Question about Panasonic SC-HT1500 System
Panasonic SC-HT1500 System Problem
The problem is that it appears on the screen u99 and I follow(continue) the instructions of the manual but it is not solved.It wanted to know if it has solution
  • 1 more comment
  • marcusbistro Jan 08, 2008
    yes
  • niktea May 08, 2008
    My SA-HT1500 has a U99 error and I cant get rid of it!! Help!!
  • starburst39 Oct 23, 2008
    I have the same problem, I can use the dvd player if I turn off the TV Guide feature. It's been that way for a few years. I haven't been able to record my shows for that long. Recently, the U99 error appeared but I am unable to switch off the TV Guide feature by pressing and holding the CH up and CH down.
    Problem Solver:
  • 9 Answers
You have U99 error due to TV GUIDE. Follow manual instruction for new set up, use bogus ZIP 00000 instead of real one, and you will be fine.
You will not have TV Guide working, but you will be able to set up manual timer recording without problem. I used to have that problem since the first day I bought this unit at the end of 2005. Having something "free" is usually not for free.
Posted on Jun 03, 2009
How do I fix my Panasonic DVD Recorder DMR-XW380
U99 Hi. This indicates a communication error between the timer and main processor unit. Try unplugging from the wall for a minute or two, and plugging it in again, to reset everything.
Sep 12, 2014 | Televison & Video
DVD Recorder MODEL no.DMR-EZ27EB has U99 on screen unable to operate it
Hi.
U99 is a general communication failure between processor and timer, and there may be different causes. Common cause is a defective disk. Removing disk from the drive sometimes may fix the problem.
The first reset that you can attempt is disconnecting power for two minutes.
I quote below a post that was originally published in the MyCe forum (here):
"According to the service manual the U99 error is specifically a "hang up" displayed when there is a communication error that has occured between the main microprocessor and the timer microprocessor.
With more than twenty Panasonics (including four DMR-ES15 models) I'll offer my own observations:
There can be any number of causes for the U99 error, including a culmination of reading, writing, finalizing errors--sometimes appearing after U61 or U88 reading errors. The U99 error might also be associated with unusual DVD Drive noises, "grinding" indicating a dirty rubber hub and spindle; "clunking," "chugging" or "errrp" noises indicating a dirty lens or a failed laser assembly (the "optical pick-up").
Initial remedial measures include the routine DVD Drive lens, rubber hub and spindle area cleaning described in other CDFreaks/MyCE and AVS Forum threads. If that does not correct the problem(s) laser assembly or DVD Drive swapping with a direct replacement may be indicated. Also check for a disturbance to a ribbon cable or ribbon cable contact, correct or repair as necessary.
If the Digital PCB has become problematic, model-specific replacement is indicated. If the DVD Drive on-board contoller (if so equipped) has become problematic, model-specific replacement is indicated. In most cases "model-specific" means the same model year DVD Drive and, with problematic Digital PCBs or DVD Drive controller boards, replacements should be from the same model year and the same or very similar model recorder. Laser assemblies should only be replaced with the same model, i.e., 3331A and 3332A "optical pick-ups" might not interchange satisfactorily.
The U99 error may also be displayed when inferior media is in use. (Beginning in 2008 I've used nothing but Taiyo Yuden 8x Premium Line DVD-R media in my Panasonic, Philips and Magnavox DVD Recorders and HDD/DVD Recorders.)
The U99 error may also be displayed when there is an operating system "time out" occasioned when the user attempts to move too quickly between digital and analog channels (in 2007 and newer EZ series models)."
Apr 26, 2011 | Music
I have an emaching E627. When I turn it on it shows the e logo then goes to a black screen and just stay therel. How can I fix this?
try to go into Safe Mode:
reboot your computer in Safe Mode by doing the following :
  • Restart your computer
  • After hearing your computer beep once during startup, but before the Windows icon appears, tap the F8 key continually;
  • Instead of Windows loading as normal, a menu with options should appear;
  • Select Safe Mode with command prompt, then press "Enter".
  • Choose your usual account.
Once in Safe Mode, you can do a System Restore:
Log on to your computer with an administrator account or with an account that has administrator credentials.
3. Type the following command at a command prompt, and then press ENTER:
%systemroot%\system32\restore\rstrui.exe
4. Follow the instructions that appear on the screen to restore your computer to an earlier state.
Look for the most recent system checkpoint created before the errors to restore from.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Jan 27, 2011 | Computers & Internet
I am getting a U99 error code. The only function
The "U99" error code signifies a "general communications failure."
It is not associated with one specific problem.
It can be related to the version of firmware your DVD recorder is currently using and it has been associated with the TV Guide on screen guide.
If your unit displays U99, turn the power off-unplug the
unit for 5 minutes, and reconnect the power.
If U99 reoccurs, please contact the Global Service Center Network for assistance.
Feb 26, 2010 | Panasonic DMR-EZ47V DVD Recorder/VCR
DVD won't work displayed SLF CHECK, now displaying U99
U99 ≥The unit fails to operate properly. Press [POWER í/I] on the main unit to switch the unit to
standby. Now press [POWER í/I] on the main unit again to turn the unit on.
Let me know if it is still not operating. there was a power failure and that has caused the U99 code.
You can access the manual by clicking the link i have provided below.
CLICK TO BE DIRECTED TO THE MANUAL DOWNLOAD PAGE
the second manual download link is the true English version and the first download link is the alternate language manual..
May 20, 2009 | Panasonic Televison & Video
Mi printer does not print
a) Load the Kodak Inkjet Printer Software CD into the
CD-ROM drive. Follow the on-screen prompts
when the instructions appear.
If instructions do not appear, click Start, then Run.
Select CD-ROM drive and type setup.exe, then
press ENTER.
b) Connect the USB cable to the printer when
instructed. Continue to follow the on-screen
prompts until installation is complete.
Do not connect the USB cable to
the printer until instructed during
software installation.
USB
To set the printer as the default:
In XP:
Start Printers and Faxes
Right-click the icon for the printer you want to use as the default printer, and
then click Set As Default Printer.
In Vista:
Start Control Panel Hardware and Sound Printers
Right-click on the printer you want to use, and then click Set As Default Printer.
Here is the setup guide:
http://www.kodak.com/global/plugins/acrobat/en/service/manuals/AiOPrinters/ESP3/1K3687-ESP3-setup_en.pdf
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Apr 23, 2009 | Kodak EASYSHARE Plus Series 3 Thermal...
Panasonic DMR-EX85 fault code U99
This is the solution from the on line owners manual for you product at www. panasonic.com. U99 ≥The unit fails to operate properly. Press [POWER í/I] on the main unit to switch the unit to
standby. Now press [POWER í/I] on the main unit again to turn the unit on. I hope this helps you with your problem.
Jan 30, 2009 | Panasonic DMR-EX85EB-S DVD Recorder/HDD...
Start up u99 message
Hi there, this is what Panasonic say.... The "U99" error code signifies a "general communications failure."
Feb 17, 2008 | Panasonic DMR-E20 DVD Recorder
U99
Feb 12, 2008 | Panasonic DMR-ES10 DVD Recorder
Panasonic SC-HT1500 System Logo
235 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
