Question about Fisher and Paykel OS302SS, Stainless Steel Single Oven
Oven Fan won't turn off. Has to be turned off at main power source in order to stop it.
  • cbr1100xx99 Nov 21, 2008
    I have the same problem. Mode knob is in the off position and the Temp knob is off - but internal fan stays on and the element is warm to touch.
    Any Ideas - have turned off and on a circuit breaker to reset - no luck.
    Model OS301.
My fan took 30 minutes after cooking to turn off. i think it may have to do with the fact that it is trying to cool the oven?
just wait for 30minutes - 1hr to see if it stops and open the oven door all the way to speed up the cooling
Posted on Jan 24, 2009
What is the worst that could happen if an electric double oven ceramic hob had the neutral and earth mains power wired the wrong way round ?
Electronic controller would most likely be damaged and need to be replaced. These things usually cost between $350-$400
Nov 28, 2014 | Ovens Ovens
Caple C3242SS Double Oven. Fan rattling in Main Oven when turned off after cooking on manual.
Since it is new contact the people that sold you the oven for warrenty repair.
Nov 18, 2014 | Caple Ovens
Belling evolution 152 main oven stopped working and clock gone out.
Have you checked the power source to the oven? Has the cord come out of the wall plug? Has a circuit breaker tripped? Once the obvious things are checked and proven good will it be necessary to dig into the interior of the appliance.
Oct 14, 2014 | Ovens
Cannot switch off oven fan.
Go back to the switchboard and turn the oven OFF, (Switch the fuse off at the switchboard)
Your Oven sounds like it has shorted out.
It could be live, Electricity can cause serious injury and even death,
Get a Registered electrician to check this for you. DO NOT use it.
Looks like you might be ordering out for dinner tonight :-)
Take Care
Feb 09, 2014 | Ovens
Main oven does not heat up
When you turn the main oven on, does the oven fan switch on?
When you turn the main oven on does the cooling fan come on?
Does the dial illuminate when the oven is turned on?
Does the oven thermostat neon come on the the oven is switched on?
Have you had a power failure recently and have not set the clock?
Are you sure that the clock/timer is NOT set and in manual mode?
Dec 13, 2009 | Stoves 720EF Electric Double Oven
Fan will not turn off
you have a faulty cut out stat. if you unplug oven , remove from housing and take lid off
near the cooling fan on top cable tied in the wireing is the cut out . it has 4 wires going in it 2 blue 2white just replace it and will be back to normal hope this helps you
regards dan
Mar 16, 2009 | Electrolux EOC6630 Pyrolytic Electric...
After effects of blown fan oven element on U1721
I think there is an inline fuse for each oven/element.
May 04, 2017 | Neff U1721 Double circotherm Electric Oven
My oven turns off on me after only a minute never heating up fully
Could be caused by either of following;
1. Faulty thermostat.
2. Faulty thermal cut out switch. (controls power to cooling fan).
3. Faulty cooling fan (not fan inside oven).
Test thermostat by setting thermostat to low temperature like 60 oC. If oven gets much hotter then its a faulty thermostat.
To test cooling fan and thermal switch take oven out and remove top or rear panels to expose components.
When oven gets hot the cooling fan should turn on. If it doesn't then check to see if there is a mains voltage present.
If mains current exist but fan is not turning then replace fan. If mains voltage is not present then its the thermal switch.
Jun 19, 2008 | AEG B1180-4 Electric Single Oven
Fisher and Paykel OS302SS, Stainless Steel Single Oven Logo
1,010 people viewed this question
Top Fisher Ovens Experts
Dennis Boxerman
ray gallant
Are you a Fisher Oven Expert? Answer questions, earn points and help others
