Question about LG XBR446 DVD Recorder/VCR
How to turn safe mode off on LG VHS recorder LV720? I have user guide but it doesnt mention this?
SOURCE: DVD/VHS Selection
turn of the power on wall, and wait 5 mins, then try again. i had same trouble with not being able to eject or play dvd, i turned off player at wall and it worked fine again.
Posted on Oct 07, 2007
SOURCE: LG VHS GC480W - VCR 'safe mode'
What do you do if you lost your remote?
Is there some master reset availible?
Posted on Oct 07, 2008
SOURCE: Need code for Viore TV to program LG RC897T DVD/VHS Recorder
If your oneforall remote didn't come with the page that gives you the set codes, you can try 991 as the code. So in this order ;
Press tv, wait fir it to blink
press 9 9 1, then power
(it should blink again)
press tv again - it should set
***IF THIS DIDN'T WORK***
SLOWLY press power, then tv, wait,
then power, then tv, wait,
After several times it should set.
(Each time you do this, it tries yet another code to set)
Posted on Jan 14, 2009
SOURCE: I have an LG RC388
Good product, but the manual is rubbish.
Check out 'dubbing' in the 'manual' andthis will more or less explain how to record from VHS to a recordable disc.
Also check out 'finalizing a disc' on the onscreen menu to be able to play the disc on any other player.
Posted on Jan 20, 2009
SOURCE: dubbing VHS to DVD
You have to go into the Home menu and select setup. At the bottom left there should be an icon that looks like a dvd disc. Select that and then go to finalize and select that to finalize the disc. After that is complete it should play on any dvd player. I had this problem and I got through to LG's customer service line and had them talk me through it. After I finalized the disc, it worked.
Posted on Feb 05, 2009
Does this unit record vhs tapes to dvd?
In theory, yes, this unit is capable of recording from VHS to DVD or DVD to VHS (where it is not prevented by copy-protection).
You can download a user manual in pdf format from the following link:
http://files.sharpusa.com/Downloads/ForHome/HomeEntertainment/BluRayDisc/Manuals/dvd_man_DVRW350U.pdf
Go to page 39 onwards ("dubbing mode").
Jul 21, 2011 | Sharp DV-RW340U DVD Recorder/VCR
How do you record dvd to vhs and from vhs to dvd
For VHS to DVD, put the tape to dub in the VHS slot and a blank DVD in the DVD tray. Make sure the DVD is compatible with the DVD recorder (see the recommended disc list) and is unfinalized if you are using a R/W disc. Close the tray. Set the unit to VCR mode with the DVD/VCR button. Advance the tape to the place that you want the recording to start. Then press the Dubbing button (either on the remote or the unit itself). Select the recording mode (SP, LP etc), highlight Dubbing then press Enter or Dubbing. Press Stop to interrupt the recording.
For DVD to VHS, put a blank tape in the VCR (make sure the protection tab has not been broken off) and the DVD to duplicate in the DVD tray and close the tray. Put the unit in DVD mode by pressing the DVD/VCR button. Find the point at which you want to start recording the DVD. Again press Dubbing and set up the recording mode and highlight Dubbing and press Enter or Dubbing.
Note that copyprotected content can not be recorded.
The manual for this recorder is on the right side of the page here: http://www.lg.com/us/tv-audio-video/video/LG-dvd-recorder-RC897T.jsp . See page 48 for the screen captures of setting the recording mode part of the dubbing procedure.
I hope this helps.
Mar 19, 2011 | LG RC897T DVD Recorder/VCR Combo
I need a users guide for HIACHI VIDEO PLUS VHS TO DVD RECORDER Thanks
since you have not mentioned your model number look it up here or post the model as a comment so that I can direct you better
Jan 22, 2011 | Hitachi Televison & Video
How do I get an owner manual for this product?
its here for free, available in pdf format will need adobe acrobat or similar.
http://safemanuals.com/user-guide-instructions-owner-manual/LG/RC389H-_E
please rate :)
Feb 14, 2010 | LG RC389H DVD/VHS Recorder
Vhs tape ejects when pressing record
1. Rejected tapes on a VHS recorder is due to a dry belt that is the transfer belt on ejection tray is worn and needs replacement.
2. Because VHS recorder are now not so prevalent and there are so few repair shops specializing in there repair due to parts acquirement it may be best to get a new recorder.
3. Addressing the belts. The belts usually grips a pulley which in turn turns a gear that moves the ejection tray forwards/backwards when given a certain signal on from the control board. This could also be a worn gear from constant use of the load/ reloading of VHS tapes.
I hope this helps.
Feb 05, 2010 | LG Televison & Video
Cannot record t.v. programmes after the changeover on video
I put the recorder channel on AV2 and then recorded it. It worked. Thank you anyway.
Dec 29, 2009 | Samsung SV-DVD55 DVD Player / VCR Combo
LG RC389H. Can't record vhs to dvd
Put both your vhs and blank dvd into the player.
Go into VHS mode and press "Home" menu button.
Scroll across to "Easy Menu" and select "Dubbing".
Make sure you are at the place on your VHS where you want to record from and select the "Dubbing" button.
Press the Stop button to finish transfering.
When it has done recording file information, press eject once and select to finalize the disc.
And that's it!
Sep 18, 2009 | Televison & Video
LG XBR446 DVD Recorder/VCR Logo
531 people viewed this question
Computer Repairing
Computer Repairing
