action: When I push the scan button on the printer to start scan to file
Try this:
1. Locate the Brother Control Center application. It will be running in the system tray (usually near the system clock). Right click on the Control Center and left click on CLOSE. NOTE: The update cannot be performed if the Brother Control Center is left running.
2. Click START -> RUN or in the START SEARCH LINE:
3. Type in X:\PROGRAM FILES\BROTHER\CONTROLCENTER3\SKIN\ (Note: Replace X: with the letter of your local disk drive.)
4. Right click on the MODERNSTYLE folder
5. Select CUT
6. Click START -> RUN or in the START SEARCH LINE:
7. Type in C:\PROGRAM FILES\BROTHER\CONTROLCENTER3\
8. Click EDIT -> PASTE
9. Restart the PC
10. The Control Center will open and you should see the icon appear nearyour system clock if the control center does not start automatically: Open the Brother Control Center 3 by clicking START -> (ALL) PROGRAMS ->BROTHER -> (MODEL NUMBER) -> CONTROLCENTER 3. Your issue should be resolved.
Nov 02, 2010 | Brother MFC-8860DN Printer
Problem about "services.exe - Application Error" pop-up menu
Apparently, you computer has some unexpected software running during the startup. In order to get ride of these software, you could check your register table manualy by regedit or download this software, which will help you to find if there are any suspect software running at the startup.
files.filefront.com/sreng2zip/;8049311;/fileinfo.html
May 07, 2009 | Computers & Internet
When i scan the images are black and white not color
Reset the device when it is not functioning properly. If the device is not functioning properly or to clear memory, reset it.
  1. On the operator panel, press and hold the <ON/OFF> button for one second. (The display will go blank.)
    Note: It may be necessary to unplug the power cord if pressing the ON/OFF button does not shut off the printer.
  2. Wait approximately ten seconds and then press the <ON/OFF> button again.
  3. Wait until the device has completed its cycling process before submitting another job request.
Selecting a Response to Commands from the Operation Panel
You can specify a response resulting from pressing the <Color Start> or <Black Start> button on the machine. Setting the response with MP Navigator allows you to scan documents easily.
Important:
With network connection, only MP Navigator can be launched. Configure the settings accordingly.
With USB connection, with Windows XP, the program selection dialog box will be displayed the first time you press the <Color Start> or <Black Start> button on the machine, as shown below. Select 'MP Navigator', select the 'Always use this program for this action' checkbox, and then click 'OK'. By specifying this setting, selecting any scan mode launches MP Navigator, and the selected action will be performed.
1. Click the Windows 'Start' button, then click 'Control Panel' (Non-Windows XP: click the 'Start' button, then click 'Settings' -> 'Control Panel').
2. In the resulting window, click 'Printers and Other Hardware', then click (or double-click) 'Scanners and Cameras'.
3. Right-click the scanner icon for the machine, then click 'Properties'.
4. On the 'Events' tab, in 'Actions', specify the setting to launch MP Navigator. Specify 'MP Navigator Ver2.1' for 'Select an event' and for all events. (Windows 98/Windows 2000: Select an event in 'Scanner events' and specify 'MP Navigator Ver2.1' for 'Send to this application'.) If the settings are already configured to launch MP Navigator, click 'Cancel' to exit.
Important:
If MP Navigator is not set as the program to launch, you will need to select an application to launch each time you press the <Color Start>/<Black Start> button.
5. Click 'OK'. Windows 2000 only: Restart your computer.
Setting actions for the <Color Start> and <Black Start> buttons with MP Navigator
MP Navigator enables you to specify the response resulting from pressing the <Color Start> or <Black Start> button on the machine. You can specify the response individually for each event.
1. On the Windows desktop, double-click 'MP Navigator 2.1'. Alternatively, click '(All) Programs' from the <Start> button on the Windows taskbar, point to 'Canon Utilities', then 'MP Navigator 2.1'. Then click 'MP Navigator 2.1'.
MP Navigator opens
2. Click 'Preferences', and specify settings in the Color Button and Black Button tabs to determine the response resulting from pressing the <Color Start> or <Black Start> button on the machine.
3. Select 'Event', and configure the settings in 'Actions'.
4. Click 'OK'. The operation will be performed according to the scan mode settings when you press the <Color Start> or <Black Start> button on the machine
Color Button/Black Button Tabs
The Color Button and Black Button tabs allow you to configure the following settings. Click 'Color Button' or 'Black Button' to open the corresponding tab. Setting items are identical in both tabs.
The following scan modes are available from the operation panel on the machine:
Save to PC Save the captured image data on your computer. Save as PDF file Save the captured image data as PDF files on your computer. Attach to E-mail Attach the captured image data to e-mail. Open with application Open the captured image data with the selected application
Action:
The setting items vary by event.
I hope it helps!!!
Nov 27, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Still looking for Smart-Scan software
You can program the scan button by going to "Control Panel" and "Scanner's and Camera's.
Right Click the scanner and go to "Properties"
Select the "Events" tab
It should allow you to program your one touch button from here. I just wanna verify that you do have the CX3200 and not a Stylus Scan 2500?
Aug 23, 2008 | Epson Stylus CX3200 All-In-One InkJet...
Pixma mp520 scanner won't scan
I emailed Canon Tech Support (after searching their MP FAQ) and received this response. It worked for me:
Please follow these steps to set the push button event for the MP520
scanner:
1. Click on the Windows button and then Control Panel.
2. Double-click 'Scanners and Cameras'. For Vista users, if 'Scanners and Cameras' is not listed, click 'Switch to Classic View' on the left and then try again.
3. Double-click on the MP520.
4. Next, click on the Events tab.
5. For the 'Send to this application' option, select ScanGear driver, MP Navigator, or imaging application you would like to use for the scan button event in the list.
6. Click Apply or OK to save your settings.
Jul 16, 2008 | HP PSC 2110 All-In-One InkJet Printer
Canon CanoScan 9900F Flatbed Scanner Logo
308 people viewed this question
old marine
old marine
