Question about Husqvarna 155bt Gas Backpack Leaf Blower
I need to find out the gas and oil ratio mixture.
    Scholar:
  • 110 Answers
The correct ratio for a Husqvarna 155bt is 50 parts gas to 1 part oil, using more oil or the wrong type of oil will cause more damage then good, The high quality synthetic blends of 2 cycle oil like Husqvarna and Echo oils have almost no carbon ash content in them, Carbon ash will form deadly deposits in the exhaust ports and muffler that will rob power and destroy the engine. Also make sure you never use oil marked TWC, this is for water cooled 2 cycle engines and will not transfer the heat correctly for cooling an air cooled engine
Posted on Nov 15, 2009
2 Suggested Answers
  • 6 Answers
SOURCE: What is the gas/oil mixture ratio for the featherlite gas weedeater?
its a 40:1 ratio. remember to never tap the tap-n-go too hard or it will bend the shaft, and make the head hot to the touch, and eventually will melt the inside. And always keep fuel stabilizer in the gas, because if you dont, especially in winter and fall, it will clog the carb so you have to keep pumping the throttle to keep it running and you have to run it on half choke all the time
good luck!
,devin
Posted on Aug 02, 2009
What is fuel mixture on 25 cc craftsman weedwacker
This small engine needs a 40:1 ratio. Use only 2 cycle oil, not motor oil. If you are mixing one gallon of fuel use 3.2 ounces of the 2 cycle oil. This should give correct mixture so you do not get lots of smoke when you start. Take the time to measure. Note: there should be a marking somewhere on the engine about the mixture.
Sep 21, 2014 | Craftsman Convertible 25cc Curved Shaft...
Need gas and oil mixture ratio
The gas oil ratio on all Poulan models is 40:1.
First, I recommend a synthetic oil mix if you can find it and also recommend running a 93 octane gasoline.
Second, I would mix no more than 1 gallon at a time, unless you are doing a lot of cutting.
Gas/Oil mixtures do not last that long. I don't give them more than a month, and generally try to run any mixture within 2 weeks.
Think about it, gas cam gum up on it's own when let sitting for too long. Imagine what it can do with oil mixed in it.
Good luck with your saw, and be careful when cutting.
Jul 07, 2014 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
What is the gas /oil mixture for the 3.4 c.i. PM 605 chainsaw?
See the provided links for oil/gas mixture ratio:
You may contact the manufacturer, download manuals, check fuel/oil ratios, order parts, find your local service center, and view other resources using these links:
Contact us
User manuals
What is the correct fuel mixture for McCulloch products Chainsaw Trimmer...
McCulloch Service
McCULLOCH PARTS ACCESSORIES
I trust this information has proven beneficial.
May 05, 2012 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
Need to know the gas ratio mixture for a Echo Gas Trimmer GT2400 [serial#004349]
hello sir, the gas / oil ratio is, 3/4 o/z per quart or 2.6 o/z per gallon of two cycle oil, any two cycle oil will do,this is how i mix mine and never had a problem,it is a good mix.hope this helps,don't forget the 4 thumbs up,any comments welcome,thank you. ~~
Feb 18, 2012 | Echo Garden
49 CC STREET SCOOTER TWO STROKE NEED THE GAS TO OIL MIXTURE
the mixture ratio is 50 parts gas to 1 part oil. Use only a good quailty stroke oil, never use motor oil
Nov 01, 2011 | Quad 47 cc / 49 cc Pocket Mini Bike...
Gas/oil ratio mixture; chain oil lubricant
Call their customer service at 1-800-242-4672 there are options to choose for gas/oil ratio mixtures info.
May 26, 2010 | Homelite Consumer Products 9.0 Amp, 14 In....
Fuel mixture for MAC 3200 CHAIN SAW
Mix the oil to gas at a ratio of 50:1.The oil bottle will tell you how much oil and gas you need to get to that mixture.
May 11, 2010 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
Oil to gas mixture for a craftsman 3.75 hp pressure washer
There is universal 2 cycle oil available (pro-mix at Lowe's for example) that is good for all ratios from 16:1 to 50:1. With this oil you add the same amount of oil to the gas independent of ratio required. One gas can, no ratio worries. Hope this helps.
Oct 03, 2009 | Briggs & Stratton Garden
Husqvarna 155bt Gas Backpack Leaf Blower Logo
903 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
